Question about SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sansa shaker i used your suggestion and converted all the files to mp3, the shaker played a few songs and it stoped again, i went back to it and noticed that the wma files were still there so i deleted and just left the mp3 files....still it wont play, it keeps blinking as if it playing the songs but wont do anything please help... iibarragan@yahoo.com
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
THE SONGS I SYNCED WILL NOT PLAY ON MY SHAKER.
The Sansa Shaker supports only .mp3 and .wav file formats. It is possible that you have synced WMA or M4A audio files that have DRM protection. These formats are not supported by the SANSA SHAKER.
Songs purchased through Amazon or copied from your music collection in mp3 format will play on your SHAKER.
Mar 07, 2011 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
My sansa shaker is just not playing any music
"Media Coder" is a free program you can download that will convert your songs on the shaker to MP3 files. I had the same problem. Make sure the shaker is plugged into computer so that you will be able to choose the songs on it to convert. Very easy to use. Just google "Media Coder" and you should find it.
Dec 30, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Hi my sansa shaker wont play music
The Sansa Shaker ONLY plays MP3's, I downloaded a bunch of .wma files and kept getting the uh-oh so I put on an mp3 I had a voila! it played. Bummer though. Guess I gotta figure out how to convert my music files for my daughter, or pitch this thing and buy one that will play any media file.
Dec 24, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
My shaker does not play all of the loaded songs.
I had the same problem. The songs that won't play are probably MP4 files and the shaker only plays MP3 files. You need to change the file format of the songs on the shaker to MP3 files. I downloaded "Media Coder" which was free and it converted all the songs on the shaker that wouldn't play to MP3 files and they play now. Google "Media Coder" and download the free program, it is very easy to use. I had the songs converted in about 2 minutes. Make sure the shaker is plugged into computer so that you can choose the files on the shaker to convert. Hope this helps.
Dec 23, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
My sansa shaker wont play songs it does the start up noise then shuts off i have tried replacing batteries and converting the songs from wma to mp3 and still nothing!!!! :-(
Make sure the songs are in the right file format first. I would only download songs that are in mp3 format for starters - sounds like you did this already. If it is still not playing, follow the reset method that the manual suggests. If it is still not working, it may be defective. These "windowless" players are the most difficult to use, because there is no on-screen display to let you know what's going on.
-Tha Mp3 Doctor
Dec 07, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sansa shaker
SHAKER ONLY TAKES MP3 FORMAT!!!!!
Use this site to change your format to the correct one for the sansa shaker. This is the only way to load songs from your cds MWA will not work at all. Must convert all files to MWA use site below
http://www.wma-mp3.org/
Dec 25, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sansa shaker not playing
Funny I found this forum because I've been having the same problem. My understanding is that subscription services (yahoo music, iTunes, etc.) don't come in an mp3 file format. You can, however, add songs from cd's you own.
Here's a link you might find helpful. It's from the Sansa Forums. One of the posters describes how you can convert files. I don't know how complicated it is. Good luck! :)
http://forums.sandisk.com/sansa/board/message?board.id=shaker&thread.id=121
I understand your frustration! I've been having the same problem. I just wasted TWO HOURS trying to get music to download onto this Shaker. The extra $40 for a better device would have been worth it! I can't afford to buy all the cd's that I'd need to fill this player with the songs my son likes. I'm thinking of bringing it back!
Dec 18, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sansa shaker files write-protected
Dec 10, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sansa shaker
How are you transferring the music to your device. thru Windows Media Player, or Rhapsody?
If so, I would suggest manually dragging and dropping the files onto the Shaker thru My Computer.
Also, the Shaker only supports MP3 files.
Best of Luck.
Oct 27, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
SanDisk Sansa Shaker SDMX9N-512 MP3 Player Logo
64 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
