Question about John Deere Tractor 1020, 1520, 1530, ITJD37
Adjusting John deere ''Sabre'' model deck
Can I adjust the decking on my john deere tractor? it has the deck handle to adjust the cutting deck but over some time it appears even at its highest setting the deck still cuts low.
any assistance would be greatly appreciated
  • Anonymous Mar 13, 2014
    adjust steering on john deere / 530
  • Anonymous Mar 16, 2014
    i have a new holland gt 20 with a 52 inch deck that cuts uneven and leaves leaves uncut lines in the grass. it has new blades and has been to the shop multiple times but to no avail. is it possible that the removable steel plate on the top of the deck or the deck itself be warped. the mover only has 200 hours on it and has never been wrecked. any help would be much appreciated
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
Move machine to flat/level surface,with deck raised put a 2x4 between rear of deck and ground.Make sure that the 2x4 goes all the way under deck from one side too the other.Once that is done lower deck all the way and make sure lift lever is all the way forward.Then on the rear top side of deck loosen bolt that holds arm to deck bracket,pull bracket as far down as you can then retighten bolt.This is also the point where you can level deck side to side.
Posted on May 05, 2010
I cant lower the mower deck below 2.5 inches without the belt coming off, it's a 2007 John deere LA130 48" deck
try to adjust the deck. sounds like it is not level. if it is level you may have a bent pulley
Oct 22, 2016 | John Deere Garden
My John Deere D110 is cutting the grass to short on the highest deck level. How can I fix it.
level the deck off as a tilted deck will cut lower on the low side
adjust the deck mounting bars or deck pilot wheels
check that the cutter/pulley spindles are in good condition and not falling down
Sep 15, 2016 | John Deere Garden
How to level the mowing deck on 2002 John Deere (Scotts) 42 " mower. Mower deck drags on right side. Mower height adjuster doesnt work seems jammed.
Have a look underneath while someone operates the height adjustment. There's probably a link arm come off which does deck height. Go to google images for this machine, type height adjustment and look at the pictures if you don't have a handbook. Google JD handbooks and see if you can find a free download.
Aug 13, 2016 | John Deere Garden
Need to know how to adjust deck belt on a 54
I would need the model # of the deck and tractor, but all newer mowers use a spring to maintain constant belt tension. I can get you a diagram if you need one.
Dec 03, 2011 | John Deere Garden
I have a John Deere rx75. The mower deck seems to be too low when I set it at the highest position. I have no idea how to do that or to level the deck. Please help. The lawn is cutting uneven and its...
find someone who can read and use the internet
go to www.google.com
search for john deere lawn tractors
go to the john deere website and click around under "support" until you find the manuals
download a manual for your model,l but they are all about the same
have the person who can read, read you the part in the manual about adjusting the deck height and how to level it.
there you go, bob's your uncle.
Sep 19, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
May 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have a John Deere model# LA105 , and it is cutting uneven because one blade sets lower then the other,the blades are not bent.
I have a John Deere lawntractor, 105. Won't start. Gas getting to the carb, but not getting into carb. Is this a common problem. Has been setting for a year. Any suggestions on problem
Sep 11, 2009 | John Deere Garden
John Deere Lt 166 ride on mower
jd lt 166 has 5 different decks
3 of which have the same belt routing
1st the belt needs to be adjusted correctly to stop it from "slacking off"
then on most decks the belt is routed in between the 2 small idler pulleys and then to the engine pulley
so let me know the deck i.e. 36", 42 ", 46", 48"
different belt sizes also
kendo
Jun 14, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Tractor 1020, 1520, 1530, ITJD37 Logo
786 people viewed this question
Top John Deere Toys Experts
Jim Goldsmith
Jim Goldsmith
J.D. Browning
J.D. Browning
Wayne Fellows
Wayne Fellows
Are you a John Deere Toy Expert? Answer questions, earn points and help others
