Question about Kenmore 23812 Top Load Washer
Have to trip washer lid safety switch with something more substantial than little 'plunger' attached to the washer lid to get washer to drain and spin during rinse cycle. do i need to replace the safety switch or the 'plunger'?
    President:
  • 1,937 Answers
Removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet to replace it.
It comes as a complete unit and you can't replace just the plunger.
Posted on May 03, 2010
Changed lid lock switch and won't work
Is the plunger attached to the lid? It is the little prong that goes into the lid switch.
Apr 05, 2014 | Whirlpool WTW4800XQ Washer
Ge stackable washer/dryer wont spin-drain
This involves the spin lid switch
Twist timer very fast a few times and stop it on spin with the lid closed. Wiggle the timer to get the points to connect. Even if you
just get a little bump then its the timer.
If none of this works then it is the timer plus maybe something else contributing.
You can tape the two wires to the switch together and it'll work just fine
Also check the plunger on the lid to see if it is not broken off
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 10, 2010 | GE Spacemaker WSLP1100D Top Load Washer
My washer doent drain and spin.
IMUFO2
Sep 10, 2010 | Maytag PAV2300 Top Load Washer
My washer will not spin the water out.
IMUFO2
Also check drain hose for kink.
Sep 10, 2010 | Washing Machines
Washer fills up agitates then when it should drain ,nothing.motor dosent come on to pump water out.
In most cases all brands will fill and agitate with the lid open, but will not drain or spin with the lid up.
It sounds to me like your lid switch is either bad or misaligned.
The first thing to check is the actuator plunger on the lid. Make sure it hasn't fallen or been broken off. Look for a piece hanging down from the lid that looks like a little finger that when the lid is closed, would hit and depress the lid switch ,which is under the top of the washer.
If it looks like the actuator is good shape then the lid switch is either bad or misaligned. Take a pencil or a bic pen and depress the lid switch. Making sure your washer is plugged in and in the spin mode. If it begins to rotate to spin and drain then see if a screw has fallen out that holds it in place or became loose not letting the actuator hit it correctly.
If the switch does not seem loose and it will not start the machine when depressed with a pencil it is probably time to change it out.
Apr 09, 2010 | Kenmore 24032\24036 Top Load Washer
It fills up and won't agitate. It seems taht
not advisable to bypass switch this is a safety device to prevent injury your switch is adjustable or repairable by lifting the hob locating switch and doing necessary repair or adjustment please do not bypass think of your safety and the safety of others
Nov 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water is now filling, washing going round in drum but not rinsing or spinning.
Spinning and Rinsing require a safety switch to be enabled by the closing of the washers lid.
Check around your lid and washer lid opening to find the mechanism that is used to activate the safety switch mounted just under the lid opening inside your machine. Sometimes it is a plastic plunger(protrusion) on the lid that mates with and opening(hole) in the machine around the lid opening to cause this switch to close. Other times it is on the hinge side of the
lid and the protrusion is formed right into the metal of the lid itself to push a plunger on the hinge side to close this safety switch.
Most spinning problems on machines are cause by this lid safety switch. Washing machines cannot spin if the lid is not closed and this safety switch is not working to switch power to the spinning motor.
Aug 30, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Spin cycle doesn't spin out
there is a switch which detects the lid being closed. if this switch is bad the spin cycle will not engage. also, there is a little actuator which enables this switch thru a hole in the top and if has gotten broken off will also cause this problem. look for a little door at lid level and staying clear of the washer push a small rod into this hole. if spin starts the actuator is gone, if not the level switch is bad. make sure the function switch is in the spin position and activated.
Aug 30, 2009 | Kenmore Washing Machines
Defective lid switch I think
Sounds like your lid switch is ok .. u need to replace or adjust the plunger for the switch... below is a pic of the plunger.. sometimes u can get a little adjustment on the clip that pushs the plunger thats attached to the lid.. pic below
sounds like this is the part that has wore and shorten some...
also check the lid cam maybe able to wedge something behind to get more length out of the plunger heres a pic
Oct 27, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Kenmore 23812 Top Load Washer Logo
481 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
