Question about Epson Stylus CX4600 All-In-One InkJet Printer
Problems 4600 I hadn't used the printer in a few weeks- wouldn't work although I tried to run throught he cleaning steps on the machine. I turn off the machine, hold down the power and ink buttons like it says to, release, it slides the cartridge holder back and forth a couple times, stops and the ink light cames on steady and the power button flashes. I thought the ink had dried out so I even went and purchaced a new blk ink cartridge-- still the same results. PLEASE HELP!!! The guy at the cartridge place told me I would prob. have to throw the printer away--- it is brand new! Hasn't been used but maybe 6 times!!!
  • 35 Answers
I'm sorry to say, but he is probably correct.
Read these instructions for manually cleaning the heads.
http://www.fixya.com/support/t743789-printer_will_not_print_even_though
Posted on Aug 13, 2008
  • Jefferson Casavant
    Jefferson Casavant Aug 14, 2008
    I am going to copy the instructions from the linked page to here, for your convenience.
    The ink heads are clogged with dried ink.
    Follow these steps:
    1) Begin saving money for a new printer.
    2) Lift the scanner to get at the ink. Remove the cartridges.
    Take cotton swabs and alcohol and clean all the ink off of the top of the heads (located in back. they're the pointy things) until you can see the holes. THE CRUCIAL STEP: Insert something-small enough to fit in the holes-all the way through every hole in every head. This should clean out the dried ink and allow your printer to continue to work.
    3) If step two doesn't work, I really hope you did step one.
    Don't buy an Epson. They also have this other feature which prevents printing when one cartridge is empty. Even a color cartridge. I recommend a Canon, if you like name brands, or an HP.
    To Clean the Main Print Head
    Remove the ink cartridges.
    There are two screws on the gray ink lid, visible when open. Unscrew them, and then remove the lid. There are three screws inside the ink carrier. Remove them.
    Get a pair of Needlnose Pliers and a flat-head screwdriver.
    There is a plastic plate near the front of the ink carrier, at the base. It forms a right angle with the left side. On the top of the left side portion of this plate, insert the flat-head screwdriver and lever the plate inwards. It will come off to reveal two gray cables. Take the needlenose and grasp one of the ink heads. Pull upwards and towards yourself. When you can, remove the two cables from the ports in a straight outwards direction. This should free the main print head from the rest of the printer.
    At this point, you can purchase a new main ink head or wash your old one. I am cheap and chose to wash the old one.
    Get a small tub and some rubbing alcohol. Pour the alcohol into the tub, and immerse the print head for several hours, shaking every once in a while.
    Now comes the long cycle of cleansing the head totally. Have a rag ready. Remove the head from the alcohol, and wipe off the smaller print heads (the points). Then, (here comes the crazy part) put it up to your mouth and put as much pressure as you can into all four, for about ten seconds. Turn the head over and wipe off the ink that has come out. Repeat until no more ink comes out. Then, immerse the head again, remove, and allow to dry naturally (or possibly by blowing on it). Make sure the two ports for the cables are dry.
    Reassembling the printer/Inserting a new or refurbished head
    Before pressing the head back into place, connect the cables, right one first. There is an indentation on the top side of the head for the cables to fit. Then, place the head snug into the ink carrier, front side first, angling towards the back, until it is flat. Reinsert the plastic plate. There is a small tab on the right side of it, and that goes into the slot near the end of the right cable. Press the plate back into place gradually moving towards the left, starting from the tab. Put back all three screws, two on the top and one on the middle right. Reattach the cover, with the two screws on the left and right. Reinsert the cartridges, and you should have a working printer.
Roland Versacamm sp540v is not printing yellow or magenta. What could be causing this? We were out of town and it wasn't used for a few weeks.
your print head dry out, cause is: no use! you should detach the tube between the pump and the caps, the one of magenta and yellow, insert a seringe in the tube (that comes from the cap) and suck some cc´s of ink, .then atatch the tube again and run one or two powerful cleanings, then run the test. A smart advise is: never turn off the machine in the main power, the machine when in stand by, does automatic a check and a cleaning process from time to time if needed.
Jun 24, 2012 | Roland VersaCAMM SP-540V
Tip
How to clean out your stovetop kettle
I've been using the same kettle on my stove for about a year and I hadn't cleaned it even once until last week.
A while ago I started noticing these weird white chucks that would come out with the water but I just figured that it was because I get a lot of use of out my kettle.
It turns out that the white chunks are actually limescale.
I did some research on it and thankfully limescale is not harmful to ingest. However, it's pretty gross to look at and I certainly wouldn't want to serve a cup of tea to a guest that is filled with strange white flakes.
So I figured out how to clean my kettle with stuff I have at home.
All you need is some regular cooking vinegar to do the descaling for you.
There is no need to buy expensive chemicals that you wouldn't feel safe using on a cooking product anyway.
Start by rinsing out your kettle with warm water.
Then, fill half of it with water and the other half with vinegar.
Place it on your stove and let it come to a rolling boil.
