I have a wall heater robus rh20-01,i put a towell over it and it stoped working what could it be
  • 674 Answers
It could be an overheat switch. Some reset automatically after the cool. Some must be reset manually and some must be replaced.
Posted on May 03, 2010
I have a small wall heater, towel rack included, the fan & timer work, but no heat. Where do we find the model number
Usually on a small sticker on the back near where the wire goes into it.
If you know the make you can Google it and look at the images tab like this for 'Dimplex bathroom fan heater'.
dimplex bathroom fan heaters Google Search
Jan 22, 2016 | Heating & Cooling
IT doesn't heat up any more so the towel does not get warm, do you know anything about towel warmers? do they have an element?
Many do have an electric heating element; there may be a light next to the switch which might indicate whether it is on or off. However some are heated by hot water or steam (it seems). You might consider changing the element, try the fuse in the circuit first, it might save you a lot of trouble. If you decide that are able to change the element yourself, get the instructions and only then source the part. If it's wall mounted it's more difficult. However it's probably best to get an electrician to do it as it can be very tricky. I may even be necessary to contact the manufacturer or buy a whole new item
I hope someone else comes up with a better answer !
19.January.2016
Jan 19, 2016 | Mr Steam W542 Heated Towel Warmer W542...
What is the switch for by the bathroom sink
The hot water tank heater?
The pump in the well?
The pump in the Jacuzzi bath?
The baseboard heater, wall heater, towel rail?
We just have to guess these things :>)
Jan 01, 2016 | Home
My heater stoped working while driving 2002 cerokee laredo blower works but no heat
Sounds like one of 3 things. It could be low on coolant/anitfreeze, could be the heater control valve not opening to let hot water into the heater core or it could be your heater core is stoped up.
Feb 11, 2011 | 2002 Jeep Grand Cherokee
The left bracket/brace is off the wall. There is one long screw in the back center. How is this put back together?
There should be a small screw in each of the arms that secure the towel bar to the wall mounts. You will need to loosen each of these to remove the towel bar from the wall and to release the mounting bracket which has pulled free. To repair you need to puchase a larger size moly plug, toggle mount or other suitable hardware to secure the mounting bracket to the sheetrock wall (should not have pulled free is screwed in to the stud). Once you secure the mounting bracket then you are able to re-install the towel bar by placing the arms over the mounting brackets and tightening the small screws on each arm of the towel bar.
Here are a couple of videos which should help you undesrtand how towel bars are installed. Hope this is helpful. (do not delete) utube.png Here is a couple of videos that should help understand how towel bars
Dec 19, 2010 | Moen 24 In. Towel Bar...
Heater stoped working on t5 03 model used to come
Clogged heater core, stuck closed heat valve, defective control head.
Get shop manual if your gonna attempt this repair and a good chiropractor.
Apr 06, 2010 | 1986 Volkswagen Wagon Camper
I am having a problem with a GE GSH22JSRE refrigerator. Serial Number ZH203908 Over 5 day period it started to get warmer and warmer until the freezer did not freeze and food spoiled. I read on line as...
do you have any frost on the wall of the freezer? and do you still have your old control board? if yes check in the back of the board if there are any burned connections black connections, and feel free to put your nose on it and smell for a burning smell i dont know how much will it smell now but that is the easiest way to check the board ge side by side fridges have the control board problem which you replaced and the defrost heater if you have a lot frost on the back freezer wall you need a new dual defrost heater if you dont check the new board you put in for burning  if thats ok too check your compressor if its really really hot if it is try cooling it down with some paper towels and cold water put about 5 so so wet towels on top of compressor and 5 on bottom and use a couple to wipe down the middle of the compressor
if you got any questoins feel free to ask  good luck
Jun 08, 2009 | GE GSH22JSRSS Stainless Steel Side by Side...
Fridge problem
you have a defrostion issue reed to remove the back panel in the freezer behind this panel is the evaperator coil needs to be melted down because it is full of ice and frost, ahair drier will work well,put several towells down under the bottom of the evaperator to catch water runoff, after defrosting the coil inspect the defrost heater or heaters some of these can have one or two heaters the heaters are located behind metal gaurds in the evaperator if either of the heaters are bad (both)need to be replaced, if they show good then bad defrost timer or bad defrost termination thermastat wiring diagram behind frount bottom grill
Apr 12, 2008 | Refrigerators
Dryer will not start. .
if you got proper voltage to the machine, and the door latch is closing next step is to ck thermos and heater. TURN OFF POWER, remove 2 5/16 screws from bottom panel and the heater plate is located on back wall left side. 2 5/16 screws also remove this assy from rear wall (makes it easier to troubleshoot), both thermos o that plate should have continuity, as well as the heater coil itself,any one not showing cont. is the problem(sometimes the wire itself just burns off the heater terminal itself.
Feb 27, 2008 | Amana DLE330RAW Electric Dryer
Heating & Cooling Logo
106 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
