Question about Generac Guardian Ultra Source 15,000 Watt Portable Generator #04582
Size of LP gas tank recommended for Generac Guardian Stand by gen
My dad purchased a Generac Guardian stand by generator. It is rated at 16000 kw sstained. He can find the info concerning the installation of the generator itself but has questions about the size of the LP gas tank that is recommended to run the generator.
4 Suggested Answers
  • 26 Answers
SOURCE: Attempted to start Generac Guardian 15 kw air
I work on these every day. Its either gonna be the rotor or stater, the voltage regulator, but most likely its a bad stepper motor which is the throttle motor, or control board. Thats all that could be causing that so its one of those. If its the rotor or stater thats bad it causes the generator to RPM up because it thinks its not producing enough power due to that. I had the same problem with the same one we just fixed and it was the slip rings on the end of the rotor so bad rotor.
Posted on Jul 09, 2009
SOURCE: Generac Guardian 15 kw overspeed fault
Did you remember to set the overspeed shutdown threshold on the control board?
Posted on Jun 07, 2010
  • 3 Answers
SOURCE: I have a 10 KW Generac Guardian Stand By withe a
Hi, I have a 10kw Generac Generator and I went out to check on it to see that all was working and saw the display panel blank. The generator wont turn over. This was installed 3mos ago and all was fine. It has an automatic transfer switch in the main panel. I tested to see if the gen was getting power from the 2p 15amp breaker and showed power to gen. I think it might be the battery charging system were can I find this?
Posted on Feb 27, 2011
Generac power management module install
Mount the transformer on the generator. Hard wire it into a 120 vac plug. Run wires to the module and connect to the coil on the relay. Now run the load you want to disconnect while the generator is running to the load terminals of the relay in the module.
Sep 10, 2016 | Generac GUARDIAN Air-Cooled Automatic...
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
Feb 08, 2016 | Generac Guardian Air-Cooled Standby...
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
Under voltage alarm /shutdown on generac 10 kw gen.
The brushes on Generac automatic units are most likely not lined up with the slip rings and will wear down and burn out very fast. There is no way of checking this during assenbly because they are hidden from view and the generator has to be dismantled to be able to replace them. It's an extremely poor design and Genrac should face a class action lawsuit for producing this piece of junk.
Sep 18, 2012 | Generac 6051 Guardian Series Air-Cooled...
I have a 10 KW Generac Guardian Stand By withe a prwired EZ transfer swithc. Everything works except the 12 volts battery charger. What could be the problem. Only have three weeks innstalled.
Your generator is equipped with a battery trickle
charger that is active when your unit is set up for
automatic operation. The trickle charger is
designed to help extend the life of your battery by
maintaining the battery when the unit is
not running.
you will need to review which circuit bord controls this and have that board replaced or serviced some of these gen heads have this built in and it will be the rectifier in the gen it self it will be a black 1x1x3/8 inch with a mounting hole in the center and 4 lug post for the wires replace this and your issue should be solved but consult your dealer for witch unit you have as to a control board external or the built in rectifier hope this helps.
Aug 11, 2010 | Generac Guardian Series 5502 10 kW...
10kw Generac shut down overspeed
Make sure that the throttle linkage is all there and not damaged/misadjusted, then get a manometer and check your inlet gas pressure. Gas pressure should be 8 inches of water column and stay there running or not.
Carl
Apr 06, 2009 | Guardian Electrical Supplies
Apr 03, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
16 KW guardian generator
My answer:
Your Genset is made by GENERAC same as my personal 5500W home unit is. Great service and great Genset!!
I never had any problems with mine other then the Poly gas tank valve stem gasket leaked from day 1, and they replaced it no bones 100% FREE upon request. I also requested both a Service manual and an Operators Manual and they sent me both FREE of charge as well. (I had no manuals with mine either, as I bought my Genset brand new at a garage sale for $300 - great deal)
Just make sure when you call them (as with anyone seeking operator/setup manuals - that you tell them they got LOST in a recent move!) It helps - otherwise they (any company) might ask for a charge for them. Getting pretty bad out there everywhere thanks to you know who!
Call the GENERAC toll free # below anyway - regardless what it says below about the GUARDIAN brand and where to get service. You want the Install / Service manuals only.
Corporate Mailing Address
Hwy. 59 & Hillside Road
P.O. Box 8
Waukesha, WI 53187
GUARDIAN® Inquiries
All GUARDIAN products are sold through and represented by our Independent Dealers, The Home Depot® stores, and GUARDIAN Authorized Service Centers nationwide. For information or questions about GUARDIAN products, please contact one of these representatives. To locate a dealer nearest you, please visit the Dealer Locator page on the GUARDIAN Web site.
Generac® Inquiries / Customer Support
For Information or questions about Generac generators, switchgear products or Generac OHVI® engines, please call the phone # below. If you need immediate assistance, our Customer Support Department is available Monday-Friday, 8:00 a.m. to 5:00 p.m. Central Standard Time.
Phone: 1-888-GENERAC > 888-436-3722
Fax: 1-262-968-3791
Please post me a reply as to finding this solution being the best resolve to your GENERAC / GUARDIAN service manuals problem by following my recommendations above. Also please rate my troubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
Sep 06, 2008 | Electrical Supplies
Generac Guardian Ultra Source 15,000 Watt Portable Generator #04582 Logo
102 people viewed this question
Top Generac Guardian Electrical Supplies Experts
Craig Butler
Craig Butler
jdthefixer
epangan29
Are you a Generac Guardian Electrical Supply Expert? Answer questions, earn points and help others