Then, just leave it there over night.
When you wake up in the morning, dump out the water and vinegar solution.
Take a long scrubbing brush and scrub the inside of the kettle to remove whatever limescale is left.
If there is still some caked on, you can repeat the steps over again.
If your kettle is clear of the grime, simply rinse out a number of times with soap to get rid of the vinegar taste/smell.
Voila! Your stovetop kettle is clean and no more unidentified chunks in your tea!
on Jan 06, 2014 | Home
Haven't used printer for several weeks, although ink in cartridges print barely visible, tried new cartridges with same result
Dear plloyd, You had left the printer many times, which indicates that the printer heads are jammed due to non use. So go to the printer property in control panel - printer and faxes - your printer. In printer property go to maintenance. There is the option of head cleaning. Run the head cleaning programme twice or thrice. You will see, your old cartridges also can work. Thanks.
Sep 05, 2011 | Kodak ESP 5 Printer
I have a 1999 road king flhrci, and last week i changed out my seat to try another one, and accidentally unplugged the wire to the fuel pump sending unit. I tried several times to start it, and it...
Pull your codes i think you do it by alternating turnsignals ,,or cycle ing switch 10 times .w/ reset codes if there hard codes they will return ,,.you will find great help at harleytalking.com they have helped me good luck ....
Aug 16, 2011 | Harley Davidson FLHRCI Road King Classic...
No water comes out on ventilate. At first, the water was coming out very slowly, in drips. The doser or grind were not the problem, because even when I switched to Hot Water, it was still dripping. ...
Hi
It should take about 45 minutes to an hour to properly descale the machine. If it only took a couple of minutes you really didn't descale your machine. If you used the powder it has to disolve completly before descaling. The best way to descale is with the descaler in the tank. Turn on the machine and run about 8 ozs of water-descaler through the wand and then turn off the machine. Wait 10 minutes and repeatthe last procedure. Do this until the tank is empty. When done with the descaler, rinse out the tank and put fresh water in the tank and run the whole tank through the wand. Then fill the tank and your ready to go.
Nov 13, 2010 | Gaggia Syncrony Compact Coffee...
Hi! printing flight boarding passes on Epson
run it through a cleaning mode.
in ctrl panel
select printer and r click go to
properties and then the
maintenance tab.
Run clean
Run Nozzle check
When it prints correctly
ensure you select paper size as A4 and print your pass.
Pleazse rate my help++++Thanks for using Fixya
Jun 04, 2010 | Epson Stylus C46 InkJet Printer
I haven't used my canon pixma for a few weeks, came to use it again and the 3e black cartridge won't work, (tried printing from computer and copying) have done a clean, deep clean and nozzle check, even...
The black print head is clogged. The reason why the black is clogged and not the photo black or any colors is that the black is pigment ink and the photo black and colors are dye based ink. The pigment ink is a particulate formulation that binds up when water is evaporated out of the ink. You need to buy a new print head the fix the problem. You can buy a new print head for $75 from precision roller.com.
Mar 18, 2010 | Canon PIXMA MP780 All-In-One InkJet...
It leaks. It's all over the inside of machine. We don't use this printer a lot because we do design on-line; so it's not from overuse or worn out parts. It just leaks and then causes the printer to stop...
I have had problems with a number of brand new genuine HP toner cartridges leaking on this printer. Strangely, I have had almost no problems with non-OEM cartridges from Cartridge World.
I can’t explain this...and wouldn’t have believed this if I hadn’t experienced it myself.
Try removing all toner cartridges, and carefully cleaning out the printer with canned air. Then replace the leaky toner cartridges with Cartridge World cartridges. This has been my recipe for success with the HP Laserjet 4600.
Nov 16, 2009 | HP LaserJet 4600 Printer
Hp 1200 business inkjet help
I have a solution that is very similar to that printed above.
I have tested it on five installations on the computers on my home network and an HP Business Inkjet 1100, and the PCs running Win XP SP3.
Step 1) If you are setting up the printer from the HP CD, decline the question where it asks if you want to print a test page, (this will avaoid the first print job before re-setting the dates).
Step 2) Reset your clock back to a year prior to the year when your cartidge expired.
Step 3) Print a test page, or two. Or a few pages from any application.
Step 4) Reset your clock back to the current year.
The printer now prints fine. Since I performed the sequence above I have been printing with the "expired" cartridges for a few weeks. I have printed on about 15 occasions over the past few weeks, amounting to about 50 pages. No problems so far. I don't know how long this solution lasts or whether I will have to go through it again.
I have gone through a few different "solutions", including a Registry hack that didn't work, but this simple solution above has worked every time on five different installations.
I did not need to turn the printer on/off, and did not need to re-boot the computers.
However, if I sent a print job to the printer before performing the sequence described above, and the printer gave an "expired cartridges" error, then I would need to turn the printer on/off to clear the error, and flush the print queue.
Jan 28, 2008 | HP Inkjet 1200dn Printer
Epson Stylus CX4600 All-In-One InkJet Printer Logo
103 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
