Question about Brother MFC-465CN InkJet Printer
Comm error 2001 or 2006 on a brother mfc 465cn wont fax at all
Healeyman
  • 1198 Answers
SOURCE: have voip and brother mfc 7420. error code 2001 and 2006
Get a new phone wire. Put a phone on the line and listen for static. Too many phones on one line will cause problems. If the phone line is going thru a surge protector, check the quality of the sound with it and without it, it may be damaged. Keep power wires away from phone wires, they cause static.
Posted on Apr 26, 2009
  • 240 Answers
SOURCE: how can I delete the memory on a brother mfc-465cn
Review page 65 in your manual. Changing the "Advanced Fax Operations:"
If received faxes are left in your machine's
memory when you change the Advanced Fax
Operations, the LCD will ask you one of the
following questions:
Erase All Fax?
Yes - Press 1
No - Press 2
Print All Fax?
Yes - Press 1
No - Press 2
• If you press 1, faxes in the memory will
be erased or printed before the setting
changes. If a backup copy has already
been printed it will not be printed again.
• If you press 2, faxes in the memory will
not be erased or printed and the setting
will be unchanged.
Posted on Dec 11, 2009
Semi-Driver
  • 434 Answers
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Posted on Jan 21, 2010
  • 300 Answers
SOURCE: my brother mfc 465cn keeps saying paper jam. I do
The paper sensor is either stuck or dirty.
Just open it and follow the paper path and you should see where it is.
Otherwise, the sensor may be bad.
Posted on Apr 18, 2010
Samyfam
  • 378 Answers
SOURCE: Brother MFC-465CN printer. Need a fix for error 46.
The problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Posted on Jul 12, 2010
How to receive fax in brother printer mfc-465cn
Welcome to Fixya.
Please follow the link specified below as this will direct you to Brother's site where you can view/download the comprehensive user's manual :
MFC-465cn Manual
You will learn how to make the most out of your printer by going through this.
Thanks for using Fixya.
Jul 01, 2011 | Office Equipment & Supplies
Jul 09, 2010 | Brother MFC-465CN InkJet Printer
My brother mfc 465CN wont print black only color
Have you tried cleaning the print head? Find the instructions in the troubleshooting and maintainance section of the manual here http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_465cn_EN_1269.PDF
Jun 04, 2010 | Brother MFC-465CN InkJet Printer
Brother mfc-465cn opening raster file failed
Try downoading the drivers from the apple web site. You would need the brother 1.1 drivers download.
Remove printer then added it again
Jan 02, 2010 | Brother MFC-465CN InkJet Printer
How can I delete the memory on a brother mfc-465cn printer fax machine? It will not receive faxes due to this
Erase All Fax?
Yes - Press 1
No - Press 2
Print All Fax?
Yes - Press 1
No - Press 2
will be unchanged.
Dec 11, 2009 | Brother MFC-465CN InkJet Printer
Have voip and brother mfc 7420. error code 2001 and 2006
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
Mfc 465cn has black line
Open the document feeder and clean the scanner glass.
Feb 12, 2009 | Brother MFC-465CN InkJet Printer
Brother 420 cn / 6 in 1 fax machine will not fax
Hello sir; I believe this problem belong to you phone comp, better contact with them.
Jan 07, 2009 | Brother MFC 420CN All-In-One InkJet...
Will not fax
how do i find my fax number on my mfc-440cn?
Sep 09, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MFC 3360C
Try turning off ECM (error correction mode or overseas mode). Try calling the fax # from a regular phone line - If you hear the fax shrill tones you know you've got the right #) I it does not go through, you should get an error code #. let me know what it is
May 02, 2007 | Brother MFC-3340CN All-In-One InkJet...
Brother MFC-465CN InkJet Printer Logo
1,637 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
