Question about Sony Playstation 3 (PS3) Console
After turning on the system, the console shuts down and the red light flashes
  • 370 Answers
The system has been over heated and is shutting down due to damage. you should look into sending it into Sony's refurbish program. its the cheapest option for you at this time.
Posted on May 03, 2010
Fully backwards compatible ps3 shuts down with 3 beeps and flashing red light when trying to play ps1 games
Hmmmnnn, consider the reason they pulled the rev compatible system off the market. It is possible to be getting the symptoms of YLOD without it actually happening with some games. The older games spun faster(sometimes) and made the system work harder. It could be heating up and shutting down right at the point of failure. I've seen 2 different revers compatible systems YLOD the same way. Good luck.
Apr 06, 2013 | Sony Playstation 3 (PS3) Console
Turn on system, it flashes green than a yellow flashes then to red flashes. i have unplugged everthing even shut down power towhole house...and nothing.
Yes this is the red/yellow light and you will need to get it fixed, it is not a power surge unfortunately!
It is the motherboard taking too much heat!
You can fix it at home with a top guide or send it in.
May 31, 2010 | Sony PlayStation® 3 (80GB) Console
While playing a game console turned off and game disc is stucked inside, turn power on and light turns green for couple seconds then flashes red and turns back off, no chance to eject game disc.
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked.
The blinking red light is infact a general hardware failure message. In this particular case, his hardware failure is with the blu-ray drive, that's why the system does not shut down until the drive is accessed. if the system is overheating, it will tell you so in the top right hand corner. It will say the system has overheated and is shutting down to avoid further damage.
Provide a proper vent for the system...
Hope this will help...
May 28, 2010 | Sony Playstation 3 (PS3) Console
Wont turn on flashing red light
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
"When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
"If this happens:
· c Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
· Leave the PS3 system off for 30 minutes to let it cool down.
· If you continue to have issues, you will have to send the system in for service."
May 27, 2010 | Sony Playstation 3 (PS3) Console
Hello, My PS3 just keeps turning itself off. I have tried to reset the system but it keeps flashing red and yellow lights and then turns itself off into standby mode? HELP......
Try removing the game inside your disc. then try removing other external hardware and slots and try again. If problem persists it might be a system problem. Please go to the shp from where you bought it and ask them for a replacement.
May 16, 2010 | Sony Playstation 3 (PS3) Console
System shut down while playing game... light flashed red.. tried turning on, light flashed red then yellow... shut off again.. could not eject game...
This is known as the yellow light of death.Similar to xbox 360 ring of death,this is normally caused from overheating from the console.If it is still under warranty contact playstation and send it back to them other wise it's about $150.00 usd to have it repaired. Here's the number
1-888-
780-7690 between 6AM - 8PM (PST) Monday - Saturday and 7AM - 6:30PM (PST
Apr 14, 2010 | Sony Playstation 3 (PS3) Console
PS3 shuts down after one second
hi , i hate to say this but you need to do this asap. Call the playstation support line and send it in. your ps3 is experience a corrupted hard drive. This will only get worse and will eventually shut down for good.
Jun 21, 2009 | Sony Playstation 3 (PS3) Console
The game system will not turn on.it flashes a yellow light
What model is your PS3? 40 / 60 / 80 etc.
I can help you with this problem or at least give you low down on what's going on.
Mar 03, 2009 | Sony Playstation 3 (PS3) Console
360 issues
Two Red Lights
The two left quadrants of the Ring of Light flash red on the front of the Xbox 360 console
This behavior occurs when the internal temperature of the console exceeds the acceptable limits. You may think of this as too hot, overheating, and so on. Make sure the fans are operating and the system has adequate ventilation.
Since you've been inside it's possible that a heatsink or some other part of the cooling system is not working properly or is loose. Check all these!
Good Luck!
Nov 17, 2007 | Microsoft Xbox 360 Console
Sony Playstation 3 (PS3) Console Logo
101 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
