Question about Troy Garden
Replace trimmer head on a troy bilt Trimmer/mower model number52029
4 Suggested Answers
  • 10865 Answers
SOURCE: Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
Posted on May 20, 2009
jyackle5
  • 8197 Answers
SOURCE: Cannot restring Troy-Bilt weed trimmer
On the directions below tells you how to restring the spool.
If you can not read it you can click on the link below to download the manual.
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=769-04481.pdf
If you have any questions please ask befor you rate.
Good Luck
Posted on Jun 27, 2010
SOURCE: Cannot disassemble Troy-bilt trimmer head
There is a round, rotary black part between the metal piece to which the cutting head attaches and the outer plastic seat of the cutting head. There are two square slots, each about a quarter inch wide, on opposites sides of the black piece. Slide an Allen wrench or something similar firmly into the slot. Holding the Allen wrench in a stable position, turn the outer plastic ring of the cutting head (it has scalloped edges that can be gripped firmly) counter clockwise to unscrew the cutting head from the bolt on which it is mounted. Be careful with the tool (e.g. Allen wrench) used to hold the black piece steady, as it is plastic and could be damaged by the edge of the tool.
Posted on May 04, 2011
How to put a new battery cable on my troy built weed eater model # tb22ec?
I don't think this item has a battery
Troy Bilt TB22EC 41ADT22C966 25cc 2 Cycle Curved Shaft Trimmer Parts
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/equipment/troybilt/TB22EC-trimmerTB22 EC Curved Shaft String Trimmer. 25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design Model No. 41CDZ22C766 .
Jul 31, 2017 | Troy Garden
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do I replace string trimmer string on 4cycle Troy bilt string ttrimmer
verify that you are using the proper diameter trimmer line, if you have the proper line, replace the head of the trimmer
Sep 14, 2014 | Troy Garden
Fixing straight shaft attachment on Troy-Bilt string trimmer
Here is a link to sears parts direct. You can see prices for all parts and make a decision from that.
TROYBILT Trimmer Boom and trimmer Parts Model TB75SS
Aug 16, 2014 | Troy-Bilt Tb75ss
I have a toy-bilt trimmer/mower misplaced the manual. cannot get the strings to stay in. thought i might be missing a bushing or the like for the string to grab hold of [between the metal plates]. wanted...
The manual and parts diagrams for many Troy-bilt products are available here: http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001 . You will need your model and serial numbers. http://troybilt.custhelp.com/app/answers/detail/a_id/253 gives the standard format for the model numbers. The model and serial numbers are given on a plaque on the trimmer/mower. The plaque is in a location that is unlikely to get damaged during use.
I hope this helps.
(I know where to look for this plaque on other Troy-bilt equipment but I'm not sure exactly where it is on the trimmer/mower.)
Jun 19, 2011 | Garden
My Troy-Bilt line trimmer model no. TB539E Line trimmer disintergrated while using it. My problem is finding and ordering replcement parts and if necessary how to install them.
Several small engine dealers have parts for Troy Bilt but here is one site that will give you your part numbers and an idea of the costs you are looking at. Good luck!
http://www.ereplacementparts.com/
Aug 17, 2010 | Troy Bilt 17 Inch 29 Cc Gas Powered...
My troy bilt tb70ss trimmer sounds like something is stripped the motor will wind out but the head wont move its only 1 1/2 years old
will need to check if any debris is wrapped around head jamming the head --or -flex shaft is jammed or damaged separate shaft from motor and will see in shaft the flex shaft that turns the head try turning head by hand and observe flex shaft if binding or broke need to lube or replace
Jun 28, 2010 | Troy Bilt Tb70ss Gas Trimmer
Line stuck inside head of troy-bilt trimmer
Take an awl or small diameter screw driver, same size or a bit smaller dia. than the line dia., and push it through the hole from the outside of the line head. This should push the piece of old line through the hole.
Recommendation: Leave at least one inch of line on the inside of the head, so you can grab it easily when you have to replace the line. I'll carry a pair of long nose pliers on me when I use my trimmer, so I can easily grab hold of the inside piece to pull it through.
Jun 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
May 07, 2009 | Troy -Bilt String Trimmer/Blower...
Garden Logo
161 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
