Question about Hitachi 43UWX10B 43" Rear Projection Television
Philips 43pp9202 I got the same problem with my rear projection and i replaced the Ics STK 392-150 and the resistors over-heat ( at the beginning they were for the blue color proyector). when i changed everythings and turn on the tv again, the resistors for the green color projector got over-heated, and for the deflection problem, before it was the blue one now it is the green one. My question is : why are the resistors getting over-heated ?
  • nanucero Apr 03, 2008
    Thanks for your information Terryfic. I'm sorry i did the question when was reading the same problem, but in a Hitachi t.v. My question is: Can i use the same part X480293 on my Philips 43pp9202 ?
    I Was looking for the ic's STK394-160E by Sanyo but they say that it works for Hitachi Tvs only.
  • nanucero Apr 21, 2008
    Thanks Terryfic for you information about Philips - Hitachi. I did start again using the STK394-160E (CZ01341) and i changed the resistors for Philips (6.8 Ohm 1W ). Everything looked well. The display is showing, but the convergence is Terrible. All the colors are bent out of line. and when I tried to fix the converge manualy, the convergence setting doesn't respond. it stays fixed in one place. What could be the problem?
    Genius:
  • 1,694 Answers
Because the STK's used were not first quality....For STK392
-110,-120 and -150's I use STK394-160E made by Sanyo with
Hitachi part # CZ 01341 or you can buy a kit of two IC's and
some resistors ( Hitachi application ) for less money. Now you must start again............................T.
Posted on Mar 27, 2008
  • 1 more comment
  • Vista Electronics Mar 28, 2008
    PS. Kit part # X480293..........................T.
  • Vista Electronics Apr 03, 2008
    I use the Hitachi kit for Hitachi, Toshiba, Philips and any others
    that use -110,-120 or -150 original IC's......just keep in mind the
    resistors in the kit are specific to Hitachi chassis'............T.
    Your TV was made by Hitachi with Philips name on it !!.............
  • Vista Electronics Apr 21, 2008
    Check fuse devices in power supply...soldered in pico fuses....
    Check voltages that operate convergence,they flow through the fuses....................do you have Service literature ?
Philips 64p9161006 I changed stk-150 still same problem what else can it be screen warped
Did you replace the (12) 6.8 ohm resistors when you replaced the ICs? There will always be at least 1 of the resistors that will be blown when a phillips ICs fail.
Oct 20, 2010 | Philips 46PP9302 46" Rear Projection...
Red curves on bottom and top of picture
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 18, 2009 | Philips 43PP9202 43" Rear Projection...
Phillips projection tv will not converge
Replace Both convergence ICs STK392-120s use 180s better ICs they are big black ICs will have STK on them Mat Electronics for parts 1-800-628-1118.Also CK 6.8 ohm resistors around STKs.
Dec 30, 2008 | Philips Magnavox 51MP392H Rear Projection...
Power wont come on and blinks 4 times every 1o seconds?
Replace your STK ics 2 of them big black ics STK392-560 go by STK on part in set.
Dec 22, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Rear Projection TV 43PP9202 Picture looks 3D
You need to replace both convergence ICs they are STK392-120 you will also need about four 6.8 ohm 1 watt resistors. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures. here is the link.
http://servicemanuals.vstore.ca/
Jul 20, 2008 | Philips 43PP9202 43" Rear Projection...
Convergance
Its a straight forward repair just take out the convergence ICs and solder in two new ones. takes about an hour from beginning to end. just apply heat sink compound on the new ICs before installing them. And in that model check the resistors right next to the ICs as 1 or 2 of them often burn open when the ICs go out. Let me know if you need any additional info. The ICs cost about 10.00 each you will ned two.
Mar 23, 2008 | Philips 43PP9202 43" Rear Projection...
Replacing convergence ic on Philips 43pp9202
IF you can solder yes you can fix it yourself. Replace STK-392-110s with STK-392-180s,
Nov 22, 2007 | Philips 43PP9202 43" Rear Projection...
Convergence Problem
you nid change the [stk] of comvergency and chek the resistors tha sorce de negative -volts -28 or -30 many times thises resistors is open!good loouk [disculpa mi falta de ortografia mi primer idioma es espanol saludos!efrenhd@aol.com.
Dec 10, 2006 | Philips 7P4830W 48 in. Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
50 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
