Question about Remington Electric Chain Saw
How tight should the chain be? Seems too loose to me, but I think it is as tight as I can get it. It is a remington 14" chainsaw.
    President:
  • 2,220 Answers
If a solid nose bar it needs to be slightly more slack. Judging by the number of requests for adjustment repair kits I suspect it could be beefier initially too.
In answer to your question, with a solid nose bar the chain at the center bottom should just touch. If sprocket nose touch plus 1/8 turn tighter.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 03, 2010
  • dontbother10
    dontbother10 May 03, 2010
    Hold the nose of the bar up while making adjustments and tightening the bar nuts else it will slacken quickly.
I changed the chainsaw chain on my Blue Max chainsaw. The kick-back seems to be locked
Bob take the chain off again and remember to tighten the tensioning bar so that the chain is slightly loose. Enough to pull a few cm of the bottom just to stop it being tight.
Aug 30, 2014 | BLUE MAX 14" Chainsaw replacement...
Chain came off remington chainsaw now will not run
If you can't move the chain around the bar it is too tight.Back off the tension.Put on some gloves and see if it will move. If it was so loose that it came off the driver links could have been damaged and you will need to replace the chain because the drivers have burs on the side of them and are to wide to slide in the grove of the bar
Nov 09, 2012 | Remington 16" Electric Chain Saw
I have a Remington 14' Limb n' Trim electric chainsaw. There is an oil reservoir (I think - it has a little rubber cap) and I am not sure if it is for motor oil. If it is, what type of oil should I use?
jmccabe2465-
The reservoir is for bar chain oil, which all chain saws require to allow the chain to operate smoothly and reduce heat build-up from friction.
Hope this helps.
Regards,
DIYpro
May 04, 2011 | Remington Electric Chain Saw
The chain on the 16 in chain saw keep slipping. Seems the thumb screw will not stay tight? Who can check this and fix?
First thing I would do would be to loosen the thumb screw fully so the chain is as loose as you can get it Next, loosen the chain bar and pull it out as far as possible which will take up the slack in the chain itself. Re tighten the chain bar. Afterward, you can perform detailed adjustment on the chain by playing with the thumb screw.
This solution has always worked for me and my various chainsaws.
Apr 12, 2011 | Remington 16" Electric Chain Saw
Remington 14" Electric Chain Saw Assembled 1.5 Peak: I just wanted to know what type of oil to put in t...
I have been using regular chainsaw oil and I think it works ok. I inherited one of these and would like to find a spare chain and also a manual. Can you give me any info? Thanks
Tim
May 17, 2010 | Desa International Remington 14" Electric...
I need to know the chain size for my Remington 14" electric chainsaw, Model EL-1
50 drive links; 3/8 pitch; and 0.050 gauge if an original 14" bar your, choose your chain here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Input "Remington; EL-1; 14"; All; All; All"
The one installed is probably green (low chance of kickback), all of them will work provided it is the original bar.
Lou
May 02, 2010 | Remington Electric Chain Saw
14" Remington chain replacement
I input "Remington; EL-1; 14"; All; All; All" here:
It returned "91VG050G, 91VX050G or 91VXL050G". Please read the triangular warning placards. The original chain is most likely green.
Column 4 says a 14" chain has 50 drive links (the part in the bar groove". Please count them, if you get a different number try a different length bar. The Oregon part number can be ordered on line or if given to a local merchant fabricated in their facility.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 11, 2010 | Remington Electric Chain Saw
I have a Remington Electric Chain Saw and have lost the manual. Where can I get one? Model No. M15014US 14'' Bar 114731-01S Chain 114735-01S I have tried searching the Web for one and can't get a...
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
Enter M15014US (your saw) in the “Search for your unit by Model” window. You can find both an Operator's Manual and IPL. I recommend you download both.
Item 4 lists available bars for your saw, a 14" bar for your saw is pn 114731-01S, $17.85 if available.
Item 5 lists available chains for your saw, a 14" chain for your saw is pn 114735-01S updates to M14SC
, $12.95 if available. You can probably take your chain to a neighborhood chainsaw shop and have a replacement made cheaper.
Remington has ceased production and replacement parts are limited to what is on hand. HTH
Lou
Oct 29, 2009 | Remington Electric Chain Saw
Remington 16" Mod EL7 need Guard, hand, front.
Any parts or assistance available can be found here:
Remington.com
http://www.remingtonpowertools.com/find_manual.cgi
I think what you seek is proprietary and the company has folded. GL
Lou
Sep 16, 2009 | Desa International Remington 14" Electric...
Remington 14 inch electric chainsaw replacement blades
You can 14SC available online at www.masterparts.net you also can contact them toll free at 800-446-1446. They ship parts out very fast.
May 25, 2009 | Desa International Remington 14" Electric...
Remington Electric Chain Saw  Logo
73 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
