Question about Homelite Choke Lever 4 Blower W Zama C1u Carburetor
My trimmer has no power
I can start my trimmer, but it is very hard to start,
Then it seems to be laboring and I can only run it at half choke because if I move it to run it stalls.
Remove carburetor and take off sides and back out needle valves. Be sure to turn needle valves in all the way and keep track of the # of turns so you can reset it. With sides off, using a bread or garbage bad tie, run tie in and out of inlets and jets. Also, make sure the screen on the one side is not plugged. Spray with carb cleaner, then compressed air. Reassemble carb and install low and high speed adj. screws to previous position. If you don't know where you're at. turn in all the way and back off 1 1/2 turns. This should get you running to fine tune. Also, it is very important to clean muffler out. The spark arrestor can clog and smother your engine. Either clean or remove wire screen and tap out any carbon that may be built up inside. Hope this helps. Also, make sure gas is fresh.
Posted on May 20, 2010
Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
It wont start
First, make sure that the gas mixture is correct (gas and oil mixed in the right proportion). Next, press the primer bulb 3-4 times, turn the choke lever on to Full Choke, and pull the starter cord until the engine seems like to wants to start, but dies. Next, switch the choke lever to Half Choke and start the gas trimmer, giving it gas by pulling on the trigger. Once it has warmed up fully, you may be able to reduce the Half Choke to No Choke, although my 20+ years of experience with dozens and dozens of models tells me that many trimmers run better, although smoking slightly, when you keep them at Half Choke. One last tip, when pulling the cord, try pushing the trimmer away from you with the opposite hand at the exact same time that you are pulling the starter cord--the equal and opposite push-pull technique may sound like something from karate (and it is, in a way), but it is really helpful when trying to start trimmers. Best of luck, Bill
PS: Check you owner's manual (at home or online) for the proper gas/oil mixture. Empty any old gas out and replace the spark plug, if required.
Oct 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Trimmer won't stay running
Most likely needs the carb rebuilt.
First check the prime bulb and fuel lines for cracks. Check the spark arrestor for carbon buildup.
Another problem could be a stuck piston ring, but try rebuilding the carb first as it is usually the source of the problem.
Aug 02, 2009 | Homelite Mighty Lite Lawn Trimmer
Trouble starting gas trimmer
Yes. It sounds like you need to clean the carburetor. Take the carb. off, disassemble and spray with carb. cleaner. Make sure to clean the small screen in carb. Clean the small portals with a Den Tek Brush, (used for cleaning between teeth). They work great for this job. Reassemble carb. and try starting. If this doesn't cure the problem then you will need to buy a new carb. kit and replace the needle valve, gasket(s), diaphragm, & small screen.
Jim
Jun 03, 2009 | Ryobi Garden
Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
May 29, 2009 | Ryobi Garden
Homelite Choke Lever 4  Blower W Zama C1u Carburetor Logo
281 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
