Question about Goldstar M6004R Air Conditioner
The unit just stopped working and will not turn on
M6004R Goldstar air conditioner working fine then turned it off for the night went to turn it back on and will not turn back on. Check breakers and tried other outlets.
    Novelist:
    Champion:
  • 246 Answers
I'm assuming 'nothing' comes on when you try to run the AC unit. If the fan runs but the AC does not cool then ignore the below info, but if "nothing comes on" then proceed with the below info.
If the breakers are not tripped and you've tried other outlets (on different breakers) I would suspect a faulty switch. You can replace the switch ( If it's not computerized). First unplug the unit from the wall and locate the switch (it will be the one that has the knob that controls "fan, Hi Cool, Lo Cool, etc etc.) then remove the switch - 'being careful to mark all the wires in such a manner you can replace them on the new switch, exactly like they came off the old one.'
Then if you take the switch to an appliance shop and can find/order the 'exact' same switch (or at least a comparable replacement with the same connections as the old one) you could re-install it on the unit, connect your wires back up to the switch and plug it back into the outlet and see if that was your problem.
good luck!
Posted on May 04, 2010
I addred coolant to the AC unit a few weeks ago and it has been running fine until last night. I went to check the pressure and make sure the line was not frozen this morning since the indoor air climbed...
It is just coincidental that the fan motor died now...
Replace the condenser fan motor and you will be good again...
Here is a tip about troubleshooting your airconditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 20, 2011 | Carrier 38CKC036 Air Conditioner
Where is the drain plug on this unit goldstar 6500 airconditione
There is no drain plug,if it is not draining,then the drain holes are stopped up with trash and debris,remove the unit from the window,and take it out side,use a water hose to clean it out,and you will be fine,if this was at all helpful,please rate,thank you.
Jul 05, 2010 | Goldstar KG6000R Window Air Conditioner
I need to see the securest possible places to attach the given hardware so it doesn't fall out of the window and keeps insects and the hot air out of the room. Helpful to see the pictorial directions...
hi ,back mounts are the best an will give you that security you need to insure the unit will not come out ,some of the assembly materials are there but some extras possibly would have to be add . thanks
May 15, 2010 | Goldstar M6004R Air Conditioner
1 month old air conditioner wont turn on
Return it for a refund or a repalcement if less than 30 days you can get a replacement at the store.
Aug 19, 2009 | Amana PTH074B35AE Heat Pump Air...
Goldstar GE120CE aircoditioner control panel
sounds like a bad circuit board inside contact GE and have them send you a replacement or have a tech service it for you
Jul 25, 2009 | Heating & Cooling
Goldstar/air/window unit/runs for awhile and turns off
Does it have energy saver option? Check if you have timer option. If your units runs and then turns off without restarting by itself and you don't have those options call manufacturer or take it back and get your money back.
Jul 20, 2008 | Haier hwr10xc6 Air Conditioner
Running Compressor Intermittently
replace the thermastat it has a bad set of contacts
May 05, 2008 | Goldstar R8000 Air Conditioner
Goldstar M6004R Air Conditioner Logo
134 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
