Question about JBL Eon15P-1 Main / Stereo Speaker
Low End popping issues with EON 15-P
15-P had low use-- after a few months was experiencing a popping on the low end of one of the speakers-- Paid $75 plus shipping to send to JBL to analyze and troubleshoot because it was under warranty-- JBL sent speaker back advising no issues with speaker- and suggested I check the signal connection which may be the cause of popping== Ran brand new cables to xlr connection-- Speaker works fine with the exception of occasional annoying "popping sounds that occur from the bass(low-end). Changed amplifier source, cables, xlr connectors, etc and still experiencing this issue.. Any one have any advice/possible solutions?? Thanks!
SOURCE: JBL EON 15 G2 clicks and pops
my son and i fixed an eon a decade ago that had this problem. we swept a sine wave through the audio spectrum and discovered it started barking somewhere around a low D on the piano.
Turns out the mains connection was intermittent right where it enters the eon from the wall. Soldered the ac power connections and the problem went away.
Posted on Sep 21, 2008
SOURCE: JBL Eon G2 Speaker
from our experience rebuilding woofers once the lead wires get pulled too much or start to strain you have been running too much power into the woofer and making the cone move too far in and out.You need to cut the input signal from your preamp down and cut the volume down on the speaker input on you eon. We keep seeing too many of these amped speakers blown from too much signal.
Posted on Nov 08, 2008
SOURCE: jbl eon
the eon woofer is designed to fit the small frame of the inside cabinet. The EV woofers look too deep to fit but you can try. I do think that the built in amps were set to work with only the JBL woofers so there might be a signal problem using the built in amp. The eon face seems to have their own screws to hold the grill so if they aren't holding you can drop some cement to help hold the srews in place. The front does not allow removal of the woofer so it seems whatever you do should not effect anything.
SOURCE: No low end on JBL EON G2
I would think that you have a blown woofer. Check around your area for a JBL service center.
Posted on Dec 19, 2008
budmrtn
  • 11361 Answers
SOURCE: what is is the output IC no for the high driver of jbl eon
Download service manual here:
http://www.free-service-manuals.com/JBL_EON15-G2_Service_Manual_L38587/
Posted on Nov 10, 2009
My JBL 510 high end pops intermittently
Damaged component/s at its main power amplifier stage circuit. Leaky capacitor/s can cause this fault, and locating the exact one is a skilled work indeed. It will be best to contact any service technician. This is not a user repairable fault. If you wish to get some details, visit the site linked here.
Electro help
Nov 15, 2014 | JBL EON 510 EON510 Powered PA Speaker
My right JBL EON 15 Slight buzz and hum occasionally for months. Now very low sound I smacked it and the sound came on strong tapped again and lost sound , hit again and all is well. Checked all...
Sounds like it could be a short or loose wire going to the speakers. You can try taking the case off to look, but chances are you are going to need to take it to a professional to get it looked at.
Mar 09, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Jbl eon g2 not giving any low sounds only tweeter works
open it up and check cables leading to sub (large speaker) they're notorious for falling off - getting banged around
Feb 17, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
We understand that your problem is: I have two jbl eon 15 two way (non powered) speakers. recently heard a loud crack through them (mic was not on)and since then my music and my voice now sounds really...
Likely a bass pin or tweeter has gone. Drop all on eq and then just turn bass/low up. Try each speaker separate. Then both together. They should sound exactly the same. Then repeat for high end. You'll find the suspect this way.
Mar 05, 2017 | JBL EON-1500 Main / Stereo Speaker
My JBL EON cuts out from time to time (usually when there is a lot of base) and will go back on with a good tap to the side. It has been in for repair and has some solder joints checked and re-soldered. ...
hi there... i have same problem and i believe the main amp (part 339555-001 EON 15 G2) have to be replaced. jbl prosound sell it for $112.80 and you need to do the job yourself, which is not too big deal but not too easy either.
i did not start yet.
please post later if you did it. thanks.good luck. joel.
Dec 01, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Speakers on new dell Studio Laptop 1737 crackle and pop
Likely, what you are experiencing is the fact that the batteries in your speaker are running low. The sound of this speaker – as with any battery operated device – is reliant on fully-charged batteries. When the charge gets too low, you will experience sound distortion or abnormalities. Just put in fresh batteries, and you should be all set.
Jun 18, 2009 | Dell Studio 1737 Laptop
Replacing the diaphragms on the eon power 15
Yes - Simply face the speaker down - unscrew all of the screws (don't forget to remove the handle and the 2 under it) - once they are all lose, carefully stand the speaker upright and gently pop apart - as it is opening you will need to disconnect some wire harnesses and will need to undo the ground wires. DONE
Apr 07, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
please use a different connectors and try if it works
Dec 15, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Nov 25, 2006 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL Eon15P-1 Main / Stereo Speaker Logo
65 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
