Question about Brother MFC-5440CN All-In-One InkJet Printer
Printer keeps telling me that the yellow cart is empty and I have put a new one in
  • 24 Answers
Are you positive it says the yellow cart is empty? Because that brother printer is designed to say that a cartridge is empty whenever ANY of the color cartridges are empty. Usually it doesn't tell you which one is really empty either. So even if you replaced the yellow cartridge and say, the black cartridge is empty, it still won't let you print until you replace that empty black cartridge, nor will you know which of the cartridges is empty unless you pull them out of the printer and manually check the ink levels.
Its pretty much a guessing game with those old brother ink printers.
Hope this helps :)
Posted on May 03, 2010
3 Suggested Answers
SOURCE: False empty ink cartridge message
Found this solution on another webpage: http://www.fixyourownprinter.com/forums/printer/50063
Hope it help.
Posted on Apr 08, 2008
RPFinney
  • 385 Answers
SOURCE: printer tells me to install new color cart. after i have put in new hp cart.
1. Press the Setup button.
  1. Use the arrow keys to select Tools and then press the OK button.
  2. Select Clean Print Cartridge and then press OK . The device prints a test page.
  3. Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.
  4. Open the Printer Toolbox . There are two ways to do this:
    • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
  5. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
  6. Remove and re-insert, while the product is switched on.
If still bad, swap out the cartridge.
Hope this helps
Regards
Posted on Apr 19, 2009
My MFC-J430W tells me that I have not changed the yellow and i have
if the NEW cartridge is not an OEM one it will probably never work they are chipping them anymore
Dec 06, 2015 | Brother Office Equipment & Supplies
Hi, please tell me how to install a new black ink cartridge into my epsonstylus D78 printer
Open the cover. Press the Ink/maint button (triangle shape on button) this moves the carriage to indicate empty cartridge. keep pressing until carriage moves to the ink replacement position. Open ink cartridge cover and remove the cart. Ensure you remove the yellow tape on new cart' before installing and be careful not to touch the chip on the cart'. Push new cart' in until it clicks. Close lid (ensure clicks down), close printer cover and press ink button again.
Please take a moment to rate this solution, thanks.
Mar 26, 2009 | Epson Stylus C86 InkJet Printer
Dcp 135c
unplug from power. wait 2 minutes. take all carts out. refill to full. plug to power and wait til machine demands carts. insert cart one after another and give answer to display in case there is a message.
Jun 21, 2008 | Brother DCP 115C All-In-One InkJet Printer
Mfc 215c printer ink problem
yes. unplug machine from power outlet. take all carts out. wait 5 min. leave scanner top open when powering up again. machine demands carts. reinstall carts and ANSWER display.
DO run a firmware update afterwards (see brother homepage of your country).
Mar 24, 2008 | Brother MFC 210C All-In-One InkJet Printer
Cyan ink Cartridge
Do you use generic ink carts?
If yes, try another one.
Alwasy make sure that the carts are placed well and are secured.
Answer the lcd question given by machine and check the magenta and the BK one, which could be empty, too!
Dec 28, 2007 | Brother DCP-315CN All-In-One InkJet...
Cartridge not recognized
Yes. Unplug machine from power. Wait 5 minutes. open scanner and take all the carts out. close scanner. plug machine to power again. machine will do the start up cleaning. Machine demands carts. insert NEW carts and give the answer in case you are asked by machine.
Do only change the carts when machine stopps for EMPTY cart. As long as it shows Nearly Empty everything is alright.
The machine has a drop counter and counts the ink drops down to zero when the flag is raised within the (nearly) empty carts. In case you take them out at that moment and reinsert again the ink inside will splash and raise the flag again. Control logic will be in trouble....
Nov 29, 2007 | Brother MFC 420CN All-In-One InkJet...
Model mfc-240c
did you replace with brother carts, are you sure machine is refering to mag and yellew being mt, not the other ones, power off, remove all carts, power on , reinsert carts one at a time answer machine when prompted. these cartridges are deemed empty even when they look like they have a little ink left. Try putting in 4 new brother inks
Nov 09, 2007 | Brother Multi-Function Center MFC-240C...
Won't say it has a new cartridge of yellow
unplug mfc from power. take all carts out of the assy. wait two minutes. plug in power. machine demands carts. reinsert one cart after another which will be asked and displayed from machine. For the "old" ones push 2 (no change) for yellow 1 (yes). Machine should start cleaning afterwards. Do only change carts when machine STOPPS printing! Otherwise the eeprom logic will be fooled (and give wrong info!)
Oct 05, 2007 | Brother MFC 420CN All-In-One InkJet...
Brothers 420 cn printer question
try with clean the catridge nozzel and see if it is not working then you replace the catridge. bye
Sep 24, 2007 | Brother MFC-3240C All-In-One InkJet...
Near empty yellow
Do print until the message EMPTY (Printer stopps printing). DO NOT refill or change cart when message is shown: NEAR EMPTY! You fool the printers logic. Machine counts down the rest of the ink in the cart. When you refill at that moment the counter is disoriented! To clear the counter: Unplug powercord. Take carts out. Wait 3 min. Plug in power. Machine demands carts. Do use carts at full level (refill before you put them in). Works normal afterwards.
Sep 03, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-5440CN All-In-One InkJet Printer Logo
501 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
