I have a Dell Inspiron 1520 laptop. I wish to disable the mousepad when using an external mouse. I cannot see how to do that?
    President:
  • 1,561 Answers
Go to the device manager on your laptop, under it go to mouse pad, under it right click and click on disable.
Take care
Posted on May 05, 2010
How do I turn off the internal mouse pad?
There is no button/ key to turn off Internal Mouse (Touchpad) in a Dell Inspiron 1545 so you may try following the below steps which might help:
    (1)Click start.
    (2)Type device in the search box and select device manager.
    (3)Double click on Mice and other pointing devices.
    (4)Right click on the Internal mouse and select disable.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Jun 22, 2014 | Dell Inspiron 1545 Notebook
I HAVE A DELL INSPIRON 1520 LAPTOP THE SIX KEY IS ALWAYS ON I CAN NOT TYPE ANYTHING, CAN I DISABLE THE KEYBOARD AND USE MY EXTERNAL KEYBOARD?
go to C:\Windows\System32\Drivers.
You will see some files start with kb
change "kbfiltr" to "kbfiltr_del".
This will disable laptop keyboard.
Jul 04, 2012 | Computers & Internet
I can not disable touchpad of INSPIRON 1545 of DELL Computers There is no option for disabling touch pad in the MOUSE option of Control Panel
Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'immortal4u.png
Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
In the new window that appears, click 'Device Select'
Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is present'
That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
Good luck ! if your problem is solved don't forget to rate
Dec 30, 2010 | Computers & Internet
My right click menu pop's up when ever i try to click on my laptop anywhere, i have a DELL inspiron 1520.
is your pointer set to be opposite... go into control panel and mouse options, and see if you accidentally switched your mouse clicker buttons.... try clicking with the right click, does it still open your 'right-click' menu? does it work normal on an external mouse?
maybe its just a setting issue,... if not then prolly need a new mouse pad...
Sep 25, 2009 | Dell F3534 Touchpad
How do I disable the touchpad?
Try disabling the touch pad in the device manager. If that don't work unplug it from the motherboard. You will have to take the bezel and the keyboard off to unplug the touch pad.
Jul 11, 2009 | Dell Inspiron 1521 Laptop
Disable mousepad
hi,
try the Fn+F7 combo, the F7 is usually assigned to the touchpad and is indicated by an icon that's relevant.
This works on most notebooks to turn on or off the touchpad.
. Press F2 or F10 (it varies) to enter your bios setup screens. In these pages is a setting for touch pad only, mouse only or touch pad and mouse or serial. You might check that.
Jul 05, 2009 | Dell Studio 1537 Notebook
Right click not working
go into the mouse icon in the control panel and make sure its not disabled in there. If it is then enable it. If its not disabled in there then the board underneath your mousepad is bad. The right tactile button undernath the right mouse button is bad so the whole board would need to be replaced cause it comes as one whole board. You can get it directly from Dell or get one from Ebay.
May 17, 2009 | Dell Inspiron 1501 Notebook
Dell Laptop Trackball Too sensitive!
Easiest thing to do is to use a mouse. Just plug it in (ideally before you switch on), should automatically be recognised and away you go. I hate trackballs and the mousepads and when working on anyone elses laptop, always connect a mouse up.
May 05, 2009 | Dell Inspiron 4100 Notebook
The cursor doesn't respond to commands given using mousepad.
Sounds like a malfunctioning touchpad. You could try an external mouse and disabling the touchpad in device manager.
Dec 13, 2008 | Dell Latitude D600 Notebook
Keyboard and mouse won't work after start up
Pls check that the press button on the top of touchpad, most probably its disabled by being accidently pressed.
Dec 11, 2008 | Dell Inspiron 1521 Notebook
Computers & Internet Logo
David Payne
David Payne
