Question about Kodak EasyShare M883 Digital Camera
Turns on and zooms in and out then turns off - Kodak EasyShare M883 Digital Camera
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 03, 2010
Testimonial: "Thank you. I went down the list and what worked was blowing out the cracks and it worked! I didn't have any canned air so I used my paintball gun!:-)"
My problem was sand, I used canned air to blow at the lens while it was extending in and out. I held the on button so that it would keep going and finally it just stayed on.
Posted on Feb 06, 2012
Digital zoom. How do you turn it on?
You can maximise it .. but remember digital zoom deteriorate the image quality.. better to use only optical zoom and then crop in the computer
Apr 16, 2014 | Fuji Finepix S4080 720p Hd 14mp Digital...
Turn on digital zoom
Turn the zoom lever toward the single-tree symbol and hold it until it zooms all the way. Release the lever then turn it toward the single-tree symbol again to engage the digital zoom.
Full details are in the "Zooming in More Closely on Subjects (Digital Zoom)" section beginning on page 60 of the manual.
Jul 16, 2012 | Canon PowerShot SD960 IS Digital Camera
When my brother was playing game he press many more and my iphoe zoom in
If your phone is an iPhone 3GS, head over to to Settings icon then tap on General Accessibility and turn the zoom feature off.
Feb 04, 2011 | Apple iPhone Smartphone
How do I turn on the Digital Zoom?
First, the digital zoom feature is not available in AUTO mode.
If you're not in AUTO mode, is the digital zoom turned on in the menu? Check the "DIGITAL ZOOM" entry in the Shooting menu.
Jul 23, 2010 | Olympus Camedia C-700 Ultra Zoom Digital...
Hi, I have a DMC-FX30. When i turn the zoom
mera Digital Camera Hi, I have a DMC-FX30. When i turn the zoom Answer Failed: retry Hi, I have a DMC-FX30. When i turn the zoom swithc it is stiff and goes to full zoom and cannot be... (More) (More) Hi, I have a DMC-FX30. When i turn the zoom swithc it is stiff and goes to full zoom and cannot be stopped - only when i switch the camera off. Can you help?
Feb 11, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Iphone screen keeps zooming in
Go to (settings > general > Accessibility > Zoom) and click turn off zoom. Warning: getting around to just do this is a royal pain in the ***. Be patient.
Jul 19, 2009 | Apple iPhone 3GS Black (16 GB)
Zoom
My zoom problem was a combination of the software and hardware when it came to the neutral position for the zoom slider. When the camera is first turned on, if the physical zoom slider (hardware) is in the neutral position (you are not touching it) the camera software does nothing, but if you are pushing the physical zoom slider when you turn on the camera, the software resets the "zero zoom" position into memory. The solution to my problem was to push and hold the physical zoom slider towards the wide position and the software realize reset the "zero zoom" neutral position. This may take a few tries to get it right (if you over compensate, do the opposite and push the slider towards "T" when you turn it on), but I hope this will solve your problem and save you a few bucks.
Ryan
Jul 04, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Zoom
IT WONT...DIGITAL ZOOM IS IMPOSIBLE TO TAKE OFF I YOU DONT HAVE OPTICAL ZOOM
Feb 21, 2008 | Canon PowerShot S3 IS Digital Camera
Kodak EasyShare M883 Digital Camera Logo
814 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
