Question about Clarion DB175MP CD Player
Clarion DB175 cd player
I got an error 3 when I tried to play a cd-r. Can you tell me what it means and where I can get a list of errors.
  • peterpolak Sep 16, 2008
    i can't play cd's in my clarion db175mp. I was on vacation. The car was pareked for a couple of months, battery out. When I came back, I started the car, put a cd in. (one of the cd's that I was playing before) and the display says: error six. Someone said here, that it suppose to mean disc upside down, or can't read disc. Why not?
    Does that mean that my clarion is basically f...ed and i have to buy another car stereo? thank you upfront for some input...
The Clarion manual lists 3 error messages.
Error 2-A disk is caught inside the CD deck and is not ejected.
Error 3-A disk cannot be played due to scratches, etc.
Error 6-A disc is loaded upside-down and cannot be played.
Good Luck.
Posted on Apr 19, 2008
SOURCE:
Shows Error 2 however no error 2 listed in book
Error 2 on this set indicates that a DVD/CD is jammed inside the player and will not eject. If you can't eject it, you will probably have to open it up and remove the disc manually.
Error 2 when using a Memory Stick indicates that the stick is not supported.
According to the manual, some memory sticks are not supported.
Also, if you have more than 8 nested folder levels or 512 total folders, the stick will not work.
The Clarion will only play ACC, MP3 or WMA files. No DRM protected files can be played.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 13, 2011 | Clarion FZ709E Car CD USB MP3 Player
Clarion VRX925VD gives me an error6 code when trying to play dvd's
Error 6.CD error message. Could not read data from disc because it is upside-down. it's mean the problem caused by the optical lens of your DVD..you can try to clean first the surface of the lens..You can clean the lens with rubbing alcohol or one of the lens cleaner discs. If that doesn't work, I would guess the pickup is bad. At which point you would be better off just buying a new CD mech. But, if I remember correctly, most of Clarion's CD mech's are really expensive; 70-160$
It's up to you to decide if you want to replace it or not. Hopefully help
Oct 25, 2010 | Clarion (VRX765VD) Car DVD Player
My cd plays then doesn't and says error3 i don't have a manual the stereo is clarion ADX5655Rz. i alsocan't seem to set any time on the clock.
Error 3.CD error message.
The pick-up is out of focus during play mode due to scratches on the disc or contamination.
This can be a disc format error (try a previously known working disc)
Or the laser may be out of alignment. - in this case professional repair/cleaning/alignment is recommended.
Thanks for using FixYA - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 28, 2009 | Clarion ADX-5655RZ CD / Cassette Player
Error 3
plug of car battery for 5 minutes then reconnected again with switch of CD player .
Nov 24, 2009 | Clarion DXZ665MP CD Player
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
Car MP3 player error
I believe that error 6 means incompatable disc format or disc read error.
Jun 12, 2008 | Clarion Car Audio & Video
Error code 6 & error code 4
hi try first to insert a clean up CD, and test your Cd player with an original CD, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
sserpentio
May 21, 2008 | Clarion DXZ438R CD Player
Error 6 & 4 it means laser is not reading the disc and unforutunally you need to replace the pick up laser assy.
You can get it from pacparts.com,but I reccomend you to take to a proffessional tech because this is a "static sensitive" item.
Dec 08, 2007 | Clarion DX-515 CD Player
Cd player
usually error 06 means a dirty lens cap, there for it cannot read the cd. try buying a cleaning disk
Aug 26, 2007 | Clarion DXZ365MP CD Player
Clarion DB175MP CD Player Logo
806 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
