I have a Model VIZIOP50HDM. I was having issues with HDMI1 and 2 but the AV1 and 2 work ok. Replaced the main logic card and the problems persist. Discovered additional symptom as follows. If you hit the Menu button nothing happens. If you hit the Input button followed by the Menu button the Menu comes up and we can scroll through options. Also, if you hit the Volume nothing happens. If you hit the Mute and then the Volume then we can turn the volume up or down, Help, Any suggestions?
  • 1 more comment
  • msheared May 03, 2010
    Will a HDMI cord stop the Menu from being displayed?
    Please focus on the following symptoms please: Discovered additional symptom as follows. If you hit the Menu button nothing happens. If you hit the Input button followed by the Menu button the Menu comes up and we can scroll through options. Also, if you hit the Volume nothing happens. If you hit the Mute and then the Volume then we can turn the volume up or down, Help, Any suggestions?
  • msheared May 04, 2010
    In which manual can i find Service Mode" option to restore all default settings, do a "Reset" as it were. Also, you do realize the symptoms are the same with either the buttons or remote contol. The manuals are useful but we can not find the Service Mode option to reset all default settings.
  • 4,889 Answers
It is possible that the replacement logic control board you have purchased is also faulty. As you can see none of the buttons are working as they should. Always order the part by the part number as there can be different versions of the component in the same model. If you have done so and still these problems appear then you can be sure that the replacement board is faulty. I have seen this happen quite a few times.
Sai.
Posted on May 04, 2010
  • 12,061 Answers
Http://www.retrevo.com/support/Vizio-P50HDM-TVs-manual/id/512ci072/t/2/
nationalservicealliance.com/visio/VIZIO-P50HDM.pdf
Please find above, Top, you user manual, below that, your Service Manual, this is what us engineers use to troubleshoot and repair these units. You need to enter "Service Mode" and restore all default settings, do a "Reset" as it were. This at least will put you set back to the default settings and you can work from there.
http://www.scribd.com/doc/2893683/PANASONIC-CHASSIS-TH42PHD5-TV-PLASMA-TRAINING OK above is a Training manual, also below is another training manual, i am sure you will find all these manuals will assist you in sorting out your issue
http://www.schematicsforfree.com/archive/file/Sony/Video/Sony%20Plasma%20Training-1.pdf
Posted on May 03, 2010
  • 10,865 Answers
Hello. replace your HDMI cord. Many of them are duds
We have a Zebra 110 Xi4 that gives me the error printer not accessible...I have tried uninstalling and reinstalling the printer and still get the same issue
Depending on the type of connection you are using it could be a Main board issue or Ethernet card failing. Make sure it is a printer issue and not a problem with cabling, IP addresses or your PC before replacing any parts. (ignore pictures FixYa is grabbing the wrong ones)
Main Board ZEBRA P1004273 MAIN LOGIC 8MB XI4 SERIES New
Ethernet card ZEBRA 79501 011 KIT INT PRINT SERVER 10 100 Refurbished
Sep 27, 2017 | Zebra Office Equipment & Supplies
Samsung PN50C550G1FXZA clicking on and off, already replaced power supply board, main board, and main logic control board, yet the problem persists, what else could it be?
Those blinks are short circuit indication. Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 05, 2017 | Samsung Touch of Color PN50C550G1FXZA 50...
Wf-t1050 lg fuzzy logic Once start button press water start filling and draining at same time. The water inlet and outlet works at same time. I have replaced a new circuit board but problem persist.
does this issue happen when your starting the washer? (some may flush themselves out from any left over build up of soap maybe but im not sure if this is the case)
Sep 10, 2016 | LG Washing Machines
I charge my battery of my Samsung Galaxy TAB Lite 7 SM- T116NDWAXFA White CT. I cannot use the phone for anything. If the charger is in it only shows a green 100% battery and nothing else.
Samsung Galaxy Tab 7 Troubleshooting
Tablet Doesn't Turn On No matter what you do, you can't get your tablet to turn on.
Press and Hold the Wake/Sleep Button
If this does not resolve your problem, read on!
Check If Battery Will Charge
First, connect your tablet to the power adapter. Hopefully the tablet will recognize the charger and begin to recharge the battery. If it does not, the battery may be defective and need to be replaced.
