Question about HP Office Equipment & Supplies
I have a HP DesignJet 60'' wideformat printer. its a UV or DYE stsyem. I want to install the Dye from UV. Whats the procedure and is there a chip i have to swap, please help.
  • yan dikshteyn May 03, 2010
    Hey yes it helps but the movies dont run and the instructions dont follow through, I ALSO THINK THERE IS A CHIP THAT NEEDS TO BE SWAPPED OUT??Is this procedure in the service or operation manual for this manual ??
    Thanks for your help
  • yan dikshteyn May 04, 2010
    thanks alot you really helped me out
  • HP Master
  • 19,396 Answers
Hi.
Here the manual for Photosmart 60, this is for the 5000, procedure is the same on the 5500 and on other plotters of 5x series.
Click on the Tab :Media and Ink
Choose The Ink System at the top
Click Changing Ink Types.
Follow the instructions on manual.
Regards.
Posted on May 03, 2010
  • Ginko
    Ginko May 03, 2010
    Hi.
    If you buy a kit like the C6093A , the smart chip should be embedded in the HP dye ink cartridges.
    You can buy a kit from HP. Ensure that you buy the right kit for your model. The one above fits 60'' 5000 5000PS 5500 5500PS.
    Here the HP upgrade page.
    Here a third party distributor:C6093A
Low coolant. Coolant leaking somewhere
There is a UV dye you add to the radiator this will tell you where the leak is. You add it to the radiator drive vehicle for a day or so. You will need a kit contains a UV flashlight and a pair of UV glasses can be purchased at autozone for around 15 dollars. The dye cost around 10 dollars. Simply shine light around hoses, radiator and all connections the leak will show up yellow. Very easy to do I do it all the time.
Jul 02, 2016 | Cars & Trucks
Yellow printhead on my Designjet 3500CP isn't releasing ink
If you can access the printhead, try taking a rag with a small area heavily wet with Denatured Alcohol (this is a cleaning solution that can be purchased at Walmart or most stores with cleaning supplies. Rub the printhead thoroughly with the alcohol for a minute or two, it should help loosen any dried ink. Then try to print or run a print head clean cycle on the printer.
Nov 03, 2017 | HP Designjet CP UV Yellow Ink System...
I have a Designjet 5500ps Printer and it is leaking blue ink, when printing, all my research indicates that I need to replace the carriage tube connector, but I am unable to find the replacement part.
Hi there
May be you can try to contact any Authorised HP Service centre for your probelm. Could you give me your correct location so i can tell you whome to contact?
Alternatively you can try to see where the leakage is taking place and try to seal it with silicon sealent so it can atleast last untill someone attends to the probelm from HP.
The technical term for it is INK TUBE ASSY. But make sure and tell the HP people about the size of the plotter that is 42" or 60" and also keep the Product Number and Sl. No. of the machine handy which is required by HP technical team. (You can find it at the back of the plotter)
Click here to find all the spares for your plotter.
Aug 24, 2011 | HP DesignJet 5500PS InkJet Printer
After converting our 60" HP
Have you tried to revert back to the dye inks?
If that solves the problem, then your UV ink tubes have a bad control board.
(you did change the ink tubes system, printheads and ink ?)
If the error code continues, replace the Main PCA.
Jul 19, 2011 | HP DesignJet 5500PS InkJet Printer
Can't find the A/C leak on my 96 honda accord. Pro mechanic used dye and can't find it.
You need to use a UV light to see the dye. The most common leak I have run into are in the condensors. If you still can not see the dye with a uv light suspect a leaky evaporator core.
Jun 07, 2010 | 1996 Honda Accord
Why does my hp c309 Photosmart Premium printer require two black ink cartridges? Can I use just one?
The Photo Black is pigment ink (last much longer than dye ink), while the Black is dye ink. Have alook here: http://www.earthboundlight.com/phototips/dye-pigment-metamerism.html for detail explanation
May 13, 2010 | HP Photosmart Premium C309A All-In-One...
I thought it was the water pump that was leaking and needed replaced, but it not. We can see where it is collecting but not where it is organting from. Can you tell me what you think
check out the housing for the thermostat...check out the heater hoses where one connects to the thermostat housing, the other to the waterpump....just replaced one on a honda that was pin hole sized and nearly impossible to see....also check headgasket and intake manifold gaskets...good luck
Mar 22, 2010 | 2004 Ford Explorer
We have three Hp Designjet 5500 printers in the county.
Dye inks will fade in the light.
You need to convert it to UV Pigmentinks
Then they wont fade
Apr 29, 2009 | HP DesignJet 5500PS InkJet Printer
29 people viewed this question
Seeker5211
Seeker5211
