Laptop XP PRO will not load up.
Starts loading up but the desk top does not appear
Instead an error message, giving you options of starting in safe mode, normal start up and another option.
I've tried all but nothing is corrected
  • anforte May 03, 2010
    I have tried starting in safe mode, restoring system to a previous date.
    These options do nothing and the screen shows the same options again.
    Surprisingly, it will load up an older XP Pro from the cd. I will not let it do this.
  • Jose Cada
    Jose Cada May 11, 2010
    have you tried starting your computer in safe mode and try to restore the computer back to the date where it is working fine by using system restore.
  • 3,530 Answers
Yes, you will be able to load windows XP if you will boot the computer from the cdrom. i think windows installed in your computer is pretty messed up. worst scenario is you will be needing to install new windows to your computer to solve this issue. try this optiong though, try to boot the the computer using the cd and run a repair.
Posted on May 04, 2010
  • 64 Answers
Something has physically changed in the laptop. Did you add any new equipment prior to this? If you haven't changed anything you will need a PC tech to look at your laptop. If you have, remove it and put it back the way it was. Then try again using the last know good configuration option.
Posted on May 03, 2010
I'm having this Dell Vostro 1510. Its not getting booted. When i try to boot it, It opens bios setting automatically with sometime beep sound coming. I tried to boot in safe mode, safe mode with...
insert the cd into the cd rom, when dell logo appears start tapping F12 it will give you the option to boot directly from cd.
also you can try system recovery if you have recovery partition with ctrl+F11.
Aug 06, 2011 | Dell Vostro 1510 Laptop
I have a IBM thinkpad T40, while working on it, the laptop shut down and started to reboot. but only got to a point where it said could not find operating system.after a couple of times tring to reboot it,...
Whilst booting up have tried tapping the F8 key to get into the safe mode menu and either select the last known good configuration option or the safe mode option to load the operating system to then try and determine the cause. Should this suggestion not work a safe option to recovering your data is to buy a USB hard disc drive docking station, whip out your hdd, slot it into the docking station and retrieve your files using another PC. Repairing the operating system using the XP disc on boot up sometimes works but also trashes your personal data if it's on the C drive and it reloads the o/s.
Sep 23, 2010 | IBM ThinkPad T40 2373 Notebook
Toshiba satellite wont boot up windows just black screne with pointer arrow
While your laptop is trying to start up, press the F8 key several times. This should give you several start up options. Select start in safe mode.
This will load a stripped down version of windows. Click on Start - all programmes - Accessories - System Tools - System Restore (This for XP, Vista and Win7 slightly different) and select a restore point priort to when the problem started.
Jun 28, 2010 | Toshiba Satellite Pro L300 Notebook
Laptop start up problem
Have you tried performaing a recovery ?
Feb 15, 2010 | Toshiba Satellite Pro M10 Notebook
I have an eMachine T3410. When it boots, a screen
your missing the biosinfo.inf. try reinstalling the system but backup everything you need first.
Jun 09, 2009 | E-Machines eMonster 600 PC Desktop
My HP Pavilion laptop will not boot.
Usually the message about low virtual memory is because there isn't enough RAM and it was using up all the designated space on the hard drive as Virtual memory. (Uses a part of the hard drive like RAM)
That shouldn't account for being unable to boot into any Windows options though.
The one trick with HP computers, you can try is to take the battery out, make sure the Laptop isn't plugged in with an AC adapter then press and hold the power button in for 10 seconds with no power going to the laptop. This is doing a power drain. Then put the battery back in and try to power on and boot up the computer.
When you choose safe mode, does the computer ask which operating system you want to boot into and does it give you the option to choose "Recovery Console"? Or is there an option on the screen with the safe mode options to Choose your Operating System? If not then the recovery console wasn't installed. If you can choose the recovery console, you might be able to replace the failed files that are not allowing the computer to boot into any version of Windows. Unfortunately, the computer isn't reporting which files are the problem, winlogon.exe/userinit.exe/etc.
You can get a hardrive enclosure at a computer store that allows you to put the laptop hard drive in the enclosure, then plug the enclosure into another computer with a USB cable then you can copy the sensitive data onto the other computer.
If you aren't comfortable taking the Hard Drive out yourself, you can take the laptop to a computer store, and they will take the Hard Drive and hook it up to a second computer as a Slave (Secondary Hard Drive) and copy the data over for you
Apr 12, 2009 | HP Pavilion dv8000z Notebook
Cannot start up
Do you have a copy of your OS disk:
Try This:
insert your Windows XP Setup CD, and restart your computer. 1.
When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
2.
Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.
Do not choose the option to press R to use the Recovery Console.
4.
In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.
Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.
Follow the instructions on the screen to complete Setup.
Feb 16, 2009 | Toshiba Satellite A35-S159 Notebook
My computer wont start up
First try pressing F2 at start up to see if you can get to setup. Also pressing F12 may get you a boot menu. If cd is already set as first boot you may get a chance to boot from a Windows cd. The idea here is to get to a minimal Windows configuration like setup or safe mode (F8) to see if this is a hardware or operating system fault. Two common issues with eMachines are power supply problems where repetitive reboots can actually fry the motherboard or if the PC has a few years use the CMOS battery. Steve Medley
Oct 30, 2008 | E-Machines eMachines Desktop PC
Windows XP fails to load and Computer will not start up.
Boot from startup floppy disks or CD-ROM, choose repair option during setup, and run Recovery Console. When you are logged on, you can run FIXMBR command to fix master boot record. This should solve your problem.
Sep 20, 2007 | HP Compaq Presario V2000 Notebook
Driver error upon boot
You have a corrupt OS, assuming you have XP, you should do a repair installation. Don't worry, none of your files or settings or installed programs will be deleted. You may have to reinstall some old device drivers though. * Insert the XP CD and boot to it * When you see " To setup Windows XP now, press ENTER", go ahead and press ENTER * You will now see an option to repair Windows by pressing "R". Do not select this option - it will only take you to the Recovery Console which is not what we want to do. Instead, choose to continue the installation * When you see the license agreement, press F8 to agree * On the next screen make sure your current XP installation is selected and then press "R" to repair XP * At this point XP will begin to install on top of itself, replacing damaged, missing or altered system files. Follow the instructions on the remaining screens to complete the Repair Install. It will look very much like a normal (new) OS installation. If all goes well your repaired XP installation will remain intact, keeping your personalized settings and installed programs as they originally were.
Aug 08, 2007 | Acer Aspire 3680 Laptop
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
