Question about Kenmore Dishwashers
My dishwasher (model #110763510) lets water go out from the door; I think the problem comes from the overfill protector because it is no more linked to the system: I can pull it out from the dishwasher. I would like to know if it easy to repair, easy access from under. If so, then I would order the piece and repair it myself. Thanks for your advice. Claude
  • 10,865 Answers
Hello Claude. Yes. The best place to order parts is Sears Direct. Just go there, enter the model number and you get a great schematic showing every part, screw, etc. J.
Posted on May 03, 2010
Door is leaking
The first thing I would check is the overfill protection float. Check under the float for objects that may keep the protector from moving up or down.
Oct 06, 2014 | Kenmore Dishwashers
Kenmore Dishwasher 665 16059401 - Control lights flashing Not working
Hi Have you tried resetting your house breaker to your dishwasher, by turning it off for 60 secs. then back on again? this should reset your dishwasher. By Start can you hear the pump out. or can you hear water filling the dishwasher?..if it only pumps out..it may be the Overfill protector. Check to make sure the overfill protector moves up and down freely. The overfill protector is located in the left front corner of the tub it looks like a little hat. it should move up and down easily. and you should feel/hear a click that is your float switch. also check the Door latch. Open and close the door to make sure the door latch is securely fastened. Next you may take off the console, and reset that control board to keypad console connector , by taking that loose and reconnect it. If that doesn't work, then you may need a new keypad console assembly. let me know what you are doing to do? I can help you somemore.
Aug 25, 2007 | Kenmore 24 in. 16059 Built-in Dishwasher
No water is filling in my machine
Good Afternoon Friend,
I understand that your Frigidaire dishwasher, model# FFBD2411NS, will not fill with water. First make sure that the water supply, to your dishwasher, is turned on. Next, make sure the overfill protector moves freely up and down. You will find this located in the front left corner of your appliance. This keeps your appliance from overfilling. Make sure you clean this occasionally with household cleaner containing vinegar or bleach to dissolve any buildup. The overfill protector should move up and down freely about one inch. If it does not move, lift and clean underneath. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Frigidaire FFBD2411NS
Water is not coming into my frigid wire dishwasher?
Good Morning Friend,
I understand that water is not coming into your Frigidaire dishwasher, model# PLD2855RFC. There are a couple of things that I would check.
First, check to make sure the water supply is fully turned on.
Secondly, check to make sure the overfill protector moves up and down. The overfill protector keeps your dishwasher from overfilling and is located in the left front corner of the tub. The overfill protector should move up and down freely about one inch. If it does not move, lift and clean underneath. Clean this occasionally with household cleaner containing vinegar or bleach to dissolve any buildup.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 25, 2014 | Frigidaire PLD2855RFC Dishwasher
New frigidaire dishwasher won't fill with water
Make sure that your water is turned on under the sink from the line tapped off of the hot water pipe if it is on pour 3 large pots of water in the bottom and hit start
May 10, 2014 | Frigidaire FFBD2406NS Full Console...
Won't Fill and will attempt to run wash cycle when turned off and door is closed
Hello ddux97 - I understand your dishwasher has power but will not fill with water. Here are a few simple troubleshooting tips that may help you resolve this issue:
• Make sure water supply is turned on. (First check for shut off valve under the kitchen sink).
• Check the house circuit breaker or fuse box, reset circuit breaker or replace fuse.
• Check inlet hose and make sure it's not twisted.
• Does float overfill protector (mushroom shaped object in tub) move freely? This is located in the bottom left front corner of the dishwasher.
• If this is a new install, then make sure the unit is not pressed up against the cabinet and the fill tube is not squeezed closed.
• Make sure the electrical wires going to the water inlet valve have not come off. It is best to turn off power to the dishwasher before reconnect wires, it doesn't matter which terminal is off both need to be connected.
• Make sure the drain hose is installed correctly. If the drain hose is routed under the floor as the dishwasher fills water can be drawn from the tub and appear to have never filled.
• Some models of Frigidaire dishwashers use a water pressure switch that will shut off the water valve if the tub over fills. These models do not have floats.
I hope these troubleshooting tips help you in some small way.
Jun 20, 2013 | Frigidaire 24 in. PLD2850 Built-in...
My frigidaire fdb1100rhm dishwasher detergent dispenser clogs as well as overfill protector
Check for correct water pressure to the dishwasher. Could be a restriction in the 1/4" water supply line.
Feb 01, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
Dishwasher does not drain completely
Check your main drain system where your finally connect to let off the dish washer water.
Apr 10, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Will not fill with water
The problem is most likely the water inlet valve. This is a solenoid that opens when there is power to it. It is a common problem on dishwashers and washing machines.
They are not very expensive and are usually fairly easy to replace.
If you need more help, post a comment.
Thanks,
Tim
May 27, 2009 | Frigidaire PLDB998A Built-in Dishwasher
Dishwasher problem - no water in the tub
hi.
The sensore key that control the door of dish washer may be show that the door is open & it doesent let that water come to machine . you should checke the key
Nov 09, 2008 | Frigidaire 24 in. FDB1250RE Built-in...
Dishwashers Logo
89 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
