Question about Hitachi 1TB External USB 2.0 Hard Drive
My XP will not boot when my Hitachi 1TB External USB 2.0 drive is connected. It gets as far as showing the Pentium screen and stalls.
    Guru:
  • 1,705 Answers
Its probably trying to boot from your external drive.
Go into your bios and reset your boot setting to HDD0 as your first boot device, Disk drive 0 second and floppy third, unless you want to boot from an external drive. That being the case select an appropriate order.
If the bios shows your external HDD as HDD0, then you have to work out which is the drive carrying the operating system and set that to your first boot device.
To get into the bios, watch the boot screen for a key to hit to enter setup, normally its the "DEL" key.
Posted on May 03, 2010
  • 2 more comments
  • georgeC_59 Jan 20, 2011
    dgsturt, I am having the same problem as joepols. But I can’t apply the fix you suggest.
    My BIOS (AMI BIOS revision 3.28, 08/27/04) with Setup Utility v 2.51 already has my internal hard drive as the first boot device. It is identified by name[PM-ST3120025A], and not as HDD0.
    Incidentally, another external drive that is sometimes attached to the USB hub does not interfere with the XP’s boot process, and neither did an older external drive that the XL1000 replaced.
    For now my only workaround is to unplug the XL1000 during the boot sequence, and plug it back in after the operating system starts. This is doubly inconvenient given that the XL1000 does not have a power switch.
    Any idea would be appreciated.
  • dgsturt Jan 21, 2011
    I think the issue may be down to the size of your external hard drive. WinXP can only see HDD up to 127Ghz, yours I believe is 1TB (1000Ghz). This being the case, I think you need to partition your external hard drive into lumps of 127Ghz or less.
    This can be done by using a programme such as partition magic, but the easiest way is to use another PC with a different O/S such as Vista, WIn7 or Linux to partition the drive. With luck it should then work on your XP PC.
  • georgeC_59 Feb 06, 2011
    I want to emphasize that the computer doesn't detect the external drive DURING the boot up process and stops it from continuing. This is before XP loads. Once XP has started, I power up the External drive, and everything is OK. I doubt very much that partitioning is the answer.
    When you wrote Ghz, you meant GB!. Right?
  • dgsturt Feb 07, 2011
    Apologies for misreading, and yes you're right I did mean 127 Gb. Partitioning would probably be necessary if you wanted to boot from the external drive.
    Now back to the problem, if I'm reading this right the XL 1000 is interfering with the boot process when turned on prior to your PC.
    My only other thought is, back to your bios setup, of the several boot options,is one of the boot settings on "external device"? if so try switching it out, choose no device if necessary. But don't change your first boot option.
    After this I'm at a loss, save for trying the Hitachi web site, contacting their techs for advice or like other companies, do they run a forum for problem solving.
I have Hitachi 1 TB HD, XP professional on HP desktop.I bought 1 TB to exchange my regular 500Gb. Start to install HD was formated only 120 Gig. Excess to Bios would not help/ No extra options to change size of HD. How can I reformat that dist to 1 TB? Fdisk or format did not work.
Posted on Aug 28, 2010
SATA Hitachi 1 Tb HARD DRIVEi AM TRYI8NG TO INSTALL A NEW HARD DRIVE ON MY DELL 4700 AND I CANT FIGURE IT OUT IT IS SAYING NO ( BOOT DEVICE NOT FOUND)\
Dear Jackson,
If you are connected your new hard drive, You just have to go into BIOS and set your old hard drive as first boot device . its all. for BIOS choose f2 or f10. Good Luck.
Nov 20, 2012 | Hitachi 1TB External USB 2.0 Hard Drive
Windows xp sp3 stop error message 7e usb
Why not just pull it out instead of clicking on safely remove hardware? Try it and see if it works. Sounds like your usb drive is not windows 7 compatible. Or windows 7 has some driver issue which is not uncommon.
Jun 04, 2012 | Hitachi 1TB LifeStudio 35 Desk Plus...
Transfered XP to internal Sata disk with controller . MOBO A7V8X-X, BIOS version 1014. Disk is recognized during boot. Disconnected all IDE drives. System won't boot from sata disk. Booting from CD results...
get to the bios boot section
( on starting the computer hold down the delete key until the bios screen shows
in that section you will see boot preference
organize the sequence that the unit will boot from save and esc
so sata hard drive =1
cd=2
external hard dive =3 etc
Sep 11, 2017 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
I have a 1TB Hitachi HD i used on my Imac. now my son has it but he has Windows XP..How can i format this to window so he can use it. We plug the Hitachi on his comp. but do not show any help?
Connect the Hitachi
Click Start
Right-mouse click My Computer
Click Manage
Click Storage
Click Disk Management
Right-mouse click the icon for the Hitachi
Click Format
Assign a drive-letter
Done.
Oct 18, 2010 | Hitachi 1TB External USB 2.0 Hard Drive
When i plug my hitachi xl 1000 to my laptop it works and its win xp... but when i connect it to my desktop win7 it doesnt work and doesnt get detected...need some help
Hello michaello337
I presume you are booting that 1TB right?
Did you tried connecting that USB in the back of your Desktop?
Try it, sometimes Front Panel USB's is busted.. Due to misconfiguration of the connectors.
Try that and send me a buzz.
Aug 18, 2010 | Hitachi 1TB External USB 2.0 Hard Drive
I can't see the hd symbol. I have a brand new external 1TB hard disk. Windows xp recognizes the device but it doesn't show the system symbol, thus I can't write on it.
Check the Disk Management console to see if the hard disk is partitioned and formatted.
Right-click My Computer and select Manage in the popup menu.
Dec 18, 2009 | Hitachi 1TB External USB 2.0 Hard Drive
Vista 64 - slow boot with WD MyBook attached
This is caused if there are any system files on your external drives OR if you have set the bios to be able to boot from usb devices
One or the other is where you need to look.
Aug 17, 2009 | Western Digital 320GB MyBook External USB...
Hitachi 1TB External USB 2.0 Hard Drive Logo
677 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
