Question about Homedics SBM 300H Therapist Select Shiatsu Plus Massaging Cushion SBM300
Massager squeaks My Homedics back massager makes an awful squaking noise just after a few minutes of use. It's pratically brand new and has not been used much.I took it apart and used wd40 but that did not help. Thanks
  • 1 more comment
  • Harry Mole
    Harry Mole Dec 19, 2016
    zip the cover off and add a little talcum powder to the inside of the back pad.
  • Rick Yeager Feb 11, 2018
    Thank you!!! No more squeaking for now. Now if I could just get the covers it back on LOL
    Thank you!!! No more squeaking for now. Now if I could just get the cover zipped back on LOL
    New Friend:
Zip off the cover and add some talcum powder to the inside cover where the roller make contact with the cover.
Posted on Dec 19, 2016
SOURCE: homedics programmable percussion massager with heat
The motor is Jammed
Try Taping it or banging it lightly
if that don't work im sorry ether needs repair or buy a new one
Regards; Aaron
Posted on Sep 16, 2008
SOURCE: i have a homedics shaitsu back massager that stoped working
Hi.
Give it a good 'knock' on the back (hard surface). You might hear a clink sound. I think it's when a cog gets out of line. My chair is fine now. You'll notice that the rollers start moving back to the off setting. So if it goes off and they are in the middle or top then it's stuck and needs a thwack!
Posted on Dec 19, 2008
naniguju
  • 10 Answers
SOURCE: remote doesnot work
If you have not already, register your product with the company. And contact them regarding the malfunction. they should replace the part or the product if you send it in.
Posted on Jun 09, 2009
  • 5603 Answers
SOURCE: the SBM 200 Homedics massager makes a noise when
Look at the teeeth on the smaller gear that drives the thing up and down. They are easily stripped off.
Posted on Sep 08, 2009
SOURCE: I need a new power adaptor for the Homedics SBM
I have one you can purchase. Name your price. Email me at MicaylaDodson@hotmail.com if you are interested.
Posted on Dec 15, 2009
Hi yesterday i was using my homedics cushion . I had it set on shiatsu and i was controlling whereit went. I accidently pushed roller full...well it startd to go upwards and then started making clunki
mine did that and I tried turning it on and let it run through the cycles with no pressure on it. then it found its own track again and started working ok, but I am very careful with the controller now. Hope it helps.
Oct 13, 2017 | Homedics Quad Roller Massaging Cushion...
I'm having a problem with my Homedics SBM 300H Massager. I was using it when it suddenly stopped, after hearing a faint "pop" sound from it. I tried re-plugging it in another outlet but still no...
Yes there was a short circuit and am sure the massager and the cpomputer where plugged in the sane extension box that was why there was loss of power when the massager stopped working.For the massager it is the fuse so get a new fuse for it.
Jan 21, 2011 | Homedics SBM 300H Therapist Select Shiatsu...
Hi, I have got brand new Homedics shistsu massager cushion (MCS-360H). When I am plugging it in, I can see that power button in the remote is not getting started. Can you please assist me with this...
Hopefully you've got the right model listed here, as the MCS-360H is a Swedish Massage Cushion.
Did you remove the screw from the back of the unit before plugging it in...? The unit will not work properly until that screw is removed, and could be damaged if it is operated with the screw in place.
Here's the manual -
http://www.homedics.com//media/documents/homedics/instructionbooks/MCS-360H_IB.pdf
If removing that screw does not make the unit operate properly, contact Homedics Customer Service at 1-800-466-3342
Oct 02, 2017 | Homedics Shiatsu Massager
Can Homedics Therapist Select? Shiatsu Pillow with Heat be used under 220 V power? Thanks
If it is set up for 110 volts, you should not use it on 220. Most likely you will burn the motor out in a matter of minutes.
Jan 24, 2010 | Homedics PA-4H Programmable Percussion...
Remote doesnot work
Jun 09, 2009 | Homedics Qrm 400h Therapist Select Quad...
Ilectrical problem
If I only used it for 10 min. and it stopped working? I would quickly throw it back in the box and find a store that sells them and demand a replacement. Or just buy the same exact model and then return the broken one to the store with the same reciept.
Jan 01, 2009 | Homedics SBM 300H Therapist Select Shiatsu...
Homedics programmable percussion massager with heat
The motor is Jammed
Regards; Aaron
Sep 15, 2008 | Homedics 10 Motor Back Massager with Heat
Homedics SBM 300H Therapist Select Shiatsu Plus Massaging Cushion SBM300 Logo
867 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
