Question about HP 48G Graphic Calculator
Calculator will not turn on. Batteries are good.
If I keep pushing the button and messing with it, it will turn on and work fine. Suggestions? Bad ON switch?
    Sergeant:
    Champion:
  • 387 Answers
Hi
with this model you need to change the all keypad it one unit and canot be open and fixed
the price for a Keypad is $40 no new keypad only used no more new parts for this model
ecrdn@yahoo.com
Jack
Posted on Oct 23, 2010
The Stat button is stuck down, have tried popping up with a paper clip but no good. Any suggestions, none of the other buttons will work with the STAT button stuck!
Hi
take out all 4 batteries take alcohol 2 drops on the button
push the button a few times it should help unless there is glue inside than yo must open the calc and clean all the buttons
Sep 12, 2012 | Texas Instruments TI-83 Plus Calculator
Ti 82 just displays a blue screen and charcters are all messed up.
Put new Batteries in, then Hold down the del button for 45 seconds. After that Turn On The Calculator Then push 2nd Down and it should go back to normal
Aug 18, 2012 | Texas Instruments TI-82 Calculator
TI-83 Plus Silver Edition problem
These instructions are from education.ti.org, and worked for me.
1) Take out one of the AAA batteries
2) Hold down the CLEAR button
3) Put the AAA battery back in while still holding down the CLEAR button
4) Let go of the CLEAR button and turn the calculator ON
5) Press CLEAR to get rid of the error message.
Then you should be good! All the applications on my calculator were still intact, so despite the error message, the RAM was never actually cleared.
Oct 20, 2008 | Texas Instruments TI-83 Plus Calculator
Screen fully black
Black-Screen/Black-Pixel Fix for TI-Calculator
This will erase all memory and reset defaults.
1. Remove 1 AAA Battery
2. Press and Hold 'ON' for 30 seconds
3. Replace AAA Battery
4. Adjust Contrast to appropriate level
If this fails, try again with ALL Batteries removed including
the backup Lithium Battery.
If all else fails, try the following reset procedure:
1. Remove ALL Batteries (inc. Backup)
2. Let Calculator sit with no batteries for 2~4 hours.
3. Hold 'ON' for 30 seconds.
4. Replace all the batteries (May be good idea to use new batteries
just in case old ones were dead)
5. Turn on Calculator
6. Change Contrast to appropriate level
- Remember to use correct batteries or calculator may not work. The
correct batteries are Alkaline, Rechargable Batteries are TOO WEAK,
Heavy Duty batteries are TOO STRONG.
Oct 09, 2008 | Texas Instruments TI-89 Calculator
My Ti83 silver edition will not turn on.
I'm not sure if this will help you patchesb7; it sounds like your calculator is having issues :(
This will help others whose calculators suddenly won't turn on anymore, even after changing the batteries.
Note:
This will return the calculator to the way it was when you got it out of the package. Any data or programs have stored since will be lost.
Step 1: Remove all four AAA batteries.
Note: You will have to hold down the CLEAR button while doing Steps 2 and 3. Do not let go until after you have pushed ON in Step 3. I found this easiest to do by holding the calculator upside in my left hand with my pointer finger holding the CLEAR button so the ON button was easier to access.
Step 2: Hold down the CLEAR button (located under the arrow keys) and reinstall the AAA batteries.
Step 3: Press ON button and then let go of both buttons. The screen should say the RAM has been cleared. Press CLEAR to continue.
Aug 24, 2008 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus Problem
Batteries:
Make sure to replace the "battery backup" too the little lithium ion battery
Try Adjusting contrast:
Hold down "[2nd]" key press up or down arrow repeatedly to lighten or darken contrast.
First attempt reseting:
Step 1: Remove all the batteries
Step 2: Hold "Clear" key down
Step 3: Still holding "Clear" key reinstall batteries
Step 4: Still holding "Clear" key press "On" key until home screen is displayed.
Second shot reseting:
remove all batteries including lithium ion (backup battery), wait 3 hours and reinstall batteries.
Third Shot reseting:
Step 1: Remove a battery
Step 2: Hold down "DEL" key reinstall battery
Step 3: Possible msg pops up saying "Waiting ... Please install software" IGNORE msg and take out battery again
Step 4: Reinstall battery do not hold down "DEL" key
reseting will cause the handheld to loose all of its stored memory.
Hope that helps!
Jan 29, 2008 | Texas Instruments TI-83 Plus Calculator
WON'T TURN OFF
Under your On button might be some dirt, that keeps triggering the On button, and thus, keeps it on.
Clean under the On button
Oct 09, 2007 | Texas Instruments TI-89 Calculator
Turns on but does not respond to buttons
Try replacing both the AAA batteries and the back-up batteries. This should probably fix the problem. If not, contact the guys over at Texas Instruments for replacement parts if you need them.
Mar 12, 2007 | Texas Instruments TI-83 Plus Calculator
HP 48G Graphic Calculator Logo
99 people viewed this question
Seeker5211
Seeker5211
