Question about Andis Outliner II Hair Trimmer
I want my andis outliner 2 clippers to be sharp and the power to be stronger but I want the blades not be sharp enough that the person gets cut or they are uncomfortable how do I adjust them on the inside and the outside?
  • 62 Answers
SOURCE: Putting blade back on my Andis dog clipper
It sounds like you may have a bent hinge which is what the blade slides onto. Please call Andis customer service at 1-800-558-9441 to speak with a customer service rep. They can give you instructions on where to purchase a new hinge or send or clippers in for repair.
Thank you,
Posted on Jul 23, 2008
SOURCE: andis outliner
Andis factory for repairs at 1800 Renaissance Blvd Sturtevant WI 53177
Posted on Aug 30, 2008
SOURCE: My GTO model Andis clippers
YOU HAVE TO OPEN DEM UP. TAKE OUT THE SCREWS ON THE TOP DEN TAKE OFF THE BLADE. ONCE YOU HAVE THE BLADE OUT THERE ARE TWO MORE LIL SCREWS UNSCREW THOSE (NOT ALL THE WAY OFF, JUST ENOUGH SO THAT THE BLADE WILL MOVE) ADJUST THE BLADE HOWEVER YOU WANT. IF YOU WANT IT CLOSE FOR A MORE DETAILED CLOSE LINE (NOT TO CLOSE AS DEY WILL CUT YOUR OR THE CLIENTS SKIN). YOU MUST TRY THEM OUT ON YOURSELF SEE IF THEY ARE TOO SHARP, IF THEY ARE TAKE THEM OFF AND ADJUST THEM AGAIN. EASIEST THING TOO DO IS USE A MIRROR, HOLD THE BLADE AGAINST THE MIRROR DEN MOVE IT AT AN 45 ANGLE DEN TIGHTEN THE SCREWS DER (BARBER TRICK).
Posted on Jul 21, 2009
  • 8 Answers
SOURCE: adjust blade
On the Andis T-Outliner or Outliner if you have use the trimmer for more than 3 hair cuts or 3 time or more I do not recommend moving the blade, reason why is that you have all ready start or have a sit in or a grooved, I have found that by moving the blade it won't cut at all.You need to resharpen the blade with a professional sharpener and have them reset the blade for the type of hair cut you want. The blade can be set to shave or do line ups, and Fades. This type of trimmer is for that kind of hair cut the professional barber use them all the time. Call Mannys Sharpening 323 263-4697 They have a good rating on Yahoo Local.
I have try many sharpener and had no luck, until a friend of mind told me about Mannys Sharpening, They know what they are talking about highly Professional in thier work.
Posted on Aug 01, 2009
  • 8 Answers
SOURCE: Want to adjust trimmer so i give a better outline
Sometimes the new blades are not sharpen enough, You need to have it resharpen by a professional and adjust to the type of work you want it to do. Also sometimes even if you have the blade resharpen it will not cut, because the trimmer motor needs more power to move the blade side to side faster. On and the Andis GTO T-outliner trimmer this the most comm problem. Try Mannys Sharpening
Can I swap sharp cutting blade from one size blade to another?
Well you can either buy a new one from a local shop
http://www.angliaclipperservices.com/dog
Or wait a while and send them off for sharpening
http://www.angliaclipperservices.com/Clipper_Sharpening
May 26, 2016 | Andis Dog Clippers - AGP Super 2-Speed...
Brand new andis trimmer pulling hair and not cutting good
The questions about Andis T-Outliner or Andis Styliner II, about not cutting or pulling hair.
On the Andis T-Outliner trimmer if the sharpness of the blade is worn out, all the tricks and treats won't make this blade to cut hair. Before I do any kind of work to the trimmer, I first test the coil for the right amount power, I can get out of the coil, without this power, it doesn't matter how new or old the trimmer is, the trimmer will not cut hair at all. If the coil is good, I will sharpen the blade and set it according to your needs (lineups or shave setting) after the blade is sharpened and set. The trimmer will need to be, adjusted for alignment to the blade, adjust the power of the coil, and adjust the tension for the blade. All these factors are involved in the Andis T-Outliner to cut hair clean especially lineups or shaving. These adjustments work together for the trimmer to work properly. I know that we all trying to save money, which is part of life, but sometimes frustration will take over and say hell with it, I'll buy another or forget it. Manufactures make mistakes, sometimes the trimmer was not sharpened or adjusted correctly. Any case, what I'm trying to say here, if you try all the tricks & treats and can get your trimmer to work, it may be easier for you to send it to a professional to sharpen & repair the problem and set the blade according to your needs (lineups or shave setting) We specialize on Andis T-Outliner Trimmers. Our complete sharpening & repair service is $19.99 each trimmer, this includes return shipping. We sharpen the blade, adjust and set the blade according to your request (Lineup or Shave setting) make all the necessary adjustments for alignment, power, tension to make your trimmer work better than new. Our mail order service is one day turn around. We are well known throughout the United States for our service in sharpening. Check us out at www.mannys-sharpening.com or call us at 323 237-2885. Service You Can Trust Since 1990. Manny Mobile Sharpening and Clipper Parts Supplies
Nov 26, 2013 | Andis T-Outliner Hair Trimmer
My andis t-outliner keeps pulling hair when cutting and it barley cuts the hair. Do the blades need adjusting?
sound like your clipper blades may require sharpening, just remove the blades and send them to a professional company specialising in scissor and clipper sharpening.
Jun 08, 2010 | Andis 01690 Hair Trimmer
Brand new blades #10 in perticular leave stripes
hi, new blades are not the answer try replacing the blade drive assembly which is located at the drive end of the clipper and goes from side to side, as the clippers are used this part will gradually wear in width thus not moving the cutter far enough to complete a cut this will produce snagging in smaller blades and tram lines in larger blades like 7, 5, 4 and 3's. All Clipper Parts are available for these clipper repairs.
May 29, 2010 | Andis 01690 Hair Trimmer
Want to adjust trimmer so i give a better outline i just bought new blades, not sharp enough
Jun 15, 2009 | Andis Outliner II Hair Trimmer
Misses hair when cutting
You probably need a new blade drive, which is easily replaced yourself, if you are so inclined.
Apr 20, 2009 | Andis 01690 Hair Trimmer
My Andis Masters
tention is probably to tight, or blade needs to be realigned
Mar 11, 2009 | Andis Outliner II Hair Trimmer
My GTO model Andis clippers blade is not properly aligning..how do I adjust it? I BOUGHT NEW BLADES FOR MY ANDIS LINER BUT IT STILL DOES NOT CUT SMOOTH AND SHARP. WHAT IS THE PROBLEM.
Jan 22, 2009 | Andis T-Outliner Hair Trimmer
The problem with Andis clippers is that you are not told how to get the most effective job out of you're clippers,i can attest to that because i've repaired and adjusted hundreds of them,every user wants a crisp cut,nothing less, you want find the answer to that in the instructions,so you're encouraged to send the clipper back to Andis company,i did that once just to see if they really understand their own tool,the clipper cut no better upon it's return,it was then that i discoverer the ultimate solution,blades has to be precise,only then will you get a crisp cut,for any type of hair ,so before you get rid of blades,remember 85% of the time the problem is with the adjustment of the blade.
Dec 17, 2008 | Andis 01690 Hair Trimmer
Andis outliner
Aug 23, 2008 | Andis Outliner II Hair Trimmer
Andis Outliner II Hair Trimmer Logo
318 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
