Question about Tomtom Go 910 (Europe, USA and Canada Pre-Loaded on Hard Disk) GPS Receiver
Hi, I`v changed new batery on my 910 and it wont charge it. The batery is flat. Cant start the divice, cant update it and pressing reset buton dont help. I will need it 4 days later so dont have time to send it anywhere for repair. dDo you know what else will help?
  • marian_ubran May 16, 2010
    hi, resoldering jacks did not help.
    what can i do with the charging circuit? do i need to change motherboard? if yes where can i get one? thank you
  • 2,427 Answers
It seems like your battery aint the issue,, it can be the charging circuit or the jack itself.. Mostly the jacks solder is broken off,, simply resolder it to the board
Posted on May 03, 2010
  • Rishi Roshan Ali May 16, 2010
    Yeah the charging circuit is part of the motherboard and to change it you do have to change the entire board..... Check the solder on the jack first... Tthe one the battery connects....
My phone is restarting after welcome screen. i cant update it cause i cant set the usb mode to pc suite and i cant restore settings. i tried nokia sotware updater, jaf nothing works they cant detect p
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 25, 2012 | Cell Phones
My tom tom go 910 gps does not turn on after being charged for over 2 hours. there is a green light when i push buton to urn on but nothing appears on screen
HAVE YOU TRIED HOLDING DOWN THE RESET BUTTON WITH A PIN FOR ABOUT 15 SECONDS OR SO. IT IS A TINY HOLE LOCATED WHERE THE CHARGER PLUGS INTO THE DEVICE.
Aug 15, 2010 | Tomtom GO 910 GPS Receiver
Failed update firmware, on router asus wl600g, when router is on de power led parapadea
try reset (press reset buton more than 5 sec, until all leds is off , and power led is red). release button . if power led is allways red, u dont have any firmware on router. and contact dlink to repair (dont say u update the firware, or they charge a new one).
Dec 26, 2009 | ASUS WL-600g Wireless Router
Pc gone dead while runing something now dont start no beep nothing but the fans reving to max i cant stoped from the start stop buton i must unplug, no video signal to monitor also, check everything ram...
well it sounds that u have downloaded somethin' which support a high load which ur PC doesn't support ( this program or game may harm ur PC ) cause it make it work more than its ability so u need to go to safe mode (by press and hold on Button F8 when start ur computer) then remove the latest software or game (which is too big as i thought) then try to restart ur PC if this not work u need to formate ur PC and install new windows but before u want to install any thing new (try to check the specification needed for this software or game - The minimum PC requirement then campare it with ur one it if it pass then install it otherwise don't install it.)
Jul 22, 2009 | Computers & Internet
Iphone wont charge/itunes logo appears
please rate me Fixya if i fixed ur problem these ratings help us !
Regards
Zohail
Apr 23, 2009 | Apple iPhone Smartphone
Imate jamin not turning on and not charging
I had the same problem with my Jamin so sent if off to the technician who informed me the Jarmin's internal circuitry prevents the phone being charged when the battery is under a certain voltage so when you use a plug in charger because the battery has very low power it does not trip a circuit in the Jamin to start the charging process. The only solution to to take the battery out of the unit and charge it with a stand-a-lone charger. Hope this makes sense.
Sep 13, 2008 | i-mate JAM Pocket PC
Doesn't start up
Hi, Based on your post/description, your iPaq 2210 will not power on. It is possible that your battery is deactivated. To reactivate, plug it to the AC power supply/adaptor, press reset at the back of the unit. Assuming no other problem, the unit will initialize back to default factory settings. It's very likely that all your previous/personal settings, files and applications will be also gone. Good luck and pls post back how things turn up. Kind regards.
Jul 21, 2007 | HP iPAQ H2210 Pocket PC
Tom tom 910
Try pressing the reset button, check your documentation for the location...but it's at the connection interface.
May 21, 2007 | Tomtom Go 910 (Europe, USA and Canada...
Batery problem?
The battery number is SNN5743A .
You can get it in various sites on the web.
Apr 09, 2007 | Motorola M500 MP3 Player
My phone just froze i cant press any button
Try taking the battery out and waiting for 30 seconds. The reinstall the batter. It that does not work, look behind the batter on the phone and see if there is a small reset button. You can reset the whole phone by pushing this button. You will loose all your information on the phone by pushing that button but it should work after that. If it works you need to go to a tech at your phone server and have them update your phone. Good luck.
Jul 30, 2006 | Motorola Mobility RAZR V3
GPS Logo
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
