Back to:
Tags:
Eiki LC XNB1 LCD Projector
EIKI LC-XNB1 BRIGHTNESS
posted by will39 on Mar 26, 2008
I HAVE A EIKI AND IT WORKS WELL BUT THERE HAS TO BE ALMOST NO LIGHT OR IT KILLS THE PICTURE. I WAS TOLD THAT THE BULB IS EITHER GOOD OR BAD BUT NOT IN BETWEEN. ANY IDEAS?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 26, 2008
Not Rated (0)
Marrie
Rank:Wiz Wiz
Rating: 84%, 278 votes
Hi Will39
What you should keep in mind is that this Projector has only got 800 Ansi Lumens wich is not much and to make this worse it is a LCD Projector as well.
Ask your lamp supplier if they can insert a new lamp and check if it gives a better image at all.
If it doesn't , there is'nt really much you can do except buying a new unit with more Ansi Lumens and a better Contrast Ratio as this Eiki's Contrast Ratio is only 250:1 where the standard these days are 2000:1
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on EIKI LC-XNB1 BRIGHTNESS:
I don't want to Accept this solution
Can you Help with these Multimedia Projectors problems?
No power-dead. Tested with known good power cord, fuse...
We are using Windows XP SP2 and can not get the full...
hi marrie, i am a teacher in turkey, but i have a problem...
Could you explain to me how to connect a infocus machine...
The projector still displays from computer if is through...
Loading problems.
Repair Service
Find Multimedia Pro. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
