Question about Amana NDG7800AW Gas Dryer
It takes hours to dry small load
My amana dryer is three years old, and it takes 3 to 5 hours to dry one small load. I checked the vent, it is clear and there are not any binds in the hose. The igniter ignites the burner, but only for a very short time aprox. 20 seconds then the heat stops. This on and off procedure continues for hours. What would cause this to happen?
  • robert samples May 11, 2010
    take the vent loose and dry a load let me know how it does and how long does the burner stay on before it cycles off this will help narrow the problem oh i see 20 secs sorry but take the vent loose for one load and feel the airflow comming out the back for heat and force
  • 550 Answers
Dud thermal sensor, the temperature is shuttimg off too low
locate, replace the thermal sensor just 'downwind' of the flame
Posted on Jul 29, 2008
Takes too long to dry clothes
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
Takes several cycles to dry
The dryer takes three hours to dry a large load. It is almost one year old and it seems to take longer than it used to and the clothes don't actually get that hot anymore
is your dryer getting hot if so disconnect your dryer vent and run a normal load and if it drys that load in a normal ammount of time it is your vent pipe in the wall clogged
Mar 16, 2010 | Maytag Dryers
Amana Special Edition Electric Dryer Model ALE868QAW not drying
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these. Vent Heating element Internal ductwork Cycling thermostat Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jan 01, 2010 | Dryers
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
THE DRYER TAKES TWO TO THREE HOURS TO DRY ONE LOAD
Vent
Heating element
Internal ductwork
Cycling thermostat
May 20, 2009 | Dryers
Takes 3 hours to dry a small load, dryer is 3 1/2 yrs old
You need to clean vent hose and vent line in wall of house.
May 08, 2009 | Dryers
Amana dryer model #LG4309W doesn't heat up like it used to
you need to get a vent cleaning the recommend that you get one evey 6 months with a gas dryer.
Dec 10, 2008 | Amana ALG443RAW Gas Dryer
Dryer not drying
try taking a flashlight and look over the back of the drier see if the vent got mashed or is all coled up and stuff let me know also you can remove the vent from the back of the drier and run 1 load to see if it works normal if so then you know the vents the culprit.
Jan 16, 2008 | Amana NDE2335AY Electric Dryer
It takes 3 hours to dry one load
vent restiction look over the back of the drier and see if the vent is mashed folded etc then turn drier on go out side to where the hood is see how much air is comming out if very little find out whats blocking it
Dec 31, 2007 | Amana NDG7800AW Gas Dryer
Amana NDG7800AW Gas Dryer Logo
126 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you an Amana Dryer Expert? Answer questions, earn points and help others
