THEIR IS SOUND, BUT NO PICTURE. PICTURE RESTORE IF POWER IS UNPLUGGED AND THEN RESTORED
    Problem Solver:
  • 4 Answers
If u hit the tv does the picture come in?
Posted on May 05, 2010
My LG Vista has started to go into bootloop. Now, the battery is dead and it won't charge. I tried plugging it in and bringing up the safe mode menu but the back buttons won't work. Help!
It sounds like it has a battery problem try this take off the battery and conect the power cord see if it turn on if not unplug everything the battery and the power cord press the power button for 10 seconds after that tey to plug everyhing back as normal and see if it work from now on you might be able to charge your battery and turn on you pc and finally see what you can do about the bootloop by using saafe mode you might need to do a system restore but not available on safe mide if you tuurn it on before select safe mode do this.
To perform a System Restore using Command Prompt:
1. Start your computer in Safe Mode with Command Prompt. During the computer start process, press F8 key on your keyboard multiple times until the Windows Advanced Options menu appears, then select Safe mode with Command Prompt from the list and press ENTER.
. Next, type this line: rstrui.exe and press ENTER.
system restore using command prompt rstrui.exe
4. In the opened window, click 'Next'.
restore system files and settings
5. Select one of the available restore points and click 'Next' (this will restore your computer system to an earlier time and date).
select a restore point
6. In the opened window, click 'Yes'.
run system restore
7. If you are dealing with a ransomware infection, download and scan your PC with recommended malware removal software after restoring your computer to a previous date.
Note that in some cases, System Restore does not eliminate security infections - malicious programs can hide within restore points. After performing a System Restore, scan your computer with legitimate anti-spyware software.
Good luck.
Jan 30, 2016 | LG Computers & Internet
My picture was like 1380x640 but now its 680x480 and i cant play my xbox because the picture is messed up how do i change this... ive tried going into setting and nothing works..
Have you tried adjusting the aspect ratio by pressing the ZOOM button. There you can select Normal, Wide, Zoom, and Cinema modes. Normal mode: selects the aspect ratio that matches the source's aspect ratio.
If this doesn't work, try power-cycling the TV by turning it off, unplugging it & leaving it unplugged for a few minutes. Then plug it back in, turn it on. You can also restore factory default settings.
Press MENU.
Press LEFT or RIGHT to select SETUP, then press DOWN to open the SETUP menu.
Press UP or DOWN to select Restore Default, then press RIGHT or Enter.
When a message asks if you want to restore factory settings, select YES to restore the settings, or select NO to exit without restoring settings.
Oct 23, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
Samsung cs21m40mj no picture
I don't know if this helps, but I had the same problem in reverse. Great picture - no audio. I finally unplugged the TV and all devices connected to it (DVD player, cable box, etc.) waited 3 minutes and plug everything in. The audio was restored.
May 19, 2012 | Televison & Video
Has power but No Video or Audio
Tries unplug &replug see get it back or must replace the video board might burn parts.
Mar 28, 2009 | Hitachi 57S500 57" Rear Projection...
Just got resistance 2.  loaded and got the "tones" when system started, but no sound after that.  picture is fine
Hi, and welcome to FixYa!
Go to settings. Sroll down to system settings. Enter system settings and scroll down to restore to factory default settings. Once you restore the factory default settings, power down the unit and unplug it for two minutes. While it is unplugged, reset your router. Then after the router restarts, restart your PS3. This should fix your problem. You may have to reconfig your audio/video settings. If this doen't fix your problem, on your XMB go over to the saved game data. elete any resistance 2 files. Also delte the resistance 2 savedgame progress. Re-install the game. If this doen't fix the issue, then you have a faulty copy. Just take it back for an exchange! Let me know if this helps by rating my solution! Good Luck, and Happy Gaming!
Jan 12, 2009 | Sony Resistance 2
Pitcure no sound
Try unplugging the set for a munite and check the internal/external switch on the back if this model has one. If sound is not restored you have audio circuit problems
Oct 14, 2007 | RCA P60921 60" Rear Projection Television
No Picture, Menu screens or anything video - Sound still working!
Yes... Look for F851 and replace it with a slow blow 3.15A fuse per Toshiba. Bill
Jul 01, 2007 | Toshiba 43AX60 43" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
