I live out in the country 1 mile from town and I got a wireless-g 2.4 ghz Linksys usb network setup adapter. how do I make it work?
    Problem Solver:
  • 16 Answers
Do you have internet access? dial-up, DSL or Cable? or is this a LAN only? What operating system? XP, Linux, Vista?
The software CD that comes with it is installed first, then you are asked to insert the USB NIC. That will make it 'work", but there must be a wireless network in range to connect. Do you have a wireless access point? One mile is too far for you to access any free WAPs in town, like Starbucks or something. If it is a laptop, I suggest a ride into town to test it out.
Posted on Mar 26, 2008
SOURCE:
I don't have my user name and password for my wireless network and need it to connect a wireless printer
If you have the CD that comes with the adapter then you can try uninstall Linksys software and install only the drivers of the adapter.
Remove the Linksys Adapter and un-install the Linksys Software from Programs menu. To re-install the Drivers insert the Linksys Setup CD into your CD-ROM drive. When the Welcome screen appears click Exit. Connect your USB adapter to the computer. When the Found new Hardware Wizard window appears, click Install the software automatically (Recommended) then click Next. Click Finish when the installation is complete.Try to connect to the wireless network again. See if that works. You can also download the latest drivers from Linksys website on any other computer. Save it on a Flash drive and transfer the drivers on your computer.
Oct 10, 2011 | Linksys 2.4 GHz 802.11b Wireless - B...
I bought AE1000 wireless N USB adapter, and i cant get it to install, says "wireless adapter setup requires that wireless connections are managed by Microsoft windows, says to try the following,...
When you insert the setup disk on your computer, you can exit from the setup and then connect the adapter to the computer and a new window will popup "Found New Hardware Wizzard" and in that select the option "Install the drivers Automatically" and click on next, so it will automatically search for the drivers and install it on your computer... Once the drivers are installed on your computer then you can try to connect to your wireless network.
Setup
The Linksys AE1000 Wireless USB Adapter helps you connect your computer to a wireless network for quick Internet access. Installing the Linksys AE1000 is fairly easy. Just follow the steps below in setting up the Linksys AE1000 on your computer or laptop.
Minimum system requirements
- A computer with 1 GHz or faster processor.
- 512MB or more RAM.
- An available USB port.
NOTE: The Linksys AE1000 is supported for Windows 7, Vista SP1 and XP SP3 but NOT for Mac.
Step 1:
Insert the Setup CD into your CD-ROM drive.
Step 2:
Click Set up your Linksys Adapter. Proceed to Step 4.
If you do not see this, click Start on your computer and click Computer. Double-click on your CD-ROM drive. Continue to Step 3.
NOTE: For Windows XP, the file may be known as Setup.exe.
Step 3:
Read the License Agreement and click Next.
Step 4:
Insert the Wireless USB Adapter into a USB port on your computer or laptop.
Alternatively, you can also use the USB Extension Base to connect the Wireless USB Adapter. Plug the Wireless USB Adapter into the USB Extension Base and connect the Base to a USB port on your computer or laptop.
Step 5:
If you have an Easy Setup key, select Yes, I have an Easy Setup Key and click Next. Proceed to Step 8.
Otherwise, select No, I don't have an Easy Setup Key and click Next. Proceed to Step 6.
NOTE: For more information on Easy Setup Key, click here.
Step 6:
Select your wireless network and click Next.
Step 7:
If prompted, enter the wireless password for your network. Proceed to Step 10.
Step 8:
Follow the on-screen instructions. Click Next once you have completed the on-screen instructions.
Step 9:
The installation is complete when you see the screen below. Click OK.
Step 10:
You are directed to the Cisco Connect screen. Click Close to exit.
Nov 04, 2010 | Linksys AE1000 IEEE 80211abg IEEE80211n...
Having trouble with initial connection to an existing wireless network wireless router is a cisco wireless-n broadband router and we have 2 laptops and a printer on a wirelss network already
Follow these instructions to connect to a wireless network using the Linksys Wireless Manager.
Step 1:
Launch the Linksys Wireless Manager. To learn how to access the Linksys Wireless Manager, click here.
Step 2:
In the Connect to a Wireless Network screen, locate the name of your wireless network in the list.
NOTE: If your wireless network is not in the list, click here to learn How to Connect to a Hidden Wireless Network. If your wireless network supports Wi-Fi Protected Setup kb17673-005_en.png, click here to learn How to Connect Using Wi-Fi Protected Setup.
Step 3:
Select your network. Then click Connect.
Nov 01, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
I am using a Linksys Wireless-G 2.4 GHz wireless device and keep getting the error message: "Linksys Wireless-G USB Wireless Network MonitorWLAN.ini can't found" popping up every 20 seconds or so. The...
Its a system error(wlan.INI).Better you can download that file and save it in c:program files\linksys wireless(if any)
otherwise wireless related folder in C drive
Dec 19, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
I have a 2wire 802.11g usb wireless adapter. I
yes it would you just need to place the 2wire on a bridge mode then configure the linksys
Nov 22, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Will a wireless ethernet adapter (USB WIRELESS 54 G NETWORK ETHERNET ADAPTER 54G G WiFi) work with my wireless Linksys 2.4 Ghz router? And also it will be connected to an old Gateway 700mhz Windows 98se...
The OS would be the only problem. You would have to make sure the computer had USB 2.0 ports and that the OEM of the network adapter has a driver for Windows 98.
Without the driver it won't work at all, without the USB 2.0 ports it might work but it won't perform nearly as well as it could.
Sep 26, 2009 | Computers & Internet
Vista computer will not boot 1 out of 3 times with linksys usb
Power off the computer.
Power on the system and as soon as you see the Dell logo please tap the F2 button 3 - 4 times.
You'll reach the system setup screen. Look for an option for BOOT. Disabled Boot form network and BOOT from USB. Save and exit from the system setup. This should do the trick.
Jul 30, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Setup problem
lost my set up disk so would not connect linksys wireless b 2.4 ghz 802.11b usb network adaptor
need to dwnload disk drive for linksys wireless b 2.4 ghz 802.11b usb network adaptor
Sep 08, 2008 | Linksys Wireless-G WUSB54GS 802.11g/b
Open Questions:
VIPRE tech suPPort Phone numBer %%--18OO8-031-069---%%jkjkvs VIPRE Tech support Number +1-8OO803-1069 to resolve all VIPRE products. VIPRE is an American multinational company which was founded by Michael VIPRE using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, VIPRE support number, and selling of computer-related services and products. VIPRE Tech support Phone Number Recently, VIPRE has been named the number VIPRE customernical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, VIPRE customer care number can be dialed to contact the certified customernicians Contact Customernical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a VIPRE Service Tag or a VIPRE Get VIPRE Customernical Support Phone Number and Customer Services. VIPRE is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization supports, repairs, sells, and develops customernology products. Basically, the company offers computer related products and services VIPRE Tech support Number +1-8OO803-1069 to resolve all VIPRE products. VIPRE Tech support Number +1-8OO803-1069 to resolve all VIPRE products. VIPRE Tech support Number +1-8OO803-1069 to resolve all VIPRE products. VIPRE Tech support Number +1-8OO803-1069 to resolve all VIPRE products.
Oct 14, 2019 | The Computers & Internet
Computers & Internet Logo
46 people viewed this question
Ekse
Alun Cox