Faulty Display
If you determined that the battery was working, it is possible that the display is broken. If no light or images are visible, but the tablet has power, then the display may need to be replaced.
Bad Logic Board
If none of the previous solutions solved your problem, check all of the connections from the display to the logic board. If the device still does not turn on, the logic board in your device most likely needs to be replaced.
Screen Doesn't Respond to Touch Nothing happens when I touch my screen.
Screen protector/tablet case interferes with the touchscreen
Try removing your screen protector or case from the device, and test the touchscreen again.
Caution: Some screen protectors may not reapply properly.
Perform a Soft Reset
A soft reset restarts your device and does not erase any of your content or data. Begin by pressing and holding the Power key until your device turns off. Wait a moment, then press and hold the Power key to turn your device back on.
Bad Touch Screen
The touch screen may be bad and need replacement. The front panel (which includes the touchscreen and digitizer) should be replaced.
Bad Logic Board
If the problem persists, the logic board may need to be replaced.
Tablet Overheats Tablet is too hot to touch!
Reset the Device
Hold down the power button until the device shuts off. Let it cool down for a few minutes, then hold the power button until the device powers on.
Bad Battery
If the device continues to heat up, the battery is most likely defective and needs replacement. Purchase a replacement battery, and replace the old with the new.
Tablet Performs Slowly
Safely Remove Your SD Card
From the home screen, tap the Menu key, then tap Settings. Once in Settings, scroll to and tap Storage. In Storage, scroll to and tap Unmount SD card, then tap OK. You can now safely remove the SD card.
Close or Uninstall Applications
In the Power Usage dashboard, tap Battery Usage. Next, tap the application you want to close or uninstall.
  • To close (turn off) an application, tap Force stop.
  • To uninstall (remove from device) an application, tap App info, Uninstall, and then OK.
Verify That Your Tablet is Running the Most Recent Software
Begin by tapping the System Updates dashboard. Next, tap Device Software, then tap Check now. If an update is available, follow the prompts to install.
Tablet Doesn't Produce Sound No audio from headphones, speakers, or tablet itself.
Bad Headphones/Speakers
Check to make sure your playback method isn't the problem. Check all speaker connections and test headphones on another functioning device. If the problem is not resolved, your tablet may be the issue.
Software
First try a full restore on the tablet to make sure it is not an issue with the software.
Bad Audio Jack
If the problem is still not resolved, try replacing the audio jack. If that doesn't solve the problem, your logic board most likely needs replacement.
Aug 02, 2016 | Samsung Galaxy Cell Phones
I have recently bought a sony bravia model number KDL-40EX710. The input channel either keeps flicking to another input channel, ie AV1 to HDML or when on AV1 or AV2 the channel confirms itself at the top...
Your connections might be loose and the tv is constantly recognizing the connection over and over, that would explain the pop up. I would imagine the picture would be distorted somehow if that was the case but worth a try. If the problem persists after trying a good new cable then I would call the manufacture.
Aug 24, 2011 | Televison & Video
Model #50PC1DRA no picture but we have sound we replaced the zsus board and main logic main board and still no picture
Hi
Thanks for using FixYa. As you have already replaced the Z-sus and the main logic board then the issue seems to be with the Y-main and/or Y-sus board. You’ll need to take the back off and check for any blown/bulged capacitors that might have gone bad and causing this issue. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 02, 2010 | LG 50PC1DRA 50 in. Plasma Television
How I can solve hummer voltage 1
You must check the adjustment of your AVR and the Machine Voltage Switch.
Feb 15, 2010 | TallyGenicom 6306 Matrix Printer
Hdmi port
I have a 50 inch and recently had to have the main board replaced d/t the IR receiver was failing intermittently. Since they replaced the main board, one of the two HDMI is doing the same thing (picture, no sound). When I spoke to service they felt the issue was related to the replacement board and will be replacing. The weird thing is the picture is not quite right + no sound. Usually with HDMI it's either all OK or not OK at all. In any event, my problem seems to be the main board.
Aug 20, 2008 | LG 42PC3D 42 in. Plasma Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
