Question about Belling XOU590 Electric Double Oven
The clock display shows FU.14 and thw fan oven
The clock display shows FU.14 and the fan oven won't work on a belling electric double oven
amgm
  • 32 Answers
SOURCE: trying to set oven timer
Hi, switch off the mains for the cooker, wait for about 15 seconds then press the 2 buttons on the left and hold them, and then press the - or + button to set the time.
Cheers
Posted on Feb 19, 2009
murdozzz2
  • 75 Answers
SOURCE: bosch electric single oven (hbn 4305)
hi there have you cheked that your timer is not set to auto function
Posted on Dec 09, 2007
dutchman05
  • 487 Answers
SOURCE: timer clock on bosch double oven
Please follow this link and download the instructions.
Manual
Please rate me as FIXYA
Posted on Apr 29, 2008
barkencoa
  • 3463 Answers
SOURCE: noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Posted on Feb 09, 2009
barkencoa
  • 3463 Answers
SOURCE: My Belling oven has no heat, but the fan &
If the fan is working o/k, then there is little doubt that the oven element has failed.
This is quite common with fan assisted ovens.
The element is usually located at the rear of the oven compartment behind a removeable cover.
Posted on Mar 29, 2010
Testimonial: "Thanks "
None of the buttons are working and clock is not displaying. Just happened last night after use and the only thing working was fan.
Um, is the fan working now? No? >> check power to oven
Circuit tripped? >> check for electrical fault / mice in wires
Oct 16, 2013 | Maytag 30" Built-In Double Electric Wall...
We have Smeg DUCO8CSS double electric oven. Bottom oven does not work, clock is blank and fan doesn't work. Top oven OK ! - though usually the fan runs when this is operating.
If the clock is blank, then the main oven will not work, as the clock timer is linked with the main oven.
You need to to get the clock working, or you will not be able to use the main oven
Jan 19, 2010 | Smeg DO81CSS Electric Double Oven
Fan oven option not functioning on main oven, its a Belling synergie multifunction oven, about 5 years old
On my Belling it was the oven multi function switch that was faulty. I replaced it - carefully (lots of coloured wires) and it works fine now. Hope this helps
Oct 24, 2009 | Belling XOU590 Electric Double Oven
My large main oven will not work on my AEG U7101- 4- M. The small second over/grill is working fine.
Is the clock set? The display must show the correct time and must not be set to automatic cooking.
If the light comes on and the fan is working then the clock is set. If there is no heat then the element behind the cover and surrounding the fan is probably open circuit. This can be accessed without needing to remove the oven from the carcass.
Good luck
Nov 27, 2008 | AEG U7101-4 Electric Double Oven
DOUBLE OVEN,GAGGENAU
this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
ring 08705 678910 for service and advise
good luck
Dec 16, 2007 | Gaggenau EB 270/271 Electric Single Oven
My fan doesn't work
fan not fixable - replace. possible be that there is crap jamming the fan.check that the fan blade turns freely
Mar 13, 2007 | Belling XOU492 Electric Double Oven
Belling XOU590 Electric Double Oven Logo
226 people viewed this question
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
