Question about Peg Perego Santa Fe Express Ride On Train
I cant get the horn to work - Peg Perego Santa Fe Express Ride On Train
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Replace the aaa batteries under the smoke stack
Posted on May 22, 2012
Horn stopped
Check wiring connecters to the horn Check fuse. Or even better purchase another horn if above is fine. A good way of checking is remove the connection to the horn and place a tester onto the wires and press the horn inside. If there is signal to the horn then replace the horn.
Aug 13, 2013 | 2002 Land Rover Freelander
The horn on my 06 golf does not work
I would check the horn relay and for power at the horn pad. The pad grounds the relay to make the horn blow.
Sep 03, 2012 | 2006 Volkswagen Golf 1.6
Cant find out why my horn doesnt work
You would need to test the system with a light or a meter.
Of course check the fuse first.
A mechanic would check for voltage at the horn then work back to the steering wheel.
There is a relay in the circuit.
Jun 30, 2012 | 1998 Pontiac Grand Prix
Horn not working on toyota verso mpv fuse ok can here a click when pressing horn cant locate horn on engine
last time i looked horn was on the lower front cross panel under the radiator.....BUT has been known to be above rather than under.....
Sep 16, 2010 | 2006 Toyota Corolla
Cant find the horn truck had work done on front so i think they didnt put horn back.how can i rig a horn up cant find wires for it
put a switch under dash for horn. run a wire from horn to right side of switch,oyher side run a wire to battery or a good 12v source. now horn should work by a push button.
Jul 30, 2010 | 1998 Ford Explorer
Horn doesnt work, cant find horn relay , 94 scoupe,
horn is behind the bumper ,get assistant to hold horn on and clout it with a small hammer if it still doesnt work then renew it
Apr 08, 2010 | Hyundai Motor 1994 Scoupe
No horn
Apply 12 Volts DC directly to the horn to determine if it is good. If it is then look for a wiring problem. If you find none, suspect a problem with the horn switch in the steering wheel.
Aug 02, 2009 | 1994 Mitsubishi Mighty Max
Horn not working cant find fuse
The horn fuse is in the under hood fuse box. It is a 20 amp fuse. Good Luck
May 28, 2009 | 1998 GMC Sierra
Replaced relays and ckecked fuses horn not working 1996explorer
with the horn you can run a wire from the battery to the horn to check it if that dosent work then it is probably the contact wire inside the steering column, I cant remember the name of the part but this should fix the horn and cruise problem.
Nov 22, 2008 | 1996 Ford Explorer
Peg Perego Santa Fe Express Ride On Train Logo
65 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
