Question about KEF Audio PSW 1000 Subwoofer
Im having trouble with connections from kef psw 1000 sub to onkyo tx sr506 amp. sub is making a bit of a humming noise but not getting any proper sound through. dont know what im doing wrong. can anyone help please
    Brigadier General:
  • 8,546 Answers
Have you got the sub defined to the Onkyo correctly? Try conencting the sub's input to one of the Tape Out connectors and play some FM through it. That will prove if the sub is alive. The nwe can troubleshoot the correct failing device.
Posted on May 03, 2010
I have a sony str-de475 and a kef PSW1000, i have the line in the left on the sub connected to the sub out on the amp, and the sub powers up, but im getting absolutly nothing from the amp and now all of a...
It's not clear if this has EVER worked or what is new in the scenario. The STR manual has setup instructions for supporting a sub. If you want to prove the sub itself works you could jack any source like, say, a CD player, into it to prove its amp will respond BUT IT WILL BE LOUD if it works.
Oct 05, 2011 | KEF Audio PSW 1000 Subwoofer
Should i use an amplifier with the txsr506. i dont know if im doing anything right with the receiver. i feel like its two low on volume
It HAS amplifiers. You don't daisy-chain amps.
Get the manual and take some of the gueswork out of the process. Set it up and come back with specific questions.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR506-Receivers-manual/id/13748ci477/t/2/
Jul 05, 2011 | Onkyo TX-SR506 Receiver
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
HUM noise at PSW3000 if i connect the Yamaha RX-V995
the conections some where are dirty you need to unplug everything clean all connections and the hum will go away
Nov 06, 2009 | KEF Audio PSW 3000 Subwoofer
Is there an incompatibility between Onkyo 606 and KEF Wireless?
This is cycle hum place offending units away from each other or, isolate the power supplies and, re- check electrical circuit grounds
Jun 01, 2009 | Onkyo TX-SR606 Receiver
I just bought a KEF PSW2500 subwoofer and am trying to connect it to a Yamaha v663 receiver. However, I went from a subwoofer pre-out 1 to the right line in on the sub. I don't hear any sounds from the...
HI,go into the yam setup menu and make sure you have the sub turned on and cross over set to about 80hrtz if this suits your speakers,set sub level to about -5 on amp and say half way on the sub,this should work if not pull out sub cable at amp and touch the end,you should get a hum,if not you may have no power,faulty cable or sub.
PS>make sure you are pluged into the sub PRE OUT and NOT the six channel in.
Hope this helps.
CABLE GUY.
Apr 19, 2009 | KEF Audio PSW 2500 Subwoofer
Sorry this is not a solution.
I am having virtually the same problem and I wanted to find out if you managed to fix the issue?
It seems to be my LCD causing the static noise (even when it is powered down). The static noise goes away when I physically unplug the TV or disconnect the HDMI cable to the amp.
Mark
Mar 23, 2009 | Onkyo TX-SR606 Receiver
Buzzing/vibration noise from ONYKO TX-SR506 unit
If the unit is under warranty, DO NOT open it up. Bring it in for an exchange or warranty service. Explain that the unit makes noise during use and it will be serviced. This could be as simple as a bad connection in the power supply area and you are hearing oscillations or it could be a defective power transformer. Either case will be covered under warranty so there should be no charge to you.
Keep us posted.
Dan
Feb 17, 2009 | Onkyo TX-SR506 Receiver
No Signal on sub preout on my Onkyo TX-SR703 AVR
Well the next step would be to make sure that all the settings are set to subwoofer yes, and set your crossover as well.  The amp usually has a crossover which tells the microprocessor which frequencys to send to the sub.
Jan 06, 2009 | Onkyo TX-SR703 Receiver
Weird burbling muffled squeak noise!
you can simply and easily replace 3 capacitors on the main amplifier board (c58 - 47uF 63v or 100v) + (c52 & c53 - 220uF 25v) but stand them away from the board on the length of the capacitor leads to prevent them from absorbing heat from surrounding hot components (with heat shrink tubing to prevent shorting)
these are usually the cause of most problems with KEF PSW subs, as for it sounding wooly, this is just the way it is, mine is the same.
Dec 10, 2006 | KEF Audio PSW 1000 Subwoofer
KEF Audio PSW 1000 Subwoofer Logo
348 people viewed this question
Top KEF Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Greg Cann
Greg Cann
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
