Question about Vacuums
On Solis Master 5000. Part of brew unit is now obstructing recepticle that collects spent grounds. Brew unit is now jammed in and cannot be removed to allow viewing of the problem. Any ideas ?
  • 787 Answers
How exactly did this happen?
Posted on May 03, 2010
How do I get a manual for my Mr Coffee BVMCPSTX91-WN? the clean light is on and I don't how how to clean it or how to get the light off
The Mr Coffee web site has the manual on the product page: http://www.mrcoffee.com/coffee-makers/mr.-coffee-optimal-brew-10-cup-thermal-coffeemaker-black/BVMC-PSTX91.html . Click on the Service and Support tab. The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-mr-coffee-Site/Sites-mr-coffee-Library/default/v1426159971356/documents/instruction-manuals/BVMC-PSTX91_43_72624326.PDF . (You'll need Adobe Reader or a similar program to print the manual.)
The Clean light will come on when the Clean button is held. It won't go off until the cleaning cycle is complete; it's completely automated. You need 4 cups (20 oz.) of white vinegar or the Mr. Coffee Cleaner (diluted as directed on the package). Make sure to remove the water filter disk from the unit before cleaning. Pour the vinegar or cleaning solution into the reservoir into the reservoir. Put in a paper coffee filter or the permanent filter into the brew basket and slide it into place. Put the empty decanter in place. Now you should press the Clean button until the Clean light comes on. The unit should slow brew 3 cups of the cleaning solution and then pause for about 30 minutes while the Clean light remains on. It should then brew the remaining solution. After the cycle finishes, the Clean light should go off. Afterwards, you need to empty the decanter and rinse it with clean water. Fill the reservoir with fresh, clean water. Then replace the decanter. The cycle could take an hour.
I hope this helps.
(some brewing systems light the Clean lamp when it's time to clean the unit after lime deposits build up. To my knowledge, most of the Mr. Coffee brewers do not.)
Mar 12, 2015 | Sunbeam MR.COFFE 12CUP P/N/PAUSE,CHROM"
My brew station leaks water all over the counter top before it is brewed.
Mine Too! So frustrating. I have to take out the coffee filter, then remove the piece that it sets in. Make sure and clean the spring and the hole in the bottom. This seems to cure the problem until the next time. It seems to get plugged up quickly. I have learned to rinse it out every time I make coffee.
Feb 12, 2015 | Hamilton Beach Brew Station 12 Cup 48465
Coffee pot is not brewing.. it says to de-scale
Clean any residual coffee grounds from it and then pour in a 50/50 mix of water and white vinegar, and brew. Then repeat with just water to rinse.
Aug 16, 2011 | Vacuums
Cannot get the brewer component out of the machine to clean out the dreg tray in the Coffee machine - instruction manual is very unclear and poorly translated.
The brew group could be out of alignment. Perhaps try turning the machine on, then close the service door. The brew group should realign automatically, allowing you to then remove the dreg drawer (tray).
Try removing the brew group after the drawer is out of the way.
May 11, 2011 | Vacuums
I have a coffee maker that makes 36 cups of coffee. How many cups of ground coffee should I use to brew 36 cups?
I would ordinarily use half the amount of scoops of coffee as the amount of cups the coffee maker makes. A scoop being a Tablespoon of ground coffee. Less if you want it weak and one or two more if you want it very strong.
Apr 09, 2011 | Vacuums
My CJX Series decided not to brew! I checked the manual's troubleshooting, (The coffee is not brewing) everything is correct! The unit has power and the light comes on, will not start brewing cycle.
heating elements in coffee makers have an internal thermal protection device to locate it access the bottom cover find the wires leading to the element you will find on one of the wires a silver bullet shaped device this is the culprit, you can check with an ohm meter to verify the device is defective of open reading, go to your local appliance repair place with the defective unit in hand, perchance a replacement unit and 2 securing rings to crimp the new replacement back on the wires, reassemble and enjoy your coffee good luck about 8 dollars max...
Feb 28, 2011 | Vacuums
I have a Hamilton Beach 6 cup brew station and it has stopped taking the water from the tank and making any coffee. It just sits in the tank making noise like it is working but nothing happens. Thanks...
unplug it,empty contents
put 2 cups white vinegar in tank , plug in and start brew cycle.
discard vinegar and run 2 tankfuls of water through to remove vinegar taste
Jan 08, 2011 | Vacuums
Problem is you can have the maker plugged in but you can't manually brew the coffee. The switch will not engage to brew the coffee. Stainless Steel, Programmable Cuisinart CUI DCC 2000 model.
I have this model.
I'm not sure if you mean if it won't brew manually or not at all.
Ours failed because the thermistor failed due to the fact that the heater element was badly calcified (calcium deposits). It would come on for a bit, then stop brewing... then it just stopped altogether. I replaced the two thermistors that are in series and it works fine.
The bad news: Cuisinart cruelly used security screws to thwart repairs. The screws are on the bottom and deeply recessed. Thus aside, this coffeemaker is a bugger to dismantle but it can be done after you remove the screws.
Being that I had nothing to lose, I drilled these out and replaced them later.
Jan 07, 2011 | Vacuums
Poor flow takes two cycles to brew one cup. Heater working etc. Something stuck inside inner tube? Sucking air somewhere? can it be dis assembled?
This problem is usually caused by calcium carbonate deposits from hard water collecting in the thermal pump mechanism. The fix is to make a 1/2 pot mixture of white vinegar and cold water (about 50:50) and run through several times. Let cool off each time, and use a clean filter to catch the deposits that are removed. Finally, run several pots of cold water to wash out the vinegar taste. Hope this helps!
Jun 25, 2010 | Vacuums
Vacuums Logo
14 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
