Question about New Home L-373 Mechanical Sewing Machine
Motor makes noise and slowed down
I have a new home sewing machine.
The motor, makes a strange high pitched noise, it has now slowed doen so much I am unable to use it. It was working fine.
It has been oiled, I have sorted the drive belt as per manual instructions.
tried to tension and spool tension.
Thanks
Elaine
    Problem Solver:
  • 5 Answers
Take the belt off the motor and press the pedal see if it is still running slow, if not then there is a tightness in the machine itself.
Posted on May 03, 2010
My bernina aurora 440 sewing machine is making a high pitch humming noise when I turn it on
These machines do make a noise during start-up, but if it stops after the sewing machine has gone through the set-up, it is probably okay. However, if the noise continues, it should probably be taken for a check-up. Even so, if you are worried, a check-up may still be helpful.
Feb 12, 2017 | Bernina Sewing Machines
Just turned machine on after being off and unpugged for a month or so and it is making a noise like a motor is running. any suggestions?
Question on sewing machine motors on vintage machines. - Sewing ...
artisanssquare.com > ... > Sewing Machines
Apr 28, 2010 - 20 posts - ‎4 authors
I've recently acquired 3 vintage machines a Singer 201 and 185 and a New ... When the motor is making some noise, but nothing is moving yet, that .... look - fragile, warped ? something like that anyway - in the first few turns.
How Do I Fix My Sewing Machine: Troubleshooting Your ...
www.craftsy.com > Blog Home > Sewing Blog
Nov 7, 2014 - Well, I've been teaching on Janome machines for about 6 years, and I ... Take the Trouble Out of Sewing Machine Troubleshooting! .... Problem #7: Themachine is trying to sew and making sewing-like sounds, but ..... My Brother sewing machine JX2517 just shut down while I was ... in or close to the motor.
Six Common Sewing Machine Problems Solved ' eBay
www.ebay.com > ... > Sewing Manuals & Instruction
Sewing machines sometimes seem to have a life of their own when it comes to working ... sewing problems can be fixed or prevented just by making sure themachine is... ... If the sewing machine is making uncommon noises, such as grinding or ... Do not use the machine when it is operating this way, and turn off power to ...
Let's Talk Sewing Machine Maintenance! ' LLADYBIRD
lladybird.com/2013/02/13/lets-talk-sewing-machine-maintenanc/
Feb 13, 2013 - At the risk of sounding like a big fat sewing machine snob, it makes me cringe ... I understand that it may not be common knowledge that sewing machinesneed regular ... If the idea of poking around in your machine just sounds too ...... now the tune up turn into oiling the most basic part of your machine, .
Jan 25, 2016 | Sewing Machines
Why is my handwheel hard to turn and making a squeaky noise?
Sounds like possible thread in the gears, or the wrong oil might have been used to oil the machine. Sewing machine oil (clear oil) should be used for oiling the machine. I use an oil called Tri-Flow Lubricant which is available at your local bicycle repair shop.
May 28, 2014 | Husqvarna Huskylock Computerized 910
High pitched noise while stitching
Stop using the machine, it Needs to be tuned up and adjusted. Have it tuned up by a experienced repair technician.
Jan 28, 2014 | Sewing Machines
Sewing machine is sewing slow
This could be for several reasons. I would try the easiest "fixes" first, such as: remove the needle plate and bobbin cover plate, and clean all lint from these areas, including between the feed dog teeth. Lint can quickly accumulate and bog the feed dogs from advancing correctly; oil all moving parts of your machine after removing the top covers, side covers, and the needle plate & bobbin cover plate as mentioned previously--oil anywhere in which metal moves against metal, but make sure you remove all lint or dried oil gunk first; check the belt of your machine to see if it is too tight if it was recently replaced--if it hasn't been replaced or adjusted in a long time, it would more than likely be too loose rather than too tight, but if too tight, it will bog the motor down by making the motor pulley too hard to turn; slowly turn the machine's hand wheel by hand without power with all of the covers off as previously stated and watch everywhere the machine moves--see if anything looks bent, is hitting something it shouldn't or making clanking or clacking noises somewhere as a part may be bent and rubbing somewhere, slowing-down the machine (and of course, if you know the machine has been dropped or damaged, something bent is highly likely which may require a repair tech); check your foot controller--is there something physically blocking the pedal from depressing completely?--these controllers also sometimes just need replaced, so as a test, you may borrow one to test on your machine and see if that helps; if your machine has a fast and slow sewing speed, make sure that setting is not governing the machine from sewing fast; check all of your power cords, plugs, and controller connections to make sure everything is plugged in securely, and maybe try your power plug in another outlet; and lastly, it could be your motor--the motor may need new brushes, some motors require a drop of oil now and then for the bearings (your manual should tell you this if so), or the commutator may have a common build-up of carbon residue that can be removed, and you may have just worn-out your motor that can be replaced. And as always, make sure you are using a new needle after encountering and hopefully fixing an issue.
Feb 17, 2013 | Singer 2263 Mechanical Sewing Machine
I have a Singer 7462 and when I try to load a bobin, the machine makes a nasty grinding noise and the needle slowly moves up and down and ultimately all of the lights on the stitch selection panel flash...
Ok, this is pretty common. Disengage the machine (as if you were winding a bobbin) run the machine at high speed for 5 minutes.
The motor is dirty and this will clean it out. You should hear the pitch of the motor change as the minutes go by.
Aug 24, 2010 | Singer 7462 Mechanical Sewing Machine
New Home L-373 Mechanical Sewing Machine Logo
172 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
