Question about Craftsman Blower Attachment
Craftsman 2 cycle blower stalls.
CRAFTSMAN 2 cycle gasoline powered blower / vac Model # 358.794740. This blower starts up reliably and will idle - however when swithched to the "run" position the engine will not accelerate and stalls. It will restart - but stalls when the throttle trigger is pulled. I have cleaned the air filter, installed a new spark plug and a new fuel line filter. What can I do to fix this?
    Guru:
  • 302 Answers
Most Probably the problem lies in the adjustment of the carburettor. There are two needles in the carb one for lowend adjustment and one for high end adjustment. Your lowend adjustment seems fine. The highend needle needs to be adjusted. Following are some very detailed procedures for adjusting these types of carbs
http://tech.flygsw.org/walbro_tuneup.htm
http://www.drystacked.com/Walbro%20Carburetor%20Theory%20ebook1.pdf
If your machine has a carb other than a "Walbro" dont worry the procedures are same. I am sure if your engine has not completed its life span this will solve your problem.
Posted on May 19, 2010
Where can I find a Diagram for a craftsman blower/vac carbuerator
Go to searspartsdirect.com and enter the model number and it will give you a diagram for the carb. Hope this helps.
Aug 13, 2014 | Craftsman 4 Cycle Blower/Vac
I have a Craftsman model 358.797920 32cc blower want to know the mixture of gas per twocycle oil?
Most of these mix at 50 to 1. 500ml of oil to 5 gallons of gasoline should do it. If you don't feel comfortable with this mixture try 40 to 1.
Nov 17, 2010 | Craftsman 4 Cycle Blower/Vac
Someone just gave me a Craftsman 32cc blower without the manual. What fuel does this use?
IF it says 4 CYCLE then it uses regular gas.(87-89 octane unleaded) Another sign to prove it's 4 cycle it should have a crankcase you keep filled with oil.
Jul 18, 2010 | Craftsman 4 Cycle Blower/Vac
Need a repair manual 2c Craftsman Gasoline Powered Blower Vac Mulcher model 38797931
the numbers you have provided do not come up under Sears Parts look up. Can you double check please.
When you have double check you can go to
http://www.searspartsdirect.com/partsdirect/index.action
see if this helps locate what you need
Nov 20, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman blower stalls when choke is disengaged
You need to play with the timing adjustment, either on the spark plug, or the gap between the contact and the magneto.
That'll do it ;)
Don't forget to rate, thanks
Jul 31, 2009 | Craftsman 4 Cycle Blower/Vac
CRAFTSMAN LEAFBLOWER TROUBLE
After you do the above, try to clean out the fuel line. It may only be letting in a small amount no matter the throttle control.
Dec 30, 2008 | Craftsman 4 Cycle Blower/Vac
Craftsman leafblower running worse
Check the exahust screen (if fitted) for blockage. or exahust port...If it is clean port and or screen and use correct type/ ratio mix.
Dec 14, 2008 | Craftsman 4 Cycle Blower/Vac
Craftsman Blower Attachment Logo
1,016 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
