Question about Garden
Echo hedge trimmers, won't start put a little fuel in the throttle body it starts then dies out> i think its not getting fuel< and the fuel to air ratio is off
  • 10,865 Answers
Hello. Do this. Go to the auto parts store or even a walmart and purchase a can of starting fluid. Spray some starter fluid into the air intake and start it up. Then keep giving it short blasts of starter fluid for a couple of minutes until it takes off on the gasoline. Joe
Posted on May 03, 2010
Echo hedge trimmer replaced carburator still wont start getting spark
Hi, There are 3 things that you need for the motor to start.
1) Fuel 2) Air 3) Spark. Check all 3 and it should run. Good luck.
Jul 27, 2015 | Echo Garden
Echo HC-150 rebuilt the carb, and now the primer bulb sticks and engine won't start
Try to pressure test the carb to see if you have an internal leak. If it won't hold pressure then it is junk and needs to be replaced. If it holds then double check that you didn't accidently put the gaskets and diaphragm in wrong. If it holds and still doesn't work right replace the carb anyway. They are relatively inexpensive
Jan 20, 2013 | Echo HC-150, Hedge Trimmer 20"
Km90 starts but won't run on full revs
The KM90 is a 4mix engine that has valves. You may need to check the valve clearance, using the clearance tool.
Aug 28, 2012 | Stihl Used Km 90r Km90r Pole Hedge Trimmer
I have a echo HC-150 it won't stay on boggs down
Hi, either the carby is flooding and requires a carby kit or the spark arrestor or outlet in the muffler is blocked. Hope this helps, regards Phil.
Jul 18, 2011 | Echo Garden
Echo manuals hard starting hedge trimmer 1500
all echo manuals are available on line at echo.com for free
Nov 01, 2009 | Echo 21.2 CC Shafted Hedge Trimmer
Cleaned carb on echo headge trimmer how do i redo
It will depend on what type of carburetor you have. You can go to this website and enter your model and it should give you the correct settings. If you cannot find the info, start with each about 1 1/2 turns out and go from there. A little hit and miss and you will figure the correct setting. When setting the high speed, you want to hold the throttle wide open and slowly adjust the screw. It will suddenly start to run very smoothly, and that's a good setting for the high speed.
http://www.echo-usa.com/faqs.asp
Oct 24, 2009 | Echo Garden
Putting gears back in echo trimmer
go to www.echo-usa.com/documentation.asp youll need your model number and you can get a breakdown of your machine which should help you to get it back together a little easier.
Dec 23, 2008 | ECHO, Inc. 20 In. Double Sided Hedge...
Garden Logo
247 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
