Question about Sony HDR-HC1 Mini DV Digital Camcorder
HDR-HC1 LCD screen is only illuminated when rotated and pushed back to camera body. Where can I get service manual?
Http://www.eserviceinfo.com/download.php?fileid=42561
You will need to download all 6 parts and then extract the files.
Posted on May 31, 2010
Lcd screen only works when flipped over and against the camera
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Feb 06, 2011 | Sony HDR-HC1 Mini DV Digital Camcorder
Sony HDR-HC1 The buttons on the touch panel do not work at all. The manual says to reset the calibration but this is impossible as you have to access the calbration through the buttons on the touch...
The most likely cause for this is a damaged or defective flexible ribbon connector between the LCD and the camera body and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to usually be repaired by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Sep 10, 2010 | Sony HDR-HC1 Mini DV Digital Camcorder
The lcd screen is lit up but none of the touch screen works so i can't access the menu, yet i can still record, but on playback i can't press play rewind etc
touch screen deactivated? checked manual?
to activate you have to put her in play back mode by moving that switch
so please read some basic instruction or let somebody demo it to you :-)
May 26, 2010 | Sony HDR-HC1 Mini DV Digital Camcorder
The lcd screen is almost black/ very dark, but i still see that it works. it looks like the light is out. sony hdr hc1
The LCD screen may be turned OFF. To turn the LCD backlight off or on, press and hold the DISPLAY/BATT INFO button for a few seconds. After the backlight has turned off or on, release the button.
Aug 07, 2009 | Sony Handycam HDR-HC1E HDV Digital...
How do you fix the touch screen on my hdv 1080i mini dv,
touchscreen problem on the HDR-HC1 is usually caused by a broken flex cable. service manual is a must-have; it illustrates the correct disassembly and replacement procedures for the cables.
Jun 05, 2009 | Sony HDR-HC1 Mini DV Digital Camcorder
Touch panel menu unaccessible
Me too! The camera was working perfectly until yesterday and when I turned it on today, it selectively ignores some buttons on the screen - and pressing the "Menu" gives me nothing. I've tried to reset it through that pin hole button, but it just resets the machine back to its default.
Dec 13, 2007 | Sony HDR-HC1 Mini DV Digital Camcorder
HDR-HC1 power keeps cycling
I had this exact problem, and the cycling would stop after about 30 sec. and then function properly. I believe a circuit was confused, mainly because I used an older battery and let it run out till the batt was dead - accidently - and when I put in a fresh batt, it no longer cycled and works perfectly to this day.
Now if I can get my computer to recognize the camera via firewire, I'd be golden.
Mar 07, 2007 | Sony HDR-HC1 Mini DV Digital Camcorder
Sony HDR-HC1 Mini DV Digital Camcorder Logo
660 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
