Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Water leaking from freezer into refrigerator
Water leaks into the refigerator from the back of the freezer. there has also been water that has frozen on the freezer floor.
    President:
  • 949 Answers
This is most likely due to the defrost drain being restricted, here is a link to help explain how to correct the problem. Let me know if this helps. Thanks.
http://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
Posted on May 03, 2010
Why is water leaking at the bottom in front refigerators
Water leaking in the freezer and on the floor in the front of your refrigerator usually is caused by a blocked evaporator drain line.
Hope the video helps you understand what you will need to do to fix the problem.
Appliance 911 Sea Breeze
Leaking Refrigerators
Sep 29, 2015 | LG LRFD22850 Bottom Freezer Refrigerator...
Hotpoint. Water is leaking from behind light bulb
The drain hose in the back of your freezer is frozen shut. The water you see is coming from the defrost cycle. Turn off the refrigerator. Remove the floor from your freezer and remove/thaw all of the ice. Locate the drain in the back of the freezer. It may be behind the back panel. Thaw the drain until water flows freely through it. Reassemble the freezer, and you are back in business.
Oct 22, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refigerator is leaking
There are many types of leaks and where they begin. It is my understanding that you are speaking of the inside back of the refrigerator. Below is a link that covers many different ways they happen. So if I am mistaken by what you are saying please don't rate me low because your meaning was something different. Just tell me what the problem is an where. Thanks, Sea Breeze
click on link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Three year old Whirlpool Refigerator (ED5FHEXNB), water leaks from bottom of refigerator when outdoor garden hose water is turned on. Only leaks when outdoor garden hose is turned on. Water filter, Brita...
Hello it sounds like you have a leaking water hose which you need to find. maybe check first where it connects into the back of the unit.. Otherwise the fridge has a blocked drain in the freezer. cheers
May 15, 2009 | Refrigerators
REFRIGERATOR MOTOR CONTINUES TO RUN AND WATER IS LEAKING.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
u
Mar 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Water leaking
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezerr.
Dec 27, 2008 | Frigidaire FRS26R4A Side by Side...
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Water leaking inside
Unforturnately, I have the same problem. You have to take the bottom panel of you freezer off. You will have ice built up. You will have to remove the ice. In the back, there is a hole that drains to the drip pan, that has become frozen solid. I have this problem about every 30 days. I wish I knew how to fix the problem. My dad has the same refigerator freezer, it's a problem for him too.
Jun 16, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore refrigerator not cooling
Is there frost on the back wall? If so your coil is frozen up and you have a defrost problem. The water coming out of the freezer door could also be caused by the same problem.
May 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Water leaking from dispenser into refigerator/French door bottom freezer
IT IS PROBERLY THE HOLDING TANK / TUBES LEAKING TAKE LOWER CRISPERS OUT AND CHECK THERE ITS BEHIND THEM
Aug 26, 2007 | LG LRFD22850 Bottom Freezer Refrigerator...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
289 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
