Question about Gateway GT5058 Desktop PC
I am trying to troubleshoot a video issue, I replaced the video card, I receded memory, etc, no video. How do I tell the BIOS to look at another video card instead of the on-board?
    Problem Solver:
  • 6 Answers
Once the card is install u have to disable the onboard video by going into systems than device manager click on video and disable the intergrated video
Posted on May 03, 2010
    Guru:
  • 1,705 Answers
There are, I think, three ways to read a video card.
1) On-board card reader.
2) External card reader.
3) Using a device (Camera) as a card reader.
You shouldn't need to access the bios at all.
1) You know about.
2) These plug into a USB port and the card should be identified as a USB mass storage device or extra HDD.
3) These plug into a USB port and the card should be identified as a USB mass storage device or extra HDD or even the Camera device name.
In each case you should be able to click onto the device, it should open and display any files there on.
Asus Ee pc screen is half white. how can i fix it?
Try to boot to the BIOS screen/ system setup screen. Tap on F2 on the splash Asus splash screen. If the BIOS still shows this problem, it is a hardware failure. You will either need to replace the LCD screen of the video card of your laptop. To further isolate the issue, you need to connect an external monitor on the portable system while you are on the BIOS screen and press on Fn+F8. If the issue is seen on the monitor, then it is the video card, if the external monitor is clear, then it is the LCD screen.
However, if the issue does not occur in the BIOS, it must be the video card. Hopefully it is just a corrupted video card driver. Try to uninstall and reinstall the video card driver. If it does not resolve your issue, then it is the video memory of your computer. You still need to spend some money to have it serviced.
Jul 02, 2011 | ASUS Eee PC 900HD Netbook
Beep Codes?
This board has been known to have some issues, the Asus' PEG optimizations aren't fully supported by some video cards like the Gigabyte GeForce 6600 GT. One example of a fully supporting video card is the Asus Extreme Radeon EAX1900XTX.
If possible, try using a different video card (one that supports
Asus' PEG optimizations - PEG Link Mode overclocking feature; PEG Link for single/dual graphics cards ). Or you may want to try and disable the PEG entirely.
Hope this be of some help/idea. Pls post back how things turn up or should you need further information.
Good luck and kind regards.
Oct 21, 2007 | ASUS P5ND2-SLI (890552603831) Motherboard
Tip
Beep Code Explained
Thanks to Transcend Technical Support for this great Brief of understanding beep codes that is found here
This is a long post and it may be truncated at the bottom. If so, use the link above to go to the Transcend web site where these are found
1.General POST (initial system boot) BEEP Codes
If you do not know the BIOS manufacturer, the following will be the general Beep codes:
• 1 Long and 1 Short Beep ?Bad Motherboard
• 1 Short Beep and nothing else happens ?Disk Drive/Video Related Problems
• 1 Long and 2 Short Beeps ?Bad Video Card
• 1 Continuous Beep or Non-stop short Beeps ?Bad Power Supply
• 3 Short Beeps - Bad Memory
2.American Megatrends Inc. (AMI) BEEP Codes
• 1 Beep - Memory refresh timer error.
Reseat the memory, or replace with known good modules.
• 2 Beeps - Parity Error
• 3 Beeps - Main memory read / write test error.
• 4 Beeps - Motherboard timer not operational
• 5 Beeps - Processor Errors
• 6 Beeps - Keyboard controller BAT test error.
• 7 Beeps - General exception error.
• 8 Beeps - Display memory error.
If the system video adapter is an add-in card, replace or reseat the video adapter. If the video adapter is an integrated part of the system board, the board may be faulty.
• 9 Beeps - ROM checksum error
• 10 Beeps - CMOS shutdown register read/write error
• 11 Beeps - Cache Memory Bad
Beeps 4-7, 9-11
Fatal error indicating a serious problem with the system. Consult your system manufacturer.
Before declaring the motherboard beyond all hope, eliminate the possibility of interference by a malfunctioning add-in card. Remove all expansion cards except the video adapter.
?If the beep codes are generated even when all other expansion cards are absent, the motherboard has a serious problem. Consult your system manufacturer.
?If the beep codes are not generated when all other expansion cards are absent, one of the add-in cards is causing the malfunction. Insert the cards back into the system one at a time until the problem happens again. This will reveal the malfunctioning add-in card.
3.Award Bios BEEP Codes
1 Long Beep: Memory problem
Explanation: There is a failure of some sort related to the system memory.
Diagnosis: The first bank of memory probably has a failure of some sort; this is usually just a physical problem such as an incorrectly inserted module, but may also mean a bad memory chip in a module. It is possible that there is a failure related to the motherboard or a system device as well.
• 1 Long, then 2 Short Beeps: Video error
Explanation: The BIOS is unable to access the video system in order to write any error messages to the screen.
Diagnosis: This is usually caused by a problem with the video card, or the memory on the video card. It can also be a motherboard issue.
• 1 Long, then 3 Short Beeps: Video error
• Continuous Beeping: Memory or video problem
Explanation: The system is producing constant beeping in no specific pattern, or a fast "ringing" sound.
Diagnosis: This is usually caused by a problem with the system memory, or possibly the video card. The memory is more likely--the system complains long and loud if it can't find any usable memory, as there is no way to even start the boot process when this is the case. The motherboard itself could also be the problem.
• Other Beep Codes
Explanation: You have encountered an Award BIOS beep code I do not have documented.
