Have a Toshiba sdp-2900 that returns the error no valid disc when a dvd is inserted. Any ideas? Thanks, Tom
  • tkuhar Mar 26, 2008
    Have tried multiple dvds, tried cleaning drive, and double checked seating on the hub, still no luck.
  • tkuhar Mar 28, 2008
    I have tried cleaning the drive, several known working dvds, seating the dvd correctly on the hub. I still get the NO VALID DISC error.
    Genius:
  • 3,422 Answers
HI,
The first thing i would suggest you to do is a hard reset by unpluging the the player for 30min and then try again.
If this does not solve your problem then please see if the player tries to read the disc.
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image below.
If the problem still persists then you will have to get it repaired and thats the only solution to fix the problem.
Goodluck,
Please don't forget to rate the solution
Posted on Mar 28, 2008
  • 818 Answers
Change your drive, can be the laser break.
Sergio
  • 3,037 Answers
You could try cleaning the drive with a DVD cleaner
Have you tried multiple dvds?
Posted on Mar 26, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Mar 26, 2008
    It might have been caused by a disc that is not seated correctly in the player
    because possibly 1 of the 3 clips on the center hub has not "clicked" fully.
  • Benjamin Patri
    let me know how these solutions work out and please feel free to post any other question that you may have
  • Benjamin Patri
    Benjamin Patri Mar 28, 2008
    Toshiba has had this same problem in many of there DVD players, you can try and have it fixed but the problem usually keeps occurring. Your best bet is just buy a new DVD player.
    Good luck with this. Before buying one, find out the reviews that it has had.
SOURCE:
No valid disc toshiba SD P75S
either it is not a valid disc or a problem with the optical pickup in the unit, all discs give this error?/
Apr 07, 2012 | Toshiba Televison & Video
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
SD-P1900SN After inserting movie DVD, I get message, "No Valid Disc". I ensure disc is inserted properly. Bought player a couple of years ago. Have only used it 3 times. Can't find anything in manual...
Check for cracks or scratches on the dvd disc?It a dvd movie disc,not a computer program dvd disc?Take the dvd disc,washes it with some dish washing soap.To clean all the grims and grease out of the dvd disc laser surface to the dvd player laser eye to read the dvd disc.
Jun 17, 2010 | Toshiba SD-P1900 Portable DVD Player
"No disc" error
This means that the lens of your dvd player is having a hard time reading the discs. It could be dirty. You need to run a disc cleaner to run into your player for like 30 seconds. It it does not solve the problem. You might need to clean the lens manually. Open the casing and unscrew the plastice plate covering the lens. Then get a q tip damped in an alcohol. Gently wipe on the lens' surface and let it dry. Return everything back and play those discs again.
Feb 13, 2010 | Daewoo DVG-8500N DVD Player
No valid disc error
these built in tv/dvd players have this problem the laser inside tends to burn out. being unable to read discs. it may be dirty and you can try to clean it with a laser disc cleaner or by blowing the dust out with compressed air . but more than likley the laser is damged and you will have to go into a repair shop.
Apr 26, 2009 | Televison & Video
Toshiba SD-K770 DVD player flashes error and BAD DISC
hi... the problem might be in ur dvd... If ur dvd is perfect and u found that ur player has some problem means the best solution is that to clean up ur dvd player lense which plays a vital role in reading ur dvd when u insert into it...For cleaning up ur lense all u need is a lense cleaner dvd available in electronic shops.. u can purchase it and play that dvd as normal one.. ur problem will get solved..
thank u rate me!!!
Feb 07, 2009 | Toshiba SD-3980 DVD Player
No Valid Disc - Toshiba SD-P1900
Yep sone of a gun ! With the Toshiba Portable DVD Player, hold the "Mode button" down for several seconds and it will make a chain saw noise take your finger off, hit it again once and bingo now it works. I was ready to throw this player in the trash!
Jan 17, 2008 | Toshiba SD-P1900 Portable DVD Player
Shinco SDP-1731A 7" dvd player
How about cleaning using compressed air( it looks like an aerosol paint can)? Cleaning using cotton buds will only clean the outer side of lens, compressed air in can will clean the inner side of the lens. its like cleaning you computer keyboard, ( actually compressed air in can are used to clean the keyboards). A 30psi pressure of clean air is enough to wipe the dirt out of dvd lenses.
Aug 23, 2007 | Shinco Initial Technology Portable DVD...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Ekse
