Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I have an electrical short in the mower clutch on my G110 mower.
I've been having trouble with the wiring for the electric clutch on my G110 John Deere lawn tractor since the restraining bracket broke. after a couple of rewirings, there is now a short I cannot find. However I have now found that hot side of the electric clutch is indicating it is grounded when the mower is turned off. This does right to me. could this be the problem? Or should I look elsewhere? It is the only thing I could find.
Thanks.
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
wireguy212
  • 1627 Answers
SOURCE: ELECTRICAL PROBLEM
Can't get you a diagram but i can tell you most electical problems on these tractors can be solved by replaceing the key switch/modual or cleaning corrosion from fuse holders.
Posted on Nov 10, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
agent91
  • 2100 Answers
SOURCE: Electric Clutch want engage the mower deck on my l120 john deere
They wear out. How old is the mower? Mine just gave out this week in the peak of hay season. (my grass) The wire can be unhooked from the PTO clutch and a 12 volt jumper can test it, if it jumps, it is good, if not, it is shorted out, they are expensive, I found 3 of them all the wrong size for mine. Try to find the same one. Ebay has a couple on there right now. Check it out.
Posted on Jun 10, 2010
farmerbear
  • 490 Answers
SOURCE: need mower deck belt diagram for L-130 John Deere
I have found the manual at JD's website. Click the link and scroll down in the left column until you find the heading for replacing the belt. I contains big, clear photos. Here is the link:
http://manuals.deere.com/cceomview/OMGX21647_K3/Output/Index.html?tM=HO
You can copy it into your browser window or type it in. I sure hope this helps you out. If I can be of any further assistance, please let me know:)
Posted on Aug 21, 2010
Electric PTO clutch on a LX255 John Deere I want to remove it and disassemble it to repair it
Electric Clutch Adjusting and Troubleshooting for Lawn ...
? 7:05
www.youtube.com/watch?v=yB9Lf_NKYXw
Oct 15, 2011 - Uploaded by askanthonynow This video describes how to adjust an electric clutch on a lawnmower. ... How To Repair Ripped Out Wires On An ElectricalPTO Blade Clutch - Duration: ... John Deere: How to change bearings in the deck spindles - Duration: .
Aug 25, 2015 | Garden
John deere l120 mower deck just quits after 20 min mowing or may work ok for 4 hrs?
The blades only turn when the electric clutch is engaged. Sounds like you may have a short in the wiring possibly at a terminal that is shutting down the clutch. Or it might be in the "reverse button" you have to push to keep the blades turning when you back up. Try holding in on the button when it stops and see if they start back up. I think it's definitely in the wiring somewhere.
May 16, 2014 | Garden
John Deere G110 electrical problem
Does your mower still work? It is possible this is a connector for an external trickle charger which may be connected while the mower is in longer term storage.
Mar 29, 2014 | Garden
Why does my john deere g110 blows fuse when blades are engaged
unplug the clutch and see try it if the fuse doesn't blow then look at the wires going to the clutch make sure they didn't rub on something
Jun 09, 2012 | John Deere Garden
Triped cb
Make sure you are using an extension cord that can handle the amperage. If so then you've likely got an electrical short somewhere. Your extension cord should be at Least as large as the cord on the mower or larger.
Nov 20, 2011 | Garden
Mowerdeck will not engage...
I own a similiar John Deere model (L130, 23HP with a 48" deck). I would check the electric clutch (called a PTO). To do this check the wires to this clutch and look for something disconnected. These wires (to this PTO clutch) should have twelve volts with the key on and the blades engaged.
Feb 26, 2011 | John Deere 195HP Hydrostatic 42" Cut...
20 amp fuse on Model 125A blows when blade engaged
There is a short in the electric clutch or the clutch just plain went bad and needs to be replaced... I would check all the wires going to the clutch for rubbed spots where the coating is rubbed off and bare wire is hitting the metal...
heatman101
Aug 29, 2010 | John Deere Garden
I have a John Deere l130 and the mower blades engage when I start the engine even when the PTO switch is off. Any suggestions?
sounds like you have feed going directly from switch as soon as you turn ingition to start mode ?
check wiring back from electric clutch to main switch
possible 2 wires have been placed on main switch instead of pto switch ?
or you have a crossed circuit somewhere (that is feed from another live circuit) not directly connected and its ended up at electric clutch as soon as you liven main circuit
a wiring diagram may help
check with www.johndeere.com
or www.jdparts and enter their site load your model and type
and go to electrical system and print out a copy of wiring diagarm
you may need to supply and user name and apply for password from john deere via their site apply on line
its a good site for info and parts diagrams
cheers hope it helps
paul
Aug 05, 2010 | John Deere Pto Clutch For Stx38 And Stx46...
Electric Clutch want engage the mower deck on my l120 john deere lawn tractor. all of the belts are ok.
Jun 10, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
156 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