Diagnosis: Award says that any beep patterns other than "one long followed by two short" are likely problems with the system memory. However, of late they have started adding other beep codes to their systems as well.
4.Phoenix BEEP Codes
• 1-1-3
Explanation: Your computer can't read the configuration information stored in the CMOS.
Diagnosis: Replace the motherboard.
• 1-1-4
Explanation: Your BIOS needs to be replaced.
Diagnosis: Got to your motherboard manufacturers web site and download the new Bios.
• 1-2-1
Explanation: You have a bad timer chip on the motherboard.
• 1-2-2 or 1-2-3 or 1-3-1 or 1-3-3 or 1-3-4 or 1-4-1
Explanation: Motherboards is bad.
• 1-4-2
Explanation: Some of your memory is bad.
Diagnosis: Go to Basic Trouble Shooting
• 1-3-1
• 2-_-_ Any combination of beeps after two
Explanation: Some of your memory might be bad.
• 3-1-_
Explanation: One of the chips on your motherboard is broken.
• 3-2-4
Explanation: Keyboard controller failure.
Diagnosis:
• 3-3-4
Explanation: Your computer can't find the video card.
Diagnosis: Is it there? If so, try swapping it with another one and see if it works.
• 3-4-_
Explanation: Your video card isn't working.
Diagnosis: Replace Video Card.
on Jan 20, 2009 | ASUS P5W DH Deluxe Motherboard
Beep codes 1long and 2 short with blank screen
Usually Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
You could try removing the video card and re-seating it. Also you may try using a another power connector than the one you are using as one of them may have a problem. But it looks like a video problem. Check BIOS in case your settings changed and the onboard video (if present) is on. In certain Mainboard it could be a memory issue, reseat your RAM too.
Hope it helps.
Oct 11, 2010 | HP Computers & Internet
How can i allocate more memory to video card of acer aspire 5100
You can only do that with onboard video cards. If you have an onboard you can choose how much ram to assign to it in your bios settings. However it is limited and if you already have 128 assigned to it, that's probably about all it's gonna give ya. But hey it never hurts to check Assigning your physical memory to your graphics card will result a shortage of your total system memory and your whole system will slow down a bit.
Video cards meant for better processing the graphical content of your system and free up your system's physical memory.[via]
So, if you buy a new and better video card with more memory you will have a fast system with better performance.
Apr 27, 2010 | Acer Aspire 5100 Notebook
Monitor (no signal) after replacing mother board and CPU
try only connect Monitor and keyboard, and check for booting (disconnect all the rest (HDD, CD DRIVE, Sound Card, Network Card, ....) then try connect one by one and always off to change hardware config.
If dont work with monitor and keyboard, try reset bios(jumper),check again, then replace memory modules (must be compatible to new motherboard), evan dont work, send back the motherboard for defective motherboard.
Jan 14, 2010 | Gateway Intel (El Paso 2) Motherboard P4...
Amibios post code on a gigabyte board, 8 beeps 2 beeps 1 beep on GA-6rx board, no video output, have changed cpu, memory, video card, keyboard, hd etc, still no boot----help!
Hope this helps ... from the Ami BIOS website ....
8.2 POST BIOS Beep Codes
Number of Beeps
Description
1 Memory refresh timer error.
3 Base memory read/write test error
6 Keyboard controller BAT command failed
7 General exception error (processor exception interrupt error)
8 Display memory error (system video adapter)
8.2.1 Troubleshooting POST BIOS Beep Codes
Number of Beeps
Troubleshooting Action
1, 3 Reseat the memory, or replace with known good modules.
6, 7 Fatal error indicating a serious problem with the system. Consult your system manufacturer. Before declaring the motherboard beyond all hope, eliminate the possibility of interference by a malfunctioning add-in card. Remove all expansion cards except the video adapter.
• If beep codes are generated when all other expansion cards are absent, consult your system manufacturer’s technical support.
• If beep codes are not generated when all other expansion cards are absent, one of the add-in cards is causing the malfunction. Insert the cards back into the system one at a time until the problem happens again. This will reveal the malfunctioning card.
8 If the system video adapter is an add-in card, replace or reseat the video adapter. If the video adapter is an integrated part of the system board, the board may be faulty.
Copyright 2008
Sep 26, 2009 | Gigabyte Computers & Internet
My pc not working and gives 4 beep only
Most probably, this could be a videocard or memory problem.
Try opening your CPU and take out the memory and place it to a vacant slot. Make sure it is properly installed.
Do the same also with your videocard.
If it does not work, try isolating the problem isolating the problem. If you have extra memory or videocard, it is best to do trial and error by replacing one at a time to determine whether the memory or the video card is defective.
Jul 20, 2009 | Computers & Internet
Mother board
Remove all peripherials, i.e .drives, video cards, even memory. Leave Power Supply connected. I hope you disable power while removing or installing components. Try to boot up motherboard with nothing except P/S connected. Assuming no beeps there, hook up one or both memory modules at which time there should be error beeps indicating no video card attached, etc. If you are then getting the bios beeps, there is a good possibility that the motherboard is good. If there are no beeps, then one has to consider the possibility of a bad motherboard or a damaged bios. Tell me more about motherboard manufacturer and model #.. All this is necessary to properly research your issues
Feb 21, 2008 | Computers & Internet
Gateway GT5058 Desktop PC Logo
152 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
