Question about Dell E173FPf 17" TFT LCD Flat Panel Monitor
Service manual dell e173fpf - Dell E173FPf 17" TFT LCD Flat Panel Monitor
  • saznote May 04, 2010
    3lik bessabr ya weldi :)
  • 11,361 Answers
Try here:
http://elektrotanya.com/?q=showresult&megnev=dell&megnev2=e173&kategoria=&kat2=all
Most E152/153.172/173 have same problem, poor solder joints, blown fuse, shorted transistors.
http://s807.photobucket.com/home/budm/allalbums
Replacement bd: www.lcdrepair.us
Hope it helps. Please post back.
Posted on May 04, 2010
Everything on my Dell Monitor E173FPf is tiny, what gives?
You need to re-set your screen resolution, RMB on your desktop and select properties - settings.
Jan 21, 2011 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell E173FPf 17 vertical line problem
Yes, but the cost is not worth it. If you get it apart you will no doubt find a couple of bulging capacitors. Dell site has the disassembly instructions.
Oct 10, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Can i connect a dvd player to a dell e173fpf monitor with a scart to vga adaptor/cable?
You can with an RCA to VGA converter device (Amazon has it for $45 S&H), the AV cables of your DVD player and a pair of amplified speakers. Connect the yellow RCA video cable to this device then your monitor's VGA cable to the device. Also plug in the red & white RCA audio cable to both the device and to your DVD player. Finally connect your speakers to the DVD player ad your'e all set!
Jul 04, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
No power to monitor
4 years is a good life for a monitor, so i agree you can stick to Dell since its already proven itself... :) - As you mentioned, this monitor is not currently being sold from Dell, I would suggest an upgrade to a 19" - http://accessories.us.dell.com/sna/productdetail.aspx?c=us&cs=19&l=en&sku=320-5629 or a 23" one http://accessories.us.dell.com/sna/products/Displays/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=320-7339 ... if i were you, i would choose a 23", but for a higher pricing :) (Answered this earlier for someone else too i suppose!)
Dec 30, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
Flat Cable (P-Two AWM 20969 E221612)
you need to be patient because if you cant get it from the dell stores and still you can get it online you will need to visit a computer hardware vendor/ repairer who have thesame monitor but the monitor is completely damaged so that he can repalce it for you. but it is going to be expensive.
Dec 16, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
NO POWER ON INDICATOR LIGHT AND NO Screen Raster on Monitor
Initially, pls check D854 on the Power Supply/Logic board. It is a dual diode. If you would prefer board replacement rather than component level repair, this might be of help. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
This is of course in addition to checking the usual, power cord, fuse, outlet etc.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell E173FPf lcd- no picture,steady green light
E173FPf Mfg December 2004
This E173FPF has changed much inside from the November 2003 E172fpb which had the famous 4 identical transistors 5707 that would tend to fail in pairs. If your newer E173FPF displays a green power light and fails to display a picture try replacing the 220uf25v capacitors at C6 and C26. Test them with a volt ohm meter and they will test Ok, replace them anyway. Radio Shack did not have the 25v so I used the 35v, display works fine now. There is an E173FPF repair kit with directions available on Ebay if you don't have a parts store in your area and would prefer delivery.
i'm not an expert at anything...x'cept maybe dumpster diving. God Bless
Jan 14, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
No power in dell e173fpf
I would expect the same (new) part failed. Try another dual diode otherwise you may be chasing the problem around the board.. Good Luck, Tim
Feb 19, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FPf 17" TFT LCD Flat Panel Monitor Logo
978 people viewed this question
Alun Cox
