Question about Vacuums
Bagless upright with no suction
There is no suction from bottom only from the hose. I already tried with eureka themselves, but they were no help neither were was the approved service company.
  • 25 Answers
What model do you have?
Posted on Mar 26, 2008
SOURCE:
Eureka pet expert vacuum lost suction
I had the same problem with exact same vacuum, was working great and the one day just lost almost all suction in the hose and in very very poor suction on base when vacuuming carpet, also when vacuuming the carpet everything I vacuum shoots out the bottom and hits my feet, never happened b4, checked all hoses and tor apart every thing to see if their war dust in motor, clogging anywere but nothing everthing looked great, NEED HELP CANT AFFORD TO BUY ANOTHER VACUUM OR TO TAKE TO REPAIR MAN TO B CHRGED AN ARM AND LEG, SOMEONE PLEASE HELPPPP!!!!!!!!!!
Jun 05, 2012 | Eureka 3276AZ Pet Lover Bagless Upright...
I cleaned all the filters and it doesn't have any suction
Check the hoses for a clog. Sometimes the hoses themselves will get clogged and cut off suction -- other times it happens between the beater brush and the hose (within the cleaning head itself). If this is the case, when you turn on the vacuum it will make a higher pitch sound than normal, and sound like it is working really hard, even thought there is no suction. If you can't reach the clog, but you have found it in the hose, you can usually use a coat hanger to either loosen it up or remove it completely from the hose. If this does not work, you can try loosening the clog with another vacuum. Just use the second vacuum to reverse the normal air-flow through the hose ... sometimes this will loosen it up and get your equipment to work.
May 26, 2011 | Eureka 3276AVZ Bagless Upright Vacuum
Hi there. my cleaner turns on and i have suction through the hose, but not on the bottom. can you help?
Does the brushes turn , if not you have maybe a broken belt. if brushes turn i suspect a blockage in the bottom unit.
pete
Nov 08, 2010 | Eureka 2971AV EZ Kleen Bagless Upright...
My Eureka Optima vacuum doesn't have any suction when on the floor option. How can I fix this?
It will as long as long as your accessory hose is properly inserted into the base. Otherwise the vacuum stays on the hose only.
Mar 13, 2010 | Eureka 431A Optima Bagless Upright Vacuum
No suction on main unit
Take the top cover off and check the inlet hose by the brush roll for a clog.
Aug 06, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
No upright suction
This means that you have something plugging the main camber where the dirt enters through beater bar head.check that out. biigg53566
Jun 24, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
My eureka 2961avz bagless vacuum has no suction
Usually clogs are in the dirt inlet by the brush roll, or in the hose. Take the hose off from the bottom and see if there is suction, if not, then the hose is clogged. If suction there, then it is lower. Also is the brush roll turning, if not, that could be your problem.
Jun 06, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Hose suction Eureka theboss smartvac
There has to be a clog in the hose, Unhook the hose and drop like a big marble in it to see if it comes out the other end.
May 10, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Vacuums Logo
42 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
