Question about EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express
The 945GCT-M/1333 stats the it is compatible with 2 gb Kingston KVR667D2n5/2g memory modules on one page but on another it states that total memory capacity is 2GB which one should I believe will this board go to 4 GB if these Kingston modules are used ?
    Guru:
  • 1,705 Answers
Its supports a max of 4gb, 2gb per slot but, don't take my word for it go to this url:-
http://www.crucial.com/uk/store/drammemory.aspx
And check it out for yourself for free.
Posted on May 03, 2010
Asus motherboard p7h55-mlx has 2gb 1333 dd3 memory i tried putting in 2 pieces kingmax 4gb 1333 ddr3 memory now will not boot hangs on startup options screen?
Be sure the memory modules you installed meet this spec:
2 x DIMM, Max. 8 GB, DDR3 1333/1066 Non-ECC,Un-buffered.
Check the buffering and error correction architecture on the modules you installed. They may not be compatible.
Oct 15, 2014 | ASUS Computers & Internet
Ram supported for z580/5 5933347 lenovo
The Ideapad z580 series takes DDR3 SODIMMs, either PC3-8500 (1066 MHz) or PC3-10600 (1333 MHZ)
It can go to 4 GB (2 x 2 GB SODIMMs) in 32 bit or 8 GB (2 x 4GB SODIMMs) with a 64 bit OS. Here is the Kingston page, although they have discontinued these models Memory Discontinued Models
Jun 27, 2014 | Computers & Internet
No display, no beep ecs 945gct-m2 motherboard
Try another memory brand! Maybe memory you have in there not compatible. Have you tried testing your video card make sure it's not a bad video card?
Feb 17, 2014 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Ram enquiry
Kingston has a memory finder. You enter the details of you computer and the site brings up the memory modules that are compatible with your computer. Here is the address of the page.
http://www.kingston.com/us/memory/system_specific/desktop_notebook?gclid=CKu5qsv-gLsCFQpgMgod0nYAkw
Nov 25, 2013 | MSI Computers & Internet
Does the Intel MB DG41TX work with the Intel 7300 processor and a single 4GB memory module (Kingston KVR1333D3N9/4G)?
maximum memory for this motherboard 4 GB not sure about a single 4GB module
Max Supported Memory 4 GB
  • Supported RAM Technology DDR3 SDRAM
  • Supported RAM Integrity Check Non-ECC
  • Two 240-pin DDR3 SDRAM Dual Inline Memory Module (DIMM) sockets
  • Support for DDR3 1333(OC)/1066/800 MHz DIMMs
  • Support for up to 4 GB? of system memory
  • hope this helps
  • Sep 03, 2011 | Intel DG41TX Motherboard
    Hi. My new H61iCafe board should be able to recognize 16 GB (4 memory slots). I have bought 2 8-GB-Kits (each consisting of 2x4GB): Kingston KVR1333D3N9K2/8G After inserting 2 modules, 8 GB are...
    Number of Memory Slots: 4-240pin
    Note:
    1. Before you install memory module on this motherboard, please read below message to avoid any improper installation: - Due to chipset limitation, if you plan to install three or four memory modules on this motherboard, please install only single-sided memory modules.To install two memory modules on this motherboard, please install them on DDR3_A1 and DDR3_B1 DIMM sockets.
    2. For the detailed installation information, please refer to the user manual or quick installation guide. - Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows 32-bit OS. For Windows 64-bit OS with 64-bit CPU, there is no such limitation.
    Memory Standard: DDR3 1333/1066
    Aug 12, 2011 | Asrock H61ICAFE LGA 1155 Intel H61 HDMI...
    Installed additional RAM on HP P6531p desktop, computer freezes on start-up. Using Kingston DDR3 SDRAM DIMM PC3 10600 @ 1333mHz 2GB. Computer starts and runs fine with 2 sticks installed, but freezes with...
    You may have tried to put too much memory (RAM) onto it.
    That models maximum spec is:
    Memory upgrade information:
    • Four DDR3 DIMM (240-pin) sockets
    • Supports 1 GB, 2 GB, and 4 GB DDR3 DIMMs per socket
    • Supports Dual channel memory architecture
    • Supported speeds
      • PC3-10600 @ 1333 MHz*
      • PC3-8500 @ 1066 MHz
        *DDR3-1333 modules run at 1066 MHz if three or more modules are installed.
    • Non-ECC memory only, unbuffered
    • Supports up to 16 GB on 64-bit PCs (DIMMs run at DDR3-1066)
    • Supports up to 4 GB on 32-bit PCs
    You can find the specs and troubleshooting help files here
    Jul 20, 2011 | HEWLETT-PACKARD Pavilion p6531p-b...
    I have gigabyte motherboard H57M-USB3 with Inter core i5-760 processor and kingston k24-7070 1333Mhz memory card which is not working. are they compatible? what can i do to make it work?
    It should be, it says this about your memory support.
  • 4 x 1.5V DDR3 DIMM sockets supporting up to 16 GB of system memory
  • DDR3 2200+/1800/1600/1333/1066/800 MHz
  • Here is a list of compatible memory for that motherboard
    http://memoryselector.cnetchannel.com/tigerdirect/results.asp?hvhBlBE0fe0AED
    Aug 31, 2010 | Gigabyte GAH57MUSB3 Motherboard
    I'm Confused about Dual-Channel, How to Activate/Enable it?
    Check your user manual for the type of memory you can use. If your computer could use dual channel memory, I think it would come that way. Dual Channel is a pair of special compatable memory modules and only come in pairs. To buy two unpaired memory modules and hope to run them as Dual Channel is wishing too much. If they work, you're lucky, but most likely they will not work as dual channel.
    If you are using those two different memory modules and they both work for a total of 3 GB then you can not do much better.
    How many memory slots are in your Asus G1 notebook?
    Jun 14, 2009 | ASUS G1 Notebook
    ¿Could it work with 2 Cards RAM of 1G/800? ¿Could PC work with this mother board and 2 Cards RAM of 1G/800?
    That's a pretty big jumb from 667 to 800MHz. (Motherboard does not support 800MHz).
    Manual says:
    This motherboard accommodates two memory modules. It can support two 240-pin
    DDR2 667/533/400. The total memory capacity is 2 GB.
    Yet, ECS web site says it supports up to 4 GB.
    http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=830&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
    BIOS for 945GCT-M/1333 (PCB:3.x) version 08/07/18 does not include information pertaining to increased memory speed up to 800MHz. (Bios link).
    http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=830&CategoryID=1&DetailName=Bios&MenuID=44&LanID=0
    Mike
    Nov 17, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
    EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express Logo
    315 people viewed this question
    Top EliteGroup Computers & Internet Experts
    David
    David
    Matthew Spark
    Matthew Spark
    Jerry Umali
    Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
