Question about Sylvania CL772B 17" Flat Panel LCD Monitor
Sylvania 780 wont stay on for more than 10 seconds than I have to press the on button again and it goes off after 10 secons again.
  • 11,361 Answers
If you are going to DIY repair, please read below and look at the pictures in my albums.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on May 03, 2010
Sylvania LD320SSI when turned on goes through a series of different colors and will not stop.
The way it can be brought back to normal is by pressing the "Standby" button on the tv and wait 5 seconds. Then press it again and as the TV was turning on, press the "Menu" and "Source" buttons on the tv simultaneously and when the tv was on it was on the menu. Turn the tv off with the remote turn it back on again with the remote. Should be back to normal. Hope it helps someone, it worked for a friend who had the same problem.
Apr 22, 2016 | Sylvania Televison & Video
Smp-n200 shuts off after 10 seconds. reset button not effective. 6 months new
Simple fix when this happened to me... I replaced the battery on the remote controller and the media player started working and didn't shut off again. Apparently, when it first comes on, it does a self test. if it receives no input from the remote, it shuts itself off. Hope this helps... BTW, the battery for the remote is any 2030 battery. Just replace it and try it. let me know if it worked...
Dave
Jan 28, 2013 | Sony SMP-N200 Streaming Media Player with...
I have a sylvania dvd vcr combo and the progressive scan light is on and it wont play dvds. How can I fix this?
Try the (Goldstar and Zenith) trick - with the unit on, but no discs inserted, press and hold STOP button on the front (not the remote) for 10 seconds, then release. This should revert progressive back to normal interlace output for your TV and may also turn off the progressive LED indicator on your unit.
I mentioned 2 other brands in parentheses - because the (press and hold STOP for 10 seconds) trick works for progressive on those.
Apr 10, 2011 | Sylvania (SRDD495) DVD Player/VCR
How do i program my rca remote to my 42 inch samsaung tv
you can try a code search
  1. Turn on the tv you want to program.
  2. Press and hold both the button for the component along with the power button until the light comes on and stays on.
  3. Press the play button every 5 seconds until the device turns off. A bank of ten codes is being sent each time.
  4. Press the rewind/reverse button to see if it turns off/on again. Wait 2 seconds and press again until it turns back on. You may have to do this up to 10 times until it searches through the bank of ten codes sent.
  5. Press and hold the stop button until the light goes off. This saves the code.
Mar 03, 2011 | RCA 3-Device Universal Remote
Plays about 10 seconds of A song and then wont finish playing the song how do you reset it?
I have a sylvania SMP4049 model mp3 player. I was experiencing the same problem with my own mp3 player last night. I managed to fix the problem by pressing the m button again and again, then scrolling down to normal and hitting centre button on my mp3 player. After that, the songs played all the way. Hope this helps!
Jun 30, 2010 | Audio Players & Recorders
SG2.5 GPS Receiver: SCREEN NOT VERY BRIGHT AND GOES OFF AFTER 15 SECON...
press the bottom left button
scroll to preferences
select
change the contrast settings to fix the screen issue
exit to menu again and select advanced menu, select system settings - and then you can change the auto off timings
May 17, 2010 | SkyCaddie SG2.5 GPS Receiver
Pushing on power button three green lights come on for one secone
click here you would find the details for led codes. you may select any laptop. codes remain the same.
Sep 24, 2009 | Dell Latitude D600 Notebook
Tv goes on for 5-10 seconds then turns off
OUR TV AT WORK TURNS ON OK THAN IT TURNS OFF AFTER ABOUT 10 SEC SOLVE THIS FOR US THANK YOU fghigliotty @ niece lumber.com
May 08, 2009 | Sylvania 6720FDG 20" TV/VCR/DVD
Driver's side window does not stay up
Try this,push the switch down and roll down the window continue to hold the button for three secon ds then roll the window up and continue to hold the switch up for three seconds.Do this again and see if it fixes your problem.
Nov 28, 2008 | 2003 Lexus IS 300
Sylvania CL772B 17" Flat Panel LCD Monitor Logo
194 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
