Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Leaking Water on Inside of Refrigerator/Ice Buildup in Freezer
This is an ongoing problem. In each case, I take apart the inside of the freezer and melt/remove ice, and clear the drain hole. (I also run a chlorine bleach/water solution through the drain after it is cleared). As the refrigerator has aged, the time between 'defrostings' has decreased to once every 2-3 months.
I know this is a design flaw, but is there a better solution than just defrosting the freezer/drain repeatedly?
Kenmore Model No: 72262100
Mfg Date: 02/2002
Thanks,
A Micozzi
Akron, OH
2 Suggested Answers
SOURCE: Water leaking inside refrigerator
Its the clogged defrost drain. I have the same problem. I just cant find the drain
Posted on Jun 07, 2008
My freezer door wont open, feels locked on one side. water is leaking underneath
Just answered a similar question about this but with the water leaking in this one, I think the door got wedged open slightly and you now have an excessive ice buildup on the inside of the freezer causing the door to stick from the ice buildup. You may need to pull hard to break loose the ice and when you get the door open clean all excessive ice from around the door seal area. Packages inside may need to be re- arranged so door closed properly.
Mar 05, 2015 | GE Profile Stainless Bottom-Freezer...
Jenn Air JTB2488AE Freezer Top refrigerator. Water puddles inside the refrigerator space beneath the vegetable crispers. The ice maker has been turned off and the water still appears. The amount of water...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 04, 2010 | Jenn-Air Refrigerators
Water leaking from under the freezer
Until defrosting the block of ice you canot see if is a hole or crack in the bottom. But I suppose is leaking from the door gasket under the pressure of the ice inside. Anyway, if you want to keep alife your refrigerator, better unplug it, defrosting and clean it before complete annihilation.
Sep 10, 2017 | Frigidaire Refrigerators
Ice buildup from water feeding the ice maker
Are you certain that the ice build-up is actually originating from the water flow into the icemaker? If ice is built-up on the rear freezer panel, then your problem is more than likely a defrost component issue (defrost thermostat or defrost heater(s). If the ice is built-up on the side wall of the freezer near the icemaker, then water is probably being diverted inside the water inlet tubing that goes into the icemaker. This diversion is usually caused by an accumulation of ice inside the water inlet tubing. You will probably need to remove the icemaker in order to glance inside the water inlet tubing to see if ice is in fact inside the tubing. If so, take a screw driver or other object that won't puncture the tubing and remove the ice.
Contact an appliance service company if the ice is on the rear freezer panel.
Feb 17, 2010 | GE GSH25JFR Side by Side Refrigerator
Water leaking inside freezer and refrigerator.
you have a clogged drain tube in the freezer compartment. it is frozen with ice and as the unit goes in to a defrost cycle the water has no place to go. you can fix it the easy way, just unplug the unit and let it defrost. this will take care of your issue.
Oct 19, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
The lines inside my refrigerator freeze up with ice buildup
Replace the defrost heater and defrost thermostat in the freezer section. They are located behind the freezer panel.
Jul 14, 2009 | GE GSH25JFR Side by Side Refrigerator
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking from ice/water dispenser
hi there,
you may have a kink in the water line leading to the icemaker. the leak is due to warm water entering the icemaker itself. i would also check the water valve in the icemaker itself and ice actuators or paddles to any breakage.
Sep 04, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Jun 06, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
166 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
