Question about Wolfgang Puck Bistro 1700 Deep Fryer
Error message When I plug the deep fryer in, an err message is displayed and the machine starts beeping.
  • 1 more comment
  • Anonymous May 25, 2008
    Same as others , I have no solution.
  • Anonymous Nov 11, 2008
    I have the same problem with the same type of fryer.
  • Anonymous Nov 28, 2008
    so do I !
I don't know if this is the true answer or just works with ours, but if I hold the on button (for heating) and the program button together in a couple seconds it stops blinking and resets to the temperature mode. When that hasn't worked, it's also worked to hit the rest button in the back first and hold for a couple seconds and then hit the two buttons mentioned above together. However, each time I get the ERR message it gets harder and harder to reset. I would love for someone else to respond for the actual "fix" for this as it's looking to be the actual computer part of the thermastat to us and I'm wondering if it's worth fixing or shopping for a new fryer is needed for price. But, this has gotten us through for now to be able to fry again.
Posted on Mar 11, 2010
Came up with err
I'm having the same problem, some times it will work perfect but tonight worked fine for 16/17 mins then just kept beeping and displaying error
Oct 07, 2013 | Tefal ActiFry Deep Fryer
I have a tefal family actifry and a green error flashed up and a long alarm. What is this telling me?
Tefal Actifry GH800215 user manuals GH800215
www.tefal.com/instructions.../Fryer/Actifry/Actifry.../1500634805
TefalThe Actifry Plus GH800015, GH800215 deep fryer allows you to make 1.2 kg of chips with only 1 ... To display Instructions & Manual, choose your language :.
Apr 13, 2013 | Tefal ActiFry Deep Fryer
It keeps beeping and saying help
check the ignition system.controller will display help when burners do not respond during heat start-up or heat demands.also check if the unit receives sufficient fuel for ignition.
Mar 29, 2011 | Frymaster Dean FPH55-2 Deep Fryer
Light comes on, but it no longer heats up.
I have a similar model of DeLonghi fryer, and I have read that many customers have problems with their fryers not heating, after owning and using them regularly for some time. Mine gives an error message and stops heating, once in a while. The lights remain on, but it displays an error message on the temperature readout. I've found that detaching the magnetic safety cord and thoroughly cleaning both the cord and the connections on the back of the machine makes a big difference. Your mileage may vary.
Mar 04, 2011 | DeLonghi D14522DZ Deep Fryer
Getting error reading on display. How do I fix this issue so I can make my wings today?
I have the deep fryer, which I have had a few years and got it out last night and I'm getting an error message. There is nothing about what to do about this in the trouble shooting guide. We made sure the control panel was in and after that have no idea how to solve this problem. Ann Lytle
Dec 19, 2010 | Wolfgang Puck Bistro 1700 Deep Fryer
I took the fryer out of storage. Got little response from unit
All element units are pretty simple,and you can think of them, as Heater Element, with a switch, in the Phase, that's Opened/Closed via a Thermostat, (& a sensor for said thermostat), and thus the Power is connected to the element. As such, it is easy to troubleshoot, you need a Multimeter, Using OHMS, Or Continuity test, simply trace out the circuit, from, plug, to element, along the Phase, Black, wire, USA, to the Element, the "Other" side of the Element is simply connected to return, or neutral. Also there is a "Thermal" fuse, that is there to protect, that too may have faulted, all fuses should be short circuit.
May 01, 2010 | Presto 05460 ProFry Deep Fryer
Unit will not start no light no nothing
comes on at 200 degrees. States err. beeps continualy. will not start.
Nov 27, 2008 | Masterbuilt 20010306 Deep Fryer
Delonghi fryer
I broke the plastic mount that holds the controls against the outside of the frame. That plastic mount was depressing a switch that is no longer being depressed. I get an Error message too. I'm going to try to contact the manufacturer to see if I can get a replacement part. (I doubt I can because the model is discontinued).
Aug 02, 2008 | DeLonghi D14527DZ Dual Zone Deep Fryer
Kitchen Appliances - Others Logo
387 people viewed this question
Top Wolfgang Puck Kitchen Appliances - Others Experts
Steve
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Wolfgang Puck Kitchen Appliances - Other Expert? Answer questions, earn points and help others
