Question about HP 2133 Notebook
No monitor display and wireless ligths off
When i turn on the laptop there is light light in the power button but the monitor is still black and the wireless light is off.
  • 109 Answers
The Memory chips / Ram has gone bad
I guess there are two ram chips on the mother board try to take off one ram at a time and turn on the pc
If it does'nt work replace the chips ..
Hope it works
All the best !!!
Posted on May 06, 2010
  • JULIUS SUNUWAR
    JULIUS SUNUWAR May 06, 2010
    sorry the solution is not for this issue ...did it by mistake
Black screen
first check your display in monitor with the help of vga cable attach your laptop in the monitor,if display comes in the monitor it means your screen faulty .or if display cant seen on monitor it means there is an fault on MOTHERBOARDS BGA CHIP.
Jan 29, 2014 | Lifetime Acer Aspire 4736Z Replacement...
My samsung RV511 laptop won't boot and the monitor keep on flashing on and off but the power indicator still ligths on
The monitor keeps flashing on and off? Or does your system keeps trying to reboot which causes the monitor to go on and off. Does the screen turn Blue before it goes off?
Apr 10, 2012 | Computers & Internet
Computer screen is black
you may check the lights on the keyboard if there are on. If not try to turn off the laptop and remove the cables and battery on it. Then press and hold power button for 5 secs. Reinsert the cables and battery on the laptop and then turn the power on. If the screen is black and there is no light on the keyboard, there might be a problem with the power supply or the motherboard on it. Try to call your pc provider for that. If the keyboard lits up, check the monitor if it has turn off.. Then if it cannot turned on, there might be a problem with the monitor display itself. Consult also your pc provider for such...
Dec 14, 2010 | Computers & Internet
Mylaptop turns on and runs but the screen is completely black. What do I do? The power button is on and the battery charging light is on but the screen doesnt come on at all. I can hear the laptop booting...
Connect an external monitor then power up both the monitor and laptop. If you get display on external monitor, you have 3 possible problem. First, LCD is bad, Second, CFL on your LCD is bad and Third, the cable connecting your motherboard and LCD is bad or the connection is loose. It is better to replace the whole LCD assembly than to repair.
If you have external monitor but still can't get a display, your problem may be on the motherboard.
Apr 13, 2010 | Sony VAIO (PCWA-A200)
How do i turn on wifi
F1 turn the status lights on or off. F2 turn the optional wireless network on or off. Warning: Radio frequency wireless communication can interfere with equipment on commercial aircraft. Current aviation regulations require wireless devices to be turned off while traveling in an airplane. 802.11G (also known as wireless Ethernet or Wifi) communication devices are examples of devices that provide wireless communication. Important: Your notebook came to you with the optional wireless network turned off.
F3 to enter Standby mode. Press the power button to leave Standby mode. F4 toggle the display in the following order:
  • Notebook display (default)
  • External monitor (if connected)
  • Both the notebook display and the external monitor (if an external monitor is connected)
F7 decrease the display brightness. F8 increase the display brightness. F9 play or pause a CD or DVD. F10 stop a CD or DVD. F11 play the previous track a CD or DVD. F12 play the next track of a CD or DVD. Scroll turn on Num Lock so you can use the numeric keypad. Press this key combination again to turn off Num Lock. The Num Lock status indicator appears when this function is turned on.
Feb 23, 2010 | Gateway 400SD4 Notebook
My Dell? E198WFP Flat Panel Monitor the gree ligth on the power botton not working
green light on means your monitor showing display.change your button .your monitor working properly.
Jan 15, 2010 | Dell VOSTRO SLIM TOWER and , MONITOR 19...
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
HP Pavillion dv6000 (dv6190eu) boot issues
take a look at the laptop by opening the screen all the way up and holding it up to light to see if perhaps, the inverter or backlight has gone out, just guessing here. If you can barely see the display then that's the problem.
Also you should try to hookup an external monitor to the VGA output on the laptop then turn the laptop on. See if you get video on the monitor and that will tell you if it's the backlight/inverter.
Updating drivers should not have anything to do with the display going out, however.
Mar 22, 2009 | AMD Athlon XP 2600+, 2.13 GHz...
Monitor screen stays black even though it's on
Remove the memory from your unit - power it up it should beep if full communication is still happening across your m/board. No beeps you board has died. if it beeps and your using two diffent memory modules just fitt one leave the battery out and power it up = if no display pull power swap out the memory and try again. if display occurrs you have a defective memory module - throw that failed unit away
glenn
Mar 07, 2009 | Compaq Computers & Internet
Wont post
after turning on wait for a moment.. about 5 mins. then press fn+f4
Jan 04, 2008 | Compaq Presario 700 470024-192 Notebook
HP 2133 Notebook Logo
151 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
